Fox 2.5" IFP
Discussion in 'Downsouth Motorsports' started by Downsouth Motorsports, Feb 22, 2012.
  1. Sep 15, 2012 at 9:39 AM
    TNRunner
    TNRunner Blah,blah,blah...
    TN
    2003 4Runner V8 LTD
    DeMello front bumper, DeMello sliders, Toytec coil overs with Billy 5100's, ICON 2.0 Rear shocks, ICON rear springs, Lightforce 170's, Spidertrax spacers, Rola roof rack, Cobra 19, ATO Skids, ARB front and rear, 4.88 Nitro's, XRC Competition winch, Flowmaster 70 series, custom rear bumper,DSM UCA's.
    I'm trying to find the specs for these shocks. I need the collapsed and extended lengths. You have those numbers?:pray:
  2. Sep 15, 2012 at 11:27 AM
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    These are old #'s:
    22.54" Extended
    17.58" Collapsed
    These are the old #'s from the 880-02-418
    same shock but with a Res.
    Possibly could help...
  3. Sep 15, 2012 at 7:14 PM
    TNRunner
    TN
    2003 4Runner V8 LTD
    Thx.
  4. Sep 17, 2012 at 8:26 PM
    TNRunner
    TN
    2003 4Runner V8 LTD
    I'd like to order a set. What's the timeframe?
  5. Sep 18, 2012 at 6:54 AM
    2-3 weeks maybe 4 at the moment..
    Hoping to have them sooner..
  6. Jan 4, 2013 at 7:21 AM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    2010 double cab tacoma TRDoffroad SR5 V6 4x4
    what do these come set at? 0-3?
  7. Jan 4, 2013 at 7:38 AM
    Normally the Fox shocks will get set at around 2" of ride height adjustment out of the Box..Give or take a 1/4" up or down...
  8. Jan 4, 2013 at 10:10 AM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    Thanks
  9. Jan 31, 2013 at 3:53 PM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    Where do you measure from on these to get the right hight setting?
    And how do you turn the bottom part so everything will line up for install?
  10. Jan 31, 2013 at 7:47 PM
    Good evening,
    These shocks will come normally set out of the box at 2" of ride height change.4 to 5 turns will get you about an 1" more in ride height.
    You are adding pre-load to the spring to add ride height.
    Just be careful because the more you crank up a coil over the more you will start to loose the ride quality due to the added pre-load and you are taking away the droop travel.
    You can rotate that rod end, its just a bitch because of the spring pressure that is on the spring plate which sits on that rod end..
    Bar careful rotating it that you do not loosen the rod end.
    Hope this helps...
  11. Feb 1, 2013 at 6:55 AM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    thanks I didn't want to try to turn anything that would mess something up on these things and was trying pre set at about 2 1/2" of lift before I install them with hopes of less adjustment after they are installed
  12. Feb 1, 2013 at 8:15 AM
    I would add about 3 turns to each one prior to installation.
    The easiest way is to put the shock in a wall mounted spring compressor and take the load off of the pre-load nut and adjust it that way with no pressure on the nut.
    Be very careful doing it this way...
  13. Feb 1, 2013 at 9:17 AM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    will do thanks
