Fox 2.0 Coil over height without adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bzzr2, Oct 15, 2018.
  1. Oct 17, 2018 at 9:34 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Front
    A hair over 13 inches from edge of rim to fender. Or just over 22 inches from center cap to fender.
    Rear
    A hair over 16 inches from edge of rim to fender. :confused:
  2. Oct 17, 2018 at 11:18 PM
    bzzr2
    bzzr2 [OP] Well-Known Member
    Thanks!!! I will measure up my stock heights when i get home in a couple days and see where things appear to be!.
    Dirty Harry[QUOTED] likes this.
  3. Oct 18, 2018 at 6:31 AM
    Dirty Harry
    Andrew
    SW Florida
    Let us know what those stock numbers are. I forgot to measure before I modified.
  4. Oct 19, 2018 at 11:45 AM
    bzzr2
    For sure!
  5. Oct 19, 2018 at 11:59 AM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    If you go 1.5 in the front you will have a 1/2" of bro lean. In fact if you park on uneven pavement or on a slight incline like a driveway it will look like you have major bro lean. Ask me how I know.
    I suggest 1 inch in the rear if you go 1.5 in the front. It will look really good. I am at 1.5 in the front and 1 in the rear with 265/75/16's and if i were any higher it would look goofy. Zero issues with the truck after the lift. Needle bearing was not replaced. Honestly these are the safest settings and you shouldn't run into any weird suspension issues. I was going to go 2 in the front and 1 in the rear.....Glad I didn't. FYI i am not using fox suspension so I can't answer any questions about that.
    Thanks!
    Dirty Harry likes this.
  6. Oct 19, 2018 at 1:39 PM
    bzzr2
    Thanks for your reply. I intend to go with an AAL at minimum or the Dakar pack if I can swing it. Everything is just so over priced in Canada these days. For example the 2.0’s are gonna run me $585 each + 13% tax. Dakars are $650 area ++
  7. Oct 21, 2018 at 11:25 PM
    bzzr2
    So my measurements on a stock 2018 TRD access cab with 3k miles are just under 12 inches from edge of rim to fender and about 20.5 from centre of the hub to edge of the fender. so based on our numbers looks like the fox 2.0's are getting about 1.5 inches of lift up front. i hope that is correct and not just that because i want it to be...!
