Fox 2.0 coilover + 2" spacer lift?
Discussion in 'New Members' started by man_4x4, Feb 5, 2019.
  1. Feb 5, 2019 at 7:18 AM
    man_4x4
    man_4x4 [OP] Member
    Manuel
    Toyota Tacoma TRD Sport 2011
    Hi! I'm Manuel from Chile.
    Thank you guys for accepting me... amazed by this great community of tacoma lovers!
    Just wondering if some has installed an extra 2 inch lift spacer on your Fox 2.0 performance coilover? Im actually running with the oem bilstein suspension with a 2" inch lift and I would like to keep it on my new fox, so I can use them with zero preload on the spring.
    Does it make sense? I suppose that if the spring is less preloaded, the suspension work smoother?
  2. Feb 5, 2019 at 7:22 AM
    tcjacado
    tcjacado Well-Known Member
  3. Feb 5, 2019 at 7:29 AM
    man_4x4
    man_4x4 [OP] Member
    Manuel
    Thank you!
    irayfz6 and tcjacado[QUOTED] like this.
  4. Feb 5, 2019 at 7:29 AM
    man_4x4
    man_4x4 [OP] Member
    Manuel
    Thank you!
    irayfz6 and tcjacado like this.
  5. Feb 5, 2019 at 7:35 AM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    Welcome.
    I wouldn't stack lifts like that. The fox coilovers should ride plenty smooth and are designed to run the preload. They would be a massive upgrade (without the spacer lift) over what you are currently running.
    irayfz6 and Taco critter like this.
  6. Feb 5, 2019 at 7:39 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6, Taco critter and tcjacado like this.
  7. Feb 5, 2019 at 7:52 AM
    man_4x4
    man_4x4 [OP] Member
    Manuel
    Thank you for the reply. I was thinking on the spacer because I would love to gain 2.5 or 3" total height... so I can set the Fox to only 0,5 or 1"
    irayfz6 likes this.
  8. Feb 5, 2019 at 7:54 AM
    tcjacado
    Then you need to look into maxtrac spindle lift. Unless you are 4x4.
    Taco critter and irayfz6 like this.
  9. Feb 5, 2019 at 7:56 AM
    man_4x4
    man_4x4 [OP] Member
    Manuel
    Yes, I'm 4x4
    irayfz6 likes this.
  10. Feb 5, 2019 at 8:09 AM
    tcjacado
    Ok... no spindle lift.
    Going to want to stay below 3 inches or a drop bracket lift is in your future... cut out cross member for front diff to drop.
    irayfz6 and buckhuntin-tacoma like this.
  11. Feb 5, 2019 at 8:11 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    You don’t wanna stack lifts together it will ride like crap an you CVs will hate you for it. The fox’s will ride GREAT. If you want some more lift check out a 1in body lift. PS welcome to TW:cheers:
    irayfz6 likes this.
  12. Feb 5, 2019 at 8:18 AM
    toysrgood
    SC
    2011 4x4 Reg Cab
    I see what you're thinking of doing now. If I were you I'd spend some time researching around on here and see what others are doing with the Fox 2.0s, but I think they'd meet your goals with a little bit of preload and still ride nicely.
    irayfz6 and MattCowsmasher like this.
  13. Feb 5, 2019 at 8:20 AM
    man_4x4
    man_4x4 [OP] Member
    Manuel
    Thank you. I undestand they lift max 2" isn´t it?
    irayfz6 likes this.
  14. Feb 5, 2019 at 8:20 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Welcome to Tacoma world!
    Yeah just run the fox. I think you’ll be pleased with the difference in ride quality dispite the factory preload.
  15. Feb 5, 2019 at 8:23 AM
    tcjacado
    You can always run a stiffer/longer spring on the fox set up and you won't need preload to achieve the desired lift.
    No reasonable person on here is going to tell you to put a spacer and a coil over together.
    irayfz6, toysrgood and LukeCC like this.
  16. Feb 5, 2019 at 9:16 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  17. Feb 5, 2019 at 11:41 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  18. Feb 5, 2019 at 11:45 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Welcome, here is all the info you need and crank the 2.0s up to 3".
    https://www.tacomaworld.com/threads...-and-rear-2-0-remote-reservoir-review.433285/
  19. Feb 5, 2019 at 5:18 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  20. Feb 5, 2019 at 5:27 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    Welcome.
    irayfz6 likes this.
