Fox 2.0 - taco lean spacer or no?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by strobe, Apr 12, 2022.
  1. Apr 12, 2022 at 6:27 AM
    strobe
    strobe [OP] Member
    Justin
    3rd gen Sport MT
    Hey TW, I have a fox 2.0 kit en route and should be installing by early next week (20' 4x4 sport). With all of the talk on the driver side lean, I'm debating on if I should order a 1/4" spacer to throw in. I know these are adjustable, but adjusting the collar on one would mean different pre-load on both sides which is not ideal. Have also read people saying once you go with a stiffer aftermarket setup the lean isn't nearly as bad as with factory suspension.
    Thoughts?
