Fox 2.5 preload bias left / right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badger, Jan 3, 2017.
  1. Jan 3, 2017 at 2:45 PM
    badger
    badger [OP] Well-Known Member
    07 SR5
    I am looking to get some numbers from other owners about the preload difference between the right and left side shocks with the standard 600 pound 13" spring. I'm talking about measuring the thread above the adjuster collar on both sides. I expect a small difference, with the left measurement being bigger, but my new set seems too far off. My old set was only different by about 1/4". That makes sense given the left side weight bias. My new set is different by 3/4". That should be around 450 pounds of offset. I think I got a weak spring. The spring on the right (passenger side) has the same preload as the one I took off. The drivers side is squeezed a 1/2 more than my old set.
  2. Jan 3, 2017 at 2:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you also have to take into consideration that where the shock is mounted the tire has ~ a 2x advantage on the shock. so that LB figure is cut in half. 55ish lbs for battery + ~ 140 lbs for gas..... its close.
    If you think you got a weak spring, flip sides.
  3. Jan 3, 2017 at 5:45 PM
    badger
    07 SR5
    I know, but it still doesn't pencil out. Some of the weight is shared by the front and rear, so it is actually pretty close to actual numbers.
  4. Jan 3, 2017 at 7:34 PM
    nd4spdbh
    SoCal
    true you are correct. Like stated, maybe swap springs from left to right?
  5. Jan 3, 2017 at 7:45 PM
    badger
    07 SR5
    I could, yes, but getting them off is a bugger :). It would be easier to switch the entire coilover, but they are specific left and right. I have another spring coming, so I will just replace it.
  6. Jan 3, 2017 at 7:52 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Another factor that may not be figured into your math is torque induced by the swaybar if it is still connected. Only then would you have true independent suspension acting on each wheel.
  7. Jan 4, 2017 at 6:05 AM
    badger
    07 SR5
    true, sway bar is removed
    zippsub9[QUOTED] likes this.
