Four-Wheel drive usage frequency
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Horseshoez, Nov 3, 2022.
  1. Nov 3, 2022 at 7:01 PM
    Horseshoez
    Horseshoez [OP] Well-Known Member
    Dale
    Maryland
    Hey gang,
    I'm working my way through the Owner's Manual on my new 2022 TRD Sport 6MT and noticed the following two directives in the PDF version of the manual:
    • Page 302:
      • Summary of functions:
      • Use the front-wheel drive control switch to select the following transfer
        modes:
        • 2) "4H" (High speed position, four-wheel drive)
          • Use this for driving only on tracks that permit the tires slide, like off-road, icy or snow-covered roads. This position provides greater traction than two-wheel drive.
          • The four-wheel drive indicator will come on.
    • Page 305:
      • Four-Wheel drive usage frequency
        • You should drive in four-wheel drive for at least 10 miles (16 km) each month. This will assure that the front drive components are lubricated.
    So here's my question, during non-winter months I really don't have a place to drive 10 miles on dirt, grass, sand, or anything else slippery; how do y'all keep your front drive components lubricated?
  2. Nov 3, 2022 at 7:04 PM
    Bishop84
    Bishop84 Well-Known Member
    Straight on a paved road for 1 mile. Even if there's turns it won't hurt it. 10 miles doesn't really make any sense. But it does need to be used.
    The diff is spinning even in 2WD, the transfer case not as much, but it just needs to be used.
  3. Nov 3, 2022 at 7:04 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Don't worry about getting 10 miles. Shift into 4HI on straight or straight'ish sections of road.
    Amazed how often this comes up on this forum.
  4. Nov 3, 2022 at 7:05 PM
    ShimStack
    Ben
    NC
    Just the spider gears and side gears.
  5. Nov 3, 2022 at 7:07 PM
    Bishop84
    Yup, but its far from stationary.
    ShimStack[QUOTED] likes this.
  6. Nov 3, 2022 at 7:10 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just check that it, in fact, goes into 4 wheel drive.
    I never check mine monthly. It worked 7 months ago, and I check again when the temp drops to sub freezing the next winter season.
    I've run these trucks since 1998. That monthly chech is ridiculous .
    Just check before the snow flies.
    It's a solid system. Any weak link will be electrical.
  7. Nov 3, 2022 at 7:13 PM
    Bishop84
    We actually do see the transfer case actuators stick, its rare, and you're right. But it doesn't hurt.
  8. Nov 3, 2022 at 7:16 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    I’ve never read my manual…this is news to me. Good thing I use my 4wd regularly :anonymous:
    koditten likes this.
  9. Nov 3, 2022 at 7:18 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    For 4 high I have a convenient 3 mile paved stretch that is just about straight as an airfield, the speed limit is 40. The transfer case will shift in/out silently.
    When I engage 4 high on the pavement I change the center screen to something different than normal as a reminder.
    For 4 low I occasionally engage it in my dirt drive which is about 200 feet.
    I don't feel the actual 10 miles is as important as making sure it gets engaged every month or so to exercise/lubricate the actuators and sling the oil around the transfer case a bit.
    GarlicFarts and koditten like this.
  10. Nov 3, 2022 at 7:21 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
  11. Nov 3, 2022 at 7:23 PM
    Tacomaryan18
    “When I engage 4 high on the pavement I change the center screen to something different than normal as a reminder.”
    This is great advice. A few times when I have put the truck in 4hi I’ve forgotten and driven the highway home. I’ll do this next time.
    musicisevil and RustyGreen like this.
  12. Nov 3, 2022 at 7:25 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    I’ve never forgotten I was in 4 anything. Typically I have to turn onto the pavement when I’m coming off a trail and the truck will remind me real quick:rofl:
  13. Nov 3, 2022 at 7:32 PM
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    I've always run 4hi monthly at the beginning of the month, same time as I zero my trip meter #2... This is on top of any time I actually use fourwheel on the real... Which sadly isn't as often as it's like these past couple of years
  14. Nov 3, 2022 at 7:36 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    ^Guy I bought mybtruck from had a baby and said he hadn't used 4wd in over a year. It was slow and make a noticeable clunk the first few times i had it into 4hi or lo. One of the only times a vehicular problem solved went away by itself. I flip it on a few times a month, as much to make sure there are no problems should i really need it.
  15. Nov 4, 2022 at 5:27 AM
    Horseshoez
    Dale
    Maryland
    Thanks folks!
    RustyGreen likes this.
  16. Nov 4, 2022 at 6:21 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Living in SoCal provides endless hours in freeway stop and go traffic. Perfect time to exercise that button for a couple miles a day!
  17. Nov 4, 2022 at 6:26 AM
    Horseshoez
    Dale
    Maryland
    Yeah, I used to live in SoCal in the late 1970s and in the Bay area in the early 1980s; I remember hours on cruise control without hardly moving the steering wheel at all. :)
    Here in New Hampshire, I'm hard pressed to think of a road within 20 miles of me with a straight stretch which exceeds even a mile.
    khine13 likes this.
  18. Nov 4, 2022 at 6:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's less about the distance traveled and more to get those actuators working. On my Tacoma it's a non-issue but in my Tundra, when it's raining and I remember, I'll just switch back and forth between 2HI and 4HI a few times over the span of a mile or so. Then when I get on my neighborhood street I'll jump in and out of 4lo once or twice.
  19. Nov 4, 2022 at 9:01 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Hit some gravel roads or trails in the summer. I do enough 4WD driving year around I've never needed to worry about this.
  20. Nov 4, 2022 at 9:02 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    It is the emergency fire started stored in the glove compartment. Most automotive savvy folks know more than what is in the manual.
