Fox 2.0 Coilover IFP and rear 2.0 Remote Reservoir review
Discussion in 'Suspension' started by Chaz84, May 21, 2016.
  1. Sep 30, 2017 at 2:52 PM
    #141
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    @Chaz84
    Can you explain how you mounted the roost shield on the passenger side?
    I'm mid install and the roost shield comes up and also covers about an inch of the shock body, which interferes with mounting the reservoir to the shock body.
  2. Sep 30, 2017 at 3:10 PM
    #142
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Doesn't the roost shield go on the front side of the shock? And the reserviour towards the back? the roost shields are supposed to protect the rear shocks from rocks being kicked up from the front tires.
  3. Sep 30, 2017 at 3:40 PM
    #143
    Chase8059
    Chase
    ESVA
    Not exactly, on the driver side yes because the shock is mounted at the rear of the axle. On the passenger side the shock mounts to the front of the axle and your suppose to mount the reservoir away from the axle.
    EDIT
    I was able to get it positioned just right once in the shock mount. It wasn't looking right when I was getting it into position.
  4. Sep 30, 2017 at 4:06 PM
    #144
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    You should never adjust any coilovers without taking the insane pressure of coil spring's preload on them..... ever... Like what who would do that...
    I can crank mine up (less preload) if I jack up my front end and use a lubricant and feather it up.. but never to crank it down... Like what
  5. Sep 30, 2017 at 5:15 PM
    #145
    Chase8059
    Chase
    ESVA
    Install was pretty easy with the exception of having to find a 19mm wrench... I had the sockets but there isn't enough room to get them on the upper shock bolt.
  6. Oct 4, 2017 at 11:10 AM
    #146
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Does the roost shield move up and down with travel?
  7. Oct 4, 2017 at 3:47 PM
    #147
    Chase8059
    Chase
    ESVA
    It's attached at the base of the shock near the lower mount so it moves up/down with the axle.
  8. Oct 9, 2017 at 2:10 PM
    #148
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Does it completely clear the reservoir at full flex?
  9. Oct 10, 2017 at 8:54 PM
    #149
    RoughTread
    RoughTread Member
    Very nice detailed info. Where do you find good deals for the suspension? Sorry maybe I missed it while zooming through...
  10. Oct 18, 2017 at 9:09 PM
    #150
    Gw2
    Gw2 Well-Known Member
    Concord Ca
    2011 AC 4x4 Trd Off
    Check out the “group buy” section in forum list.
    RoughTread[QUOTED] likes this.
  11. Oct 19, 2017 at 12:00 PM
    #151
    Chase8059
    Chase
    ESVA
    Not sure what you mean by "clear". My truck doesn't really stretch it's leg very often. I opted for these shocks for since they are aluminum and adjustable. My truck sees the beach more than a trail but hopefully that will change in the coming months.
    Are you worried about the roost shield clearing the resi and shock body when flexing, and then making contact with either when it gets compressed again?
  12. Oct 23, 2017 at 9:12 AM
    #152
    Chaz84
    Chaz84 [OP] Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    Hey fellas, have been slammed at work...
    Will try to address as much as possible...
    The 0-1.5's used to come with the larger bushings installed and alternate (correct size) included, but Fox has changed this since I made them aware. They should come with the proper sized bushings now. No idea about the longer 2-3" versions.
    The resi braided lines on my truck sit at a 90 degree bend; however, I will say that the last time I had the truck on a lift, it is clear that the roost guard is rubbing the passenger shock's resi mount. I tried to reposition, but it's pouring rain outside now and won't be able to get pics today. Either way, it's not bad and with how I wheel my Taco, some wear and tear is expected. Thank goodness for aluminum not corroding. It does clear the resi btw, just catches the bottom outside of the resi mount.
    Lastly, this dang thing still rides like a dream. Large speed bumps at 50 are like, "hmmm, thought there was something there... Oh well, barely felt it... Back on the gas muhaha."
    jackn7 and Coolerman like this.
  13. Oct 23, 2017 at 9:16 AM
    #153
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Is it possible to flip the shock so the reservoir is on the backside of the shock, and the roost guard is on the front of the shock?
  14. Oct 23, 2017 at 11:18 AM
    #154
    Imphedup
    Imphedup Trout Addict Whitetail Killer
    CHAD
    LOWELL,MI
    2017 DCLB OR
    How’s the cornering? Does the truck pitch/roll or does it stay level? I’m coming from 6112’s which stayed level but were a bit stiff for my liking at slower speeds. 45 mph and above they were great.
    Also is it possible to adjust the coil overs on the truck? Hard/easy/not recommended?
    Thx
  15. Oct 24, 2017 at 8:54 AM
    #155
    Chaz84
    Dr. Chase
    GA
    Chase, just realized you have your passenger side rear mounted incorrectly. The resi goes behind the main body and the roost sits free. Zero issues clearing the axle. You need to remount that pronto bud.
    Cornering is sick man. I drive my truck almost as hard in turns as my old rice rocket Acura Rsx-s I used to have (every bolt on money could buy, was in the 12's with a 2.0 :D... I do miss track days). The 6112's are def way too stiff bc of their valving. I actually think both use 600lb springs so cornering should be similar.
    It is def not recommended to adjust them on the truck due to the aluminum body; however, it is possible with super sketchy coil compressors. It would have to be a small adjustment for sure. Take my advice on three full turns up on the driver's and you'll be sitting pretty.
    Imphedup likes this.
  16. Oct 24, 2017 at 9:06 AM
    #156
    Chase8059
    Chase
    ESVA
    I thought it was mentioned that resi's should face away from the axle when you install them.
    EDIT
    So I went out and flipped mine around... I kinda feel like an idiot that I didn't notice this at first. The roost shield could hit the resi mount under compression. Now that the resi is mounted toward the rear of the truck, the only concern is how much space to leave between the bottom of the resi, and the axle so that it's not bottoming out on the axle.
  17. Oct 24, 2017 at 10:01 AM
    #157
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    That's why I had been asking about clearance issues, it just didn't look right.
    Chase8059[QUOTED] likes this.
  18. Oct 24, 2017 at 10:30 AM
    #158
    Imphedup
    CHAD
    LOWELL,MI
    2017 DCLB OR
    Sweet I like corners!
  19. Oct 25, 2017 at 5:24 AM
    #159
    Chaz84
    Dr. Chase
    GA
    I have my resi mounted with the bottom lining up with the bottom of the shock body with no clearance issues other than the roost rubbing the resi mount. This would not be a problem if I moved the mount up high, but the OCD in me didn't want to scar up the Fox emblems lol.
  20. Oct 26, 2017 at 6:40 AM
    #160
    Chase8059
    Chase
    ESVA
    There is no way in hell my resi's would line up with the bottom of the shock body AND not kink my lines. I'm maybe 1.5 inches below the shock body and maybe 4 - 5 inches above the axle.
