Fox 2.5 Resi Coilovers and 2.0 Pro Series Piggyback Rears
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by MGMGRAND, Dec 5, 2011.
  1. Dec 5, 2011 at 5:34 PM
    MGMGRAND
    MGMGRAND [OP] Well-Known Member
    WPB, FL
    PreRunner TRD Sport
    SOLD
    I bought these, used, from a local 4x4 shop and was told they were for an 05+.
    **I have been assured that they were on a 2nd Gen Tacoma. However the rears would need a Top Mount Converter to work on a 2nd Gen so I guess you could say they would work on any Tacoma. As such I will sell the them in sets of 2.
    I have 2 sets of Fronts and 2 sets of Rears.
    1st Set of Fronts: $800**Sold**
    2nd Set of Fronts: $750 (Missing part of one mount, pictured below in post #8)**Sold**
    1st Set of Rears: $250 **Sold**
    2nd Set of Rears: $200 (Missing one bushing, pictured below in post #8)**Sold**
    **I will pay the Shipping**
    Feel free to post or PM any questions.
  2. Dec 5, 2011 at 5:43 PM
    tacomacntry
    tacomacntry Joe's Auto Detail
    North East Florida
    Blacked out SR5 4x4
    K&N Cold air Cat back custom dual exhaust
    if so for a first gen..how much for just the rear shocks? or are you not parting...and the lengths and valving?
  3. Dec 5, 2011 at 5:44 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    whats wrong with the set that has the conditions
  4. Dec 5, 2011 at 6:12 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Those are second gen coilovers and rear shocks.
  5. Dec 5, 2011 at 6:20 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    the rears are for 1st gen unless you get the mount to put them on a second gen. the 2nd gens have the post on the upper
  6. Dec 5, 2011 at 6:21 PM
    double dee
    double dee Well-Known Member
    Phoenix
    2016 Tacoma 4x4
    if your willing to separate how much for the fronts only?
  7. Dec 5, 2011 at 11:48 PM
    MGMGRAND
    WPB, FL
    PreRunner TRD Sport
    If anyone can tell me a way for me to tell whether the fronts are 1st or 2nd gen let me know...I think the rears have the 1st gen top mounts as stated above.
    As for the condition issue with the 2nd set, it appears that a bushing on one rear is missing and one of the bottom mounts on one of the fronts was damaged when removing them. I'll post pics when I get home of what I'm talking about. Not serious but it will probably take a couple parts to fix.
    More specs to be added when I get home.
  8. Dec 6, 2011 at 3:48 AM
    MGMGRAND
    WPB, FL
    PreRunner TRD Sport
    As for valving fronts say 30/75, rears say 30/80.
    Rears are 24.5" extended and 16" compressed, measured from center of mounting point to center of mounting point.
    Pics of issues with second set:
    Missing rubber bushing. Has been gnarled up but it shouldn't affect functionality.
    Hard to tell but its missing part of the metal sleeve.
  9. Dec 6, 2011 at 10:42 AM
    Anthony250
    Anthony
    San Gabriel Ca
    It is missing the Hiem Spacers, They Cost $5 bucks each. And Yes those coilovers are second gen becuase they have the longer lower rod end, search peoples first gen coilovers and you can see the lower rod end is shorter. As for the rears i was wrong they are 1st gen..
  10. Dec 6, 2011 at 2:09 PM
    MGMGRAND
    WPB, FL
    PreRunner TRD Sport
    Thanks Anthony250
    Original Post Edited
  11. Dec 6, 2011 at 2:11 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    if this does happen what would you charge if i bout the rears
  12. Dec 6, 2011 at 2:20 PM
    MGMGRAND
    WPB, FL
    PreRunner TRD Sport
    I posted new prices at the top.
  13. Dec 6, 2011 at 2:22 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    I might be interested in a set of rears also if you seperate.
    *edit* Hate to be a nag but do you know the extended/compressed measurements?
  14. Dec 6, 2011 at 2:27 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    this right here
  15. Dec 6, 2011 at 5:10 PM
    Silvertacomao6
    Silvertacomao6 Well-Known Member
    Ogdensburg,Ny
    06 TRD DC relatively factory
    Iwas just curious, I have a 06 taco DCLB with a 6" Fabtech basic lift. It rides like a lumber wagon. Also have Mickey T's that scrub my front wells a lot. Would this assist my truck with my problems? The truck is also noticeably front high and would like it rear high a bit or level. If anyone could advise it would be much appreciated.
    Kind Regards,
    Trevor
  16. Dec 6, 2011 at 11:30 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    FYI to the first gen tacos... the compressed length of the rear shocks are 16" which are about 1" to 1.5" too long for the rear when articulated...
    if you wheel the truck and compress your rear axle, you will bottom out the shock before your stock bumpstops come close to hitting, and can actually bend the stock upper shock mount... i found that out the hard way...
    if you add a 1.5" to 2" bump to your upper strike post, you can save the shock from bottoming out, but you will lose a little on the up travel... you won't really miss it though if not hucking the truck...
  17. Dec 7, 2011 at 3:57 AM
    EL TACOROJO
    BURRY
    south mills NORCAK
    I believe I have 4.5 inches of lift in the rear I believe
  18. Dec 7, 2011 at 8:30 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    If u are that high up, these shocks are too short. They are only 8 inch travel. Stock travel is 6.5" so these shocks would be standard for a truck with 1.5 to 2 inch lift in rear.
    To be safe, cycle your suspension with the shocks off and measure your droop from mount to mount.
    I have a 3" lift in rear and my axle droops down to about 28 inches so I'm running 12 inch travel shocks which measure 16.3" compressed and 28.5" extended, roughly.
  19. Dec 7, 2011 at 2:15 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    ive been looking to do that .
  20. Dec 7, 2011 at 11:29 PM
    cools20
    cools20 Well-Known Member
    Cooley
    Socal
    i mob dirty
    shits built
    can i run the 2.5's as mid travel, stock lca's?
