Fox 2.5 coilover Resi adjust to 3in lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by FBGW01, Jun 5, 2012.
  1. Jun 5, 2012 at 11:13 PM
    FBGW01
    FBGW01 [OP] Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    so i installed my fox's and idk how much the top collar on the spring needs to be tightened so im at 3in of lift(max lift) im running 1in uniball ucas so thats covered. i do need a spanner wrench but when i get a hold of one, i would like to know how much to crank them so im at 3in:D anyone know about this?:confused:
  2. Jun 5, 2012 at 11:24 PM
    tsfenrir
    tsfenrir Well-Known Member
    Travis
    MIlton, FL (Lower Alabama)
    TRD Pro Cavalry Blue
    Might be getting too old for this.
    I just had mine rebuilt and adjusted a month ago. The guy told me that about every 1/4" of threads is about 1/2" of lift, so about a 2:1 ratio. Now every truck sits slightly different and unless you took before and after measurements, it may be a little difficult to determine how much of a lift you got. My driver side is cranked significantly higher than passenger. I placed a level on my hood in even terrain to get as accurate as possible. Hope this helps.
  3. Jun 5, 2012 at 11:37 PM
    tsfenrir
    Travis
    Just noticed you posted in 1st Gen. I do not know if what I suggested still applies, mine is for 2nd Gen. My apologies.
  4. Jun 5, 2012 at 11:41 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    Thankyou:D and no worries about the whole 2nd gen thing, some help is better then none:) thankyou
  5. Jun 6, 2012 at 12:15 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea..just crank until your happy really..Just keep an eye on your CV axles angle and you'll be fine.
  6. Jun 6, 2012 at 12:39 AM
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    Typically you would measure your before height for comparison. ( ie. hub to bottom of fender) also that 1/4" = 1/2" of lift is a rough estimate and is not necessarily fact for every brand of shock. I have the exact same setup you're running except I chose to be at 2 3/4" lift because I felt it rode smoother at that level. My measurement is 38 3/4" from ground to top of fender running 285/75/16 at 40 psi. You should be roughly at 39" depending on tire size and all the other factors you may have. G/L mine is 2nd gen though.
  7. Jun 6, 2012 at 9:09 AM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    no CV axles:anonymous: ha wish i did at times though:eek:
  8. Jun 6, 2012 at 9:13 AM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    thankyou:) i run 265/75/r16 so that could play a height factor too. and bein a first gen in all
  9. Jun 6, 2012 at 9:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Get another stock 1st Gen to give you measurements from the center of the hub to the fender and start with that. That would take tire size out of the equation.
  10. Jun 6, 2012 at 9:30 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Judging by the pic in your gallery, you already have a rear lift? If so, simply crank the front coilovers until you sit level (as determined by fender height measurement).
    If you want to be accurate with the measurement, park on a level surface with half a tank of fuel. Make sure the tire pressures are correct. Temporarily disconnect the sway bar (it would otherwise mask some side-to-side lean).
  11. Jun 6, 2012 at 4:40 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    ya the orignal lift had me like 4 in high in the back! hah i dumped two leafs out per pack and had alot of wieght in the back. i only got like 200lbs of sand and my spare tire in the back. so it brought the back down a little. i bought a spanner wrench today, but its a bitch tryig to torque the ring on top of the coil with the shock installed. i got a bit of cali/bro lean now:D but it almost looks level. driver side is an inch shorter then passenger to:mad: but its because it was like that b4 the shocks and still needs to be cranked up more
  12. Jun 6, 2012 at 5:36 PM
    KenLyns
    Belly of the Beast
    LOL, so the "Taco lean" affects 1st Gens too.
  13. Jun 6, 2012 at 11:47 PM
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    Ya that damm taco lean!:annoyed: haha the whole passenger side sits a little higher! but ill fix that tomorow morning.
