Fox 2.5 Coilovers question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FloTaco, Mar 9, 2015.
  1. Mar 9, 2015 at 9:24 AM
    FloTaco
    FloTaco [OP] Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    I've searched the forum extensively for an answer. Is any one running the Fox 2.5 Coilovers set at a full 3" of lift? If so how do they ride?
  2. Mar 9, 2015 at 9:25 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    It'll be stiff since you are preloading them a lot. Why do you want a full 3" of lift up front? To fit 285's you only need about 2.5"
  3. Mar 9, 2015 at 10:46 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    Just because I want a close to level set up with the All Pro leafs I have. If I can clear without rubbing the frame I'll set them lower.
  4. Mar 9, 2015 at 10:48 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yes you can do it but it'll be a stiffer ride. You'll clear the frame at 2.5". I don't have experience with them cranked up that high though.
  5. Mar 9, 2015 at 1:46 PM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    Thank you
  6. Mar 9, 2015 at 2:22 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    I have the 2.5" w/ reserviors. I believe my drivers side is 2.75" high (might have settled a little more) and passenger right at 3", might adjust that 1 down to match. Other than the front cv vibrating from 30-45 mph and having to replace the bushing (on the way from ECGS as I write this). At least I hope that fixes the problem. I think it rides better than stock over the last 2-300 miles since install. My wife hasn't complained. I replaced the rear springs with dakars and am still waiting on a mix matched rear shock set. Got 1 new and 1 old. The rear definitely bucks over the bumps, night and day difference to the front.
  7. Mar 9, 2015 at 2:48 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Ohh yeahhh I forgot that your CV angles will be bad, you'll tear your boots real quick like I did and mine are set at 2.5"..
    Your dakars will smooth out, honestly its taken mine about 3000 miles with some weight in the back to smooth out but they will, the ride was bad at first for me too
  8. Mar 9, 2015 at 3:55 PM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    I've had my current lift set at 3" for 17k miles with no torn boots. I have however, started to hear binding from my drivers side which I'm guessing is an LBJ or tie rod. Not really a big deal, just means they are at their travel limit I suppose.
  9. Mar 9, 2015 at 4:03 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    cv boot mod will prolong your cv's life alot. I'm running ~3 inches of lift maybe a touch more.. If you hear binding in the drivers side FloTaco I recommend checking to make sure your LCA's are torqued to the 100# spec as alligment shops tend to think snug is enough and then its common for people to hear binding (LCA bushing shifting around is the noise) especially when turning and backing up.
