Fox 2.0 IFP & Coilovers Ride Quality?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crocodile_cole, Jul 8, 2019.
  1. Jul 8, 2019 at 12:33 PM
    crocodile_cole
    crocodile_cole [OP] Active Member
    Cole
    2017 White TRD Off Road
    Sterling_vH111 likes this.
  2. Jul 25, 2019 at 4:14 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    X 2. Only I'm a 2 Gen and running billies 5100 with OME.
  3. Jul 25, 2019 at 4:19 PM
    Taco1997
    Taco1997 Well-Known Member
    SoCal
    2001 Tacoma prerunner, 2024 Tacoma TRD Offroad
    I’m putting my Fox IFP’s on this weekend. My 1st gen suspension is beyond worn. My dad has a 3rd gen I’ll let you know how the ride quality compares
  4. Jul 25, 2019 at 4:22 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I had the Fox 2.0 coil overs up front and the 2.0’s performance series on the rear.
    I’d definitely recommend them if the truck sees mostly pavement or only a little offroad.
    The coils come preset at about 1.5-2” of lift, and on my truck we’re just as good ride quality as oem. Slightly stiffer due to increased spring rate, but much better than 5100’s with preloaded oem coils or a spacer.
    With the rear, the calving matches the front coils well, but I would go with an add a leaf in stead of a block. Not much more expensive, and much better quality and safety.
    I liked them so much when I had them on my Tacoma, I didn’t consider any others when my father wanted to lift his Tundra, with the same goals in mind.
    tacoma guy and Taco1997 like this.
  5. Jul 26, 2019 at 5:11 AM
    tacoma guy
    Joe
    Phoenix Az.
    Are the fronts hard to adjust if need be after installed ?
  6. Jul 26, 2019 at 9:07 AM
    Sterling_vH111
    Sterling
    socal
    There’s a lock screw on each collar and then you may need a spanner wrench for 2.0 shocks.
    Also unlike some other coil overs, you need to compress the spring to adjust the preload collar. I did it with some exterior spring compressors rented from autozone, or a shop can do it with a wall spring compressor.
    I turned it by hand once the spring was compressed, just make sure the threads are clean around the collar.
  7. Jul 26, 2019 at 6:48 PM
    tacoma guy
    Joe
    Phoenix Az.
    I gotta ya. Yeah I see what your saying. Thanks for the reply!
  8. Jul 26, 2019 at 6:55 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    All coil overs you will need to take the pressure off the spring to adjust by hand. You can do this by jacking up the vehicle from the frame, depending on the coil over design, simply rotating the spring is enough. Or use the right tool and not bother Jacking / compressing.
