Fox 2.0 setup for mild lift and light offroading?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nickrick78, Sep 18, 2019.
  1. Sep 20, 2019 at 5:02 AM
    #81
    Black taco.
    Black taco. Well-Known Member
    4x4. MT.
    im not stating this as fact, but I read that the 2.0's are aluminum where as the 2.5's are not and will eventually rust.
    again, really love to hear from people who have knowledge/experience with these particular shocks.
  2. Sep 20, 2019 at 5:31 AM
    #82
    nickrick78
    nickrick78 [OP] Well-Known Member
    Nick
    Pittsburgh PA
    Tacoless for now
    Well crap. I only want to go up 1.5" in the front and 1" in the rear. I was going off Fox's website and figured I was in the correct lift range. Should I switch my order to the 117??
  3. Sep 20, 2019 at 5:43 AM
    #83
    S14swap240sx
    S14swap240sx Well-Known Member
    Jon
    15 TRD OR
    These shocks are totally rebuildable.. you can get new bodies from Fox cheap. I simply don’t need the extra shock/expense with the 2.5 option. I’m hoping to hit that 1.5/2” lift so the 117 fits perfect for my goals. Since my wife wants to use the truck for camping I did the adjustable rear to tighten up the rear dampening when we have the Tacoma loaded up.
    For me I’m not sure if I’m going with a custom leaf pack or icon rtx yet.
    For what it’s worth you should be hitting these with fluid film, so the aluminum vs steel isn’t a big deal, but if your planning for some high speed wheeling which will really work the suspension, go 2.5. If cost wasn’t an issue, I would have gone 2.5 but in the end I want an oem+ set up nothing too over done.
  4. Sep 20, 2019 at 5:44 AM
    #84
    S14swap240sx
    Jon
    15 TRD OR
    Yeah I would, because your in between the two lift ranges, and that extremely detailed post by head strong I would 100% go 117
    strongrob likes this.
  5. Sep 20, 2019 at 6:13 AM
    #85
    nickrick78
    Nick
    Pittsburgh PA
    Tacoless for now
    Fox's website says 116 for 0-1.5" of lift, 117 for 2-3" of lift. I realize they may be miscategorizing them, but would there be any possible harm in running the 117 with only 1" rear lift? Bottoming out?
  6. Sep 20, 2019 at 6:57 AM
    #86
    S14swap240sx
    Jon
    15 TRD OR
    Check post 80, black taco quoted headstrong who put a very nice review up on the 117 compared to the 116. Regardless it seems like bump stops are a good idea, but I wouldn’t worry until you really start pushing the truck on trails. For regular driving and light Offroad/Trail use these shocks wouldnt know the difference anytime soon.
  7. Sep 20, 2019 at 6:57 AM
    #87
    ToyoVL
    ToyoVL Well-Known Member
    I'll do 2.5 IFP front for $800 and rear 2.5 for $500. It's a steal for either 2.0 or 2.5 set. Thanks OP for coupon code.
    S14swap240sx likes this.
  8. Sep 20, 2019 at 7:31 AM
    #88
    S14swap240sx
    Jon
    15 TRD OR
    My issue with the 2.5 is id want the extended and then that means UCA’s
  9. Sep 20, 2019 at 7:33 AM
    #89
    nickrick78
    Nick
    Pittsburgh PA
    Tacoless for now
    I think I'll switch the order to the 117s, especially when comparing the 116s to stock replacement shocks and the travel is less. Thanks for the input.
    Black taco. likes this.
  10. Sep 20, 2019 at 8:16 AM
    #90
    kobra357
    kobra357 Member
    2016 TRD Off Road
    I don't want too much more of a lift. I think I will get an AAL. And call it good with the FOX shocks I ordered. Unless someone can tell me anything different. thanks.
  11. Sep 20, 2019 at 8:47 AM
    #91
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    You don’t need UCA’s to rub the 2.5’s. The only reason for UCA’s is if you’re lifting over two and a half inches so you can keep your alignment in spec.
  12. Sep 20, 2019 at 8:48 AM
    #92
    Unitedgrey
    Unitedgrey Well-Known Member
    Just ordered the -117's for the rear and the 2.0's for the front for under $1k plus 3 cabin air filters. Since winter is coming in I might just wait and buy the Icon leaf pack and get the install done in the spring along with the diff. bearing.
  13. Sep 20, 2019 at 9:08 AM
    #93
    S14swap240sx
    Jon
    15 TRD OR
    With the standard ones, with extended you need the UCA’s for the extra travel if not your missing out on all the extra fun you paid for
    Got a shipping confirmation!!! For the cabin filter...
    For my 3 items I needed I did:
    Cabin filter
    Rugged ridge d ring 3/4 with the plastic things
    And a tow rope from rugged
    The reviews are whatever but it’s better then a ton of air filters. In 15 years and tons of builds never replaced one of those! Maybe I been missing out
  14. Sep 20, 2019 at 10:22 AM
    #94
    Draftpick
    Draftpick Member
    2019 SR5 DCSB 4x4
    Codes don’t work anymore, congrats to all that were able to take advantage on this great deal
    Skydvrr and El Chivo Norteño like this.
  15. Sep 20, 2019 at 10:23 AM
    #95
    dblase
    dblase Well-Known Member
    2017 Tacoma
    Anyone received there order yet? i'm about to place my order for the fox 2.0 coilovers shocks and 2.0 rears.
  16. Sep 20, 2019 at 10:23 AM
    #96
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    delv date for me is the 26th so ill be waiting awhile
  17. Sep 20, 2019 at 10:28 AM
    #97
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    I'm sure they lost a grip of loot with a bunch of us using these codes. Thanks OP for the heads up on this insane deal!!!
  18. Sep 20, 2019 at 10:31 AM
    #98
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    Poll on the ODDS of them actually fulfilling the orders with $500 off?
    I ended up changing my order and ordering a set of FOX 2.5's front and rear. $1000 off total
    $1399+$999= $2398- $1000 off= $1398 with no tax and free shipping?
    There is no way why are going to take that loss.
    S14swap240sx and Skydvrr like this.
  19. Sep 20, 2019 at 10:31 AM
    #99
    Sungod
    Sungod Well-Known Member
    St Augustine
    I got confirmation that my 3 air filters shipped, but nothing else. o_O
    Did your order ship complete?
  20. Sep 20, 2019 at 10:31 AM
    #100
    dblase
    2017 Tacoma
    SOB! i should have ordered my shit yesterday! $#*@
