Fox 2.5 Coilovers...Looking For Recommendations...UCA & Bump Stops!!!!!!!!!!!!!
Discussion in 'Suspension' started by NorsemanAK, Jul 10, 2021.
  1. Jul 10, 2021 at 9:29 AM
    NorsemanAK
    NorsemanAK [OP] Member
    2013 Dblcb trd off road
    Hey everyone I have a 2013 DBCB TRD OF with Fox 2.5 coilover fronts and 2.0 rears w/AAL. Needing to upgrade UCA's to get alignment back into spec. I'm running Toyo A/T 265-75-16. When installed coilovers and had alignment done, the mechanic said the castor/camber was maxed out and wasn't much he could do. Did say it wouldn't hurt the tires but it does pull hard right. Looking into new UCA's and have been reading good things about Dirt Kings, but wasn't sure what exactly I should be looking for to increase the allowable adjustments for castor/camber.
    Also, need new bump stops and was curious what anyone would recommend...any help/info is appreciated!!!
    Pics are also always helpful!
  2. Jul 10, 2021 at 9:35 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    U gotta get SPC uca’s. They’re the best for alignments. Also I went with super bumps front & back
  3. Jul 10, 2021 at 9:37 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I run JBA UCA's and have had great luck with them.
    skigan and Kolter45 like this.
  4. Jul 10, 2021 at 9:58 AM
    su.b.rat
    su.b.rat broken truck
    another recommendation for SPCs due to their flexibility with alignment. however, be sure they are setup for alignment after install by someone who has done SPCs before or can read & follow instructions carefully. they must be setup properly before a final alignment or it'll be a mess.
    TVH475 likes this.
  5. Jul 10, 2021 at 10:10 AM
    NorsemanAK
    I did look at the SPC's...would you recommend the uniball? Also, Was just reading up on total chaos UCA's...seem expensive to me...are they worth the $?
  6. Jul 10, 2021 at 10:21 AM
    NorsemanAK
    do u have any pics of ur bump stop setup? does the mount come with the bump stops, or is it a separate item to purchase?
  7. Jul 10, 2021 at 10:23 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    You almost can’t go wrong with any of the options on the market. They all have pro’s and con’s. Fixed upper control arms with uniballs are best suited for heavy off-road use and arms with a more traditional ball joint are typically better suited for daily drivers. Depending upon where you live and how often you clean and take care of them uniballs can last a year or 10. In the pnw uniballs, sperical and heim joints seem to have a limited life. With all the rain and road debris it’s hard to keep up with routine maintenance. At the automotive shop I work at we pull more sperical joints off than we put on and they are usually replaced with a poly or delrin option. Spc’s are great for mixed use but in heavy wheeling the upper ball joint can slip and cause camber changes. I recently had this happen to me and while the change was fairly small it is something to be aware of.
    Kolter45 and NorsemanAK[OP] like this.
  8. Jul 10, 2021 at 10:29 AM
    BankrupTaco
    BankrupTaco Well-Known Member
    2021 Tundra SR5 4x4
    I ran SPCs on my taco. Definitely recommend them due to the adjustability options.
  9. Jul 10, 2021 at 10:40 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    SPC calls for 150 ft/lbs on the top nut. I had the same thing happen with it slipping about 1/8" when I first installed them 4 years ago. Since then I just put a 2' breaker bar on it and crank it down hard. I wheel a lot and it hasn't slipped at all since then. I also got really tired of the stock alignment cams slipping every wheeling trip so got rid of those and went with a cam eliminator kit. That was 2 years ago and I haven't had to visit an alignment shop since.
    With the eliminate kit and the SPC"s I was able to get my alignment exactly where I want it on my 97 4Runner. The fact you can adjust castor as well as camber via the SPC's really makes them better then anything else on the market as far as adjustments go.
    Kolter45 and 71tattooguy like this.
  10. Jul 10, 2021 at 10:42 AM
    Kolter45
    Denver, CO
    Rear superbumps go under your ubolts. You can see them here. It replaces those shitty pyramids stops
    The front super bumps just replace your oem ones too. It’s right under the red brake line. It mounts above the lca
    not the best pics but I can take some more after work this evening
    71tattooguy and NorsemanAK[OP] like this.
  11. Jul 10, 2021 at 10:43 AM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I accidentally jumped the truck out on the sand dunes and it shifted. Only time I’ve had it happen. I usually torque them to 150 while doing the alignment and then give it a good extra twist once I’m done adjusting.
  12. Jul 10, 2021 at 10:50 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
  13. Jul 10, 2021 at 11:58 AM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    For bumpstops I run timbrens on the rears and wheelers super bumps on the fronts. I have ran the wheelers for 140k miles and the timbrens for 100k and they've been amazing through all the moderate wheeling, towing, and daily driving. They're trouble and worry free.
    I like the timbrens enough to put them on my full size tow rig to help when I'm loaded pretty heavy.
    Timbren-Industries and Kolter45 like this.
  14. Jul 11, 2021 at 7:03 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  15. Jul 11, 2021 at 7:15 AM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    I have had SPC's for a while now and they work like a champ at getting that alignment in check. I have no problems with them and I like them a lot. However, because I like form AND function I ordered these:
    https://afepower.com/afe-power-460-72t001-g-afe-control-upper-control-arms
    I won't be installing them until late September when I have all sorts of the other suspension fun things arriving.
    Anyway they look solid and have very similar adjustment capability as the SPC's. I also think they look better than the SPC's and not being cast, they are less prone to a nasty break for those of you who get up in the crawlin-rocks!
    EDIT - I ordered these on July 6th for $768 - now they're priced at $921? SPC's definitely a little chapter than that.
    71tattooguy likes this.
  16. Jul 19, 2021 at 5:01 AM
    Coconutman7
    Coconutman7 Well-Known Member
    Southeast
    09 TRD Sport DCLB
    I've got SPCs and really like how easy it is to adjust my alignment myself. Clean and functional and I've also never had issues with the top nut slipping.
