Fox 2.5 missing locking ring?
Discussion in 'Suspension' started by MESO, Apr 13, 2016.
  1. Apr 13, 2016 at 10:23 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Just installed my 2.5 front coilovers,went to adjust and realized it is missing the top locking ring above the preload ring. Did Fox forget to install it? Am I crazy? BTW how do you
    crank these things up? I have the Fox coilover tool but still wouldn't budge.
  2. Apr 13, 2016 at 10:24 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I don't think it needs one...it has a bolt
    RelentlessFab likes this.
  3. Apr 13, 2016 at 10:26 PM
    MESO
    State of Jefferson
    ya, I saw the allen bolt. Even loosened it up and still super hard to turn.
  4. Apr 14, 2016 at 5:27 AM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
  5. Apr 14, 2016 at 7:05 AM
    MESO
    State of Jefferson
    Well that's retarded if true. REMOVE Entire coilover just to adjust then reinstall??o_O
    I'll call Fox tech later and get the run down.
  6. Apr 14, 2016 at 7:12 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Sub'd to see what they tell you.
    It seems like jacking up the truck and removing the load is all that would be needed. How the heck can you know where to set the ring until you install them on your truck with your configuration?
    BTW, to the original question, I have a set of 2.5" I got about a month or so ago that are sitting waiting for a few small pieces to install. They have two lock rings, so looks like you're missing the small one. I'd guess you need it otherwise Fox wouldn't put them there. My assumption is it's to spread the force onto more threads now that the bodies are aluminum. No reason to know that for sure, just assuming. It might also just be a backup lock ring.
  7. Apr 14, 2016 at 10:23 AM
    MESO
    State of Jefferson
    Okay.... just off the phone with off-road tech @ Fox.
    1)The new 2.5 IFP coilovers have only 1 ring for adjustment. No locking ring anymore. The proload ring has the holes for spanner wrench and a allen bolt that pinches it tight to hold it there after adjustment
    2)Preload must be taken off the spring in order to turn the adjustment ring. AKA Remove coilover and spring compress or try while bolted in the vehicle. FAIL:frusty::frusty:
    BTW. I got 2.5" Right out of the box. 1" from factory(it's a 3rd gen) and 1.5" after lift. Tech said 4 Full roatations will get me another .5"
    Off to find a spring compressor....
  8. Apr 14, 2016 at 10:26 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    they told you to spring compress the spring before adjusting preload? Thats odd, you sure they didnt mean let it free hang and adjust down from there with the weight off?
    phx13 likes this.
  9. Apr 14, 2016 at 10:28 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Dang, seriously? The coil over has to be removed to be adjusted? That was a big reason I dropped the coin, so that I didn't have to do much work to fix the squat each time I progress as I add a second battery then bumper and then winch. It's not much different now than just bumping up OME springs each time.
    LTDSC likes this.
  10. Apr 14, 2016 at 10:30 AM
    MESO
    State of Jefferson
    Not completely disassembled, just taking the load off spring. They way he explained it put it in a spring comrpessor, or use one of these to push the spring down.
  11. Apr 14, 2016 at 10:32 AM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    Return it and go buy Icon's or Kings'.
    RelentlessFab, LTDSC and DaveInDenver like this.
  12. Apr 14, 2016 at 10:36 AM
    MESO
    State of Jefferson
    I'll deal with it.(Had I known going in...would have went different route)and they are now used/installed. Plus, I got them with 22%off @ AutoAnything. Just hope I don't have to make multiple adjustments. Set it and Forget it.
  13. Apr 14, 2016 at 10:38 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    What a PITA having to use spring compressors. I hate those things. Although I wonder how much load has to be taken off, maybe it's not as bad (or dangerous) as actually putting together coil overs. Have to let this digest, but I would have gone a different way if I'd known, too.
  14. Apr 14, 2016 at 10:42 AM
    MESO
    State of Jefferson
    Only way is to take tension off the spring. Tech support said if you try and adjust ring without removing tension it can strip the thread on the coilover body.
  15. Apr 14, 2016 at 10:45 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    10/10 would tell Fox to get bent. Thats ridiculous.
  16. Apr 14, 2016 at 10:48 AM
    1MK
    1MK Desert Explorer
    Southern California
    One of the reasons I went to Icon, as well as the STUPID AS F$*! nitrogen fill setup.
  17. Apr 14, 2016 at 10:52 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You know, this aluminum body change is a pain but OTOH if they were still steel and rusting we'd be complaining about that, too. :)
    YotaDan likes this.
  18. Apr 14, 2016 at 10:56 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You just need to jack the vehicle up off the ground, then spray the threads down with some lube, and use a little elbow grease to adjust the collar. Set the vehicle down and roll it forward and back a few feet to settle the suspension, re-take measurements and then adjust again if needed.
    snox31, 61ragtop, Lord Helmet and 2 others like this.
  19. Apr 14, 2016 at 10:57 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I would suggest a can of the MavCoat. Even the Aluminum can have corrosion issues.
  20. Apr 14, 2016 at 11:03 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    This is the process I expected, but does it jive (warranty-wise would be my main question) with what @mesojdm was told by Fox?
