Fox 2.0 Coilover IFP and rear 2.0 Remote Reservoir review
Discussion in 'Suspension' started by Chaz84, May 21, 2016.
  1. Aug 23, 2017 at 5:13 AM
    #81
    Chaz84
    Chaz84 [OP] Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    I went through it in pretty good detail at the beginning of the thread bud. Basically, you just need a vise and two different sized spark plug sockets (might be able to use regular sockets and just work the bushing out the rest of the way with a screw driver in the bushing hole). One smaller than the opening for the bushing and one larger so you can press out the bushing into the larger using the smaller socket.
  2. Aug 23, 2017 at 5:58 AM
    #82
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Yea, I saw where you described that. Other than the bushing, the install is straight forward?
    Lift the axle, lossen the top the nut on the old shock, lower the axle and undo the bottom shock mount bolt. After swapping the bushing, put the bottom shock mount bolt through the 2.0, raise the axle and attach the top nut?
    When I say I have no tools, I'm pretty much working with jack stands, floor jack, and a socket set haha I don't even have a vise so I'll need to get creative with the bushing.
    This has me right on the edge for splurging for the CD adjustors.
    https://www.tacomaworld.com/threads/fox-group-buy-amazing-prices.506112/page-3#post-15869738
  3. Aug 23, 2017 at 11:30 AM
    #83
    Chaz84
    Dr. Chase
    GA
    I did it on jack stands with a floor jack and super sketchy 2x4's. Hit harbor freight for a vise. You are spot on with the install. Just be aware, getting the bottom shock mount in is a pain if you don't put a light coating of polyurethane friendly grease in the axle mount before sliding the shock in there (I used marine grease after the passenger side bushing got pinched and I realized you have to mount the roost guard BEFORE mounting the shock). Also, you have to mount the remote resi's to the shock body with the supplied mounts, this too takes a second to get them even and all (I'm kinda anal about both sides matching).
    I highly suggest getting the shocks ready before attempting the install bc it could turn into a cluster. Lastly, make sure you have the remote resi's facing away from the axle on both sides (see pics).
    Chase8059[QUOTED] likes this.
  4. Aug 23, 2017 at 10:20 PM
    #84
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
  5. Aug 24, 2017 at 5:15 AM
    #85
    Chaz84
    Dr. Chase
    GA
    Call Wheeler's Off-road (541-474-2879, Dan the man left so I think his replacement's name is Steve... Ask for him, sharp guy). They can tell you for sure and they sell them individually as well (you only need one since one side is behind the axle). I would guess it does fit though, the shock bodies should be the exact same.
    TXTaco13[QUOTED] likes this.
  6. Aug 29, 2017 at 3:45 PM
    #86
    Gw2
    Gw2 Well-Known Member
    Concord Ca
    2011 AC 4x4 Trd Off
    What 2.0 are you running with add a leaf? 0-1.5?
  7. Aug 30, 2017 at 5:23 AM
    #87
    Chaz84
    Dr. Chase
    GA
    1.5 progressive aal's with 2.0 remote resi's w cd adjusters 0-1.5.
  8. Aug 30, 2017 at 5:30 AM
    #88
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    Ok thanks.
  9. Aug 30, 2017 at 6:37 AM
    #89
    Chase8059
    Chase
    ESVA
    For those interested, the active GB has some pretty good deals. I placed my order last night now just waiting on the invoice to come in so I can pay it.
    2.0 rears with RR and CD adjustors. Also got the roost shields. They only sold them in pairs but the price was awesome anyways.
  10. Aug 30, 2017 at 8:43 AM
    #90
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    Yep. I think I'm going to pull the trigger also. Just don't know if need the cd adjusters.
  11. Aug 30, 2017 at 8:56 AM
    #91
    Chase8059
    Chase
    ESVA
    Do it :boink:
    Dr. Chase sold me on the CD adjustors. I don't offroad a ton, but I did haul/tow from time to time so I think the benefit to adjust them will be felt there.
    Gw2[QUOTED] likes this.
  12. Aug 30, 2017 at 9:12 AM
    #92
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    ahh, I hate you. Now I've got more to think about lol.
  13. Aug 30, 2017 at 9:23 AM
    #93
    Chase8059
    Chase
    ESVA
    We're all here to help each other empty out wallets :thumbsup:
  14. Aug 30, 2017 at 9:29 AM
    #94
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    Yeah ever since I found this site that seems to be the case.
    Chase8059 likes this.
  15. Aug 30, 2017 at 11:24 AM
    #95
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    Cd adjuster? Yes please! Pulled the trigger
  16. Aug 31, 2017 at 4:46 AM
    #96
    Chaz84
    Dr. Chase
    GA
    You guys are hilarious, but think you'll be happy once you play around with them. As stated before, I didn't think they were worth it until I had a bed full of guns and ammo a few weeks after the install and turned them up to stiffen the back end. Made the rear go from "weighted spongy" back to controlled and awesome. Do note the adjustment knobs are pretty stiff at first so be prepared to have to turn them with a shop towel for grip. Lastly, $ spent on Taco suspension is never $ wasted... I think hahaha
    Gw2, what are you doing with your leaf packs?
  17. Aug 31, 2017 at 5:30 AM
    #97
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    Don't know yet. I know I want to do 1.5 add a leave since I got the 0-1.5s. Just trying to figure what would be best with TSB leafs Ive got.
  18. Aug 31, 2017 at 9:22 AM
    #98
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    I thinking a single leaf because i wanna keep my overload.
  19. Aug 31, 2017 at 9:27 AM
    #99
    Chase8059
    Chase
    ESVA
    I have the 3pc and kept my overload. Just had to grind off the brake line brackets.
  20. Aug 31, 2017 at 10:37 AM
    #100
    Gw2
    Concord Ca
    2011 AC 4x4 Trd Off
    How much lift?
