NO LONGER FOR SALE Fox 2.5 Remote Reservoir Coilovers for 2005-2014 Tacoma
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ronnie4X4, Jan 16, 2016.
  1. Jan 16, 2016 at 5:40 PM
    ronnie4X4
    ronnie4X4 [OP] Well-Known Member
    Ronnie
    2014 Black Tacoma TRD
    Upgraded sound system
    NO LONGER FOR SALE.
    After much consideration, I've decided to sell my Fox 2.5 coilovers. I didn't have them on for very long before I decided to switch back to my stock struts with a spacer lift. Personally, I prefer the way the stock struts ride.
    These coilovers are for a 6 inch lift. They have low mileage and minimal wear. A set goes for $1600 brand new but I'll let them go for $1100 with free shipping to the lower 48 states.
    More info on these coilovers here:
    http://www.trucktoyzstore.com/realm/pc/viewPrd.asp?idproduct=3816
    808tako likes this.
  2. Jan 20, 2016 at 7:00 PM
    ronnie4X4
    Ronnie
  3. Jan 20, 2016 at 7:01 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    six inch lift? holee molee
    Justinlhc likes this.
  4. Feb 1, 2016 at 6:44 PM
    808tako
    808tako Active Member
    06 tacoma
    How much to ship to Hawaii ?
  5. Feb 2, 2016 at 8:21 PM
    ronnie4X4
    Ronnie
    What's your Hawaii Zip Code?
  6. Feb 2, 2016 at 8:37 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    These are for 6" drop bracket lifts, correct? They don't actually produce a 6" lift, but are to be used WITH a 6" lift, right?
  7. Feb 2, 2016 at 9:34 PM
    808tako
    06 tacoma
    96793
  8. Feb 3, 2016 at 7:58 AM
    ronnie4X4
    Ronnie
    Correct, these are for 6" drop bracket lifts. They'd be a great upgrade for a 6" DB lift kit that came with strut spacers. You'd be able to ditch the spacers and struts.
    Alternatively, you could buy something like this and use the coilovers instead of the spacers.
  9. Feb 3, 2016 at 8:01 AM
    ronnie4X4
    Ronnie
    808tako, I can't find anyone who's willing to ship to your zip code from my area. You could try your luck, I'm in 59802. Let me know if you find a shipper.
  10. Feb 3, 2016 at 12:31 PM
    htowntaco23
    htowntaco23 Well-Known Member
    Matthew
    Austin, TX
    07 PreRunner SR5
    Carr side steps, Flowmaster 40 series dual exhaust, Spyder projector headlights, black housing LED taillights, 2 10' JL Audio subs, Polk amp, Famous Fabrication hood mount brackets, 2 Rigid Industries Dually LEDs
    Why do you prefer the way the stock struts ride?
  11. Feb 3, 2016 at 1:15 PM
    ronnie4X4
    Ronnie
    The coilovers were too stiff for my tastes. With the stock struts, the handling and offroad performance isn't as good but the comfort of the ride is better in my opinion.
  12. Feb 3, 2016 at 2:54 PM
    808tako
    06 tacoma
    I can look just need box dimensions and weight to get quote
  13. Feb 4, 2016 at 11:10 AM
    htowntaco23
    Matthew
    Austin, TX
    07 PreRunner SR5
    Will these coilovers work if you don't have a DB lift?
  14. Feb 10, 2016 at 8:36 AM
    ronnie4X4
    Ronnie
    I doubt it. You could potentially adjust the preload to shorten the amount of lift to 3.5" which might go good with an extended/long travel kit. I don't know of any 6" kits that aren't DB kits.
  15. Feb 10, 2016 at 8:37 AM
    ronnie4X4
    Ronnie
    Sorry for the delay, I'll get you those specs tonight when I get home from work.
  16. Feb 10, 2016 at 8:43 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    How rough do they ride?
  17. Feb 11, 2016 at 2:09 PM
    ronnie4X4
    Ronnie
    Rougher than my liking. I can feel small bumps considerably more with the coilovers than I can with the struts.
  18. Feb 11, 2016 at 5:41 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    I have these on my BDS kit and love em. They can take a beating for sure and ride way better than stock. I love mine but also wanna sell them.
  19. Feb 11, 2016 at 6:27 PM
    ronnie4X4
    Ronnie
    Sorry it took so long. I have the dimensions and weight. The box is 10.5" 20.5" x 31" and weighs about 70 lbs.
  20. Feb 11, 2016 at 6:49 PM
    808tako
    06 tacoma
    Thanks I'll start looking
