Fox 2.5 tips
Discussion in 'Suspension' started by Yotaholic, Apr 5, 2018.
  1. Apr 9, 2018 at 8:09 AM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Sharkfrog likes this.
  2. Apr 9, 2018 at 8:17 AM
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    We just installed fox 2.5's on my truck and adjusting them on the truck was a PITA. @foxrcing07 could probably explain a lot better than me, but we kept having issues with the coil binding on the split ring. We ended up pulling them off the truck and using spring compressors to set the ride hight, and even that was not an easy task.
    Biscuits, RangerComa and go2cnavy like this.
  3. Apr 9, 2018 at 9:28 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    I know what you mean. Same thing was happening to me. I somehow got it past the split in the collar. I might might have used a flathead screwdriver to give it that little extra it needed to clear the gap. It was a blur of cussing and knuckle banging, so I blocked it from memory.
    Catfish21 likes this.
  4. Apr 9, 2018 at 10:11 AM
    Yotaholic
    Yotaholic [OP] Well-Known Member
    Oahu, HI
    2017 DCSB Sport 4x4 MT
    Was it because the keeper nut was loosened too much? If it’s not that expensive to take it to a shop to adjust then I don’t mind paying. My only concern is fine-tuning the coilovers to the exact height I want.
  5. Apr 12, 2018 at 7:08 AM
    Mavrick
    Mavrick Well-Known Member
    2015 DCSBOR
    What is the deal with these coil overs and not being able to reasonably adjust them on the truck. That is total BS in my opinion and could be easily improved with some type of washer or ring that goes between the coil and the adjusting ring. That and why they went with a split ring collar is beyond me, can someone tell me the advantage of the split ring verses a second jam ring?
    I know someone will post, "how much do you really need to adjust?" and the answer is this, enough to make it worthwhile for a better ring/adjusting system. They really expect you to install these shocks and simply guess at the height you want, then take the whole thing out to "guess" again and repeat and repeat and repeat LOL F That.
    I would really like to know from the experts why these shocks are not made to be adjusted on the truck?
    Biscuits likes this.
  6. Apr 12, 2018 at 7:29 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    No, it only happened on the first or second time going around. After that it wasn't a problem. But at that point I made sure to keep turning with force until I cleared the split with the end of the coil.
    Most of us can and have adjusted on the truck without too many issues. My biggest issue was that I installed my coils with the keeper nut on the backside, making access to loosen it VERY difficult. In the end I figured it out and was able to adjust on the the truck.
    Edit: what are your options? King are the same way, not unique to fox.
  7. Apr 12, 2018 at 11:26 PM
    Yotaholic
    Oahu, HI
    Everything came in the mail today, going to do the install this saturday!
    CementTRDOffRoad and RangerComa like this.
  8. Apr 13, 2018 at 12:32 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I have zero issues adjusting them on the truck. I find it very simple and a 10 minute project, which includes getting the jack and tools out. I've done it 4 sepererate times.
  9. Apr 14, 2018 at 11:48 AM
    Yotaholic
    Oahu, HI
    Currently doing my install. I noticed that the keeper nut is facing the opposite side and I’m not able to access it to adjust my shocks once they are installed. Help here!
    RangerComa likes this.
  10. Apr 14, 2018 at 11:55 AM
    Mavrick
    2015 DCSBOR
    I don't have my shocks yet so havent done it but they state your not supposed to do it on the truck. I get the fact you can but just can't see their point in how they make them, you would think that adjusting them on the truck would be a marketing thing.
  11. Apr 14, 2018 at 11:56 AM
    Mavrick
    2015 DCSBOR
    I don't have mine yet but would assume you need to put the set screw to where you can get at it before you install them so it faces the wheel.
  12. Apr 14, 2018 at 12:01 PM
    Yotaholic
    Oahu, HI
    Wouldn’t that defeat the purpose of having to compress the shocks/droop the suspension to adjust the ring?
  13. Apr 14, 2018 at 12:04 PM
    Mavrick
    2015 DCSBOR
    I think were talking about two different things. What are you referring to when you say keeper nut is facing the the opposite side?
  14. Apr 14, 2018 at 12:05 PM
    Yotaholic
    Oahu, HI
    The nut you need to loosen to adjust the coilover height
    Jultepod likes this.
  15. Apr 14, 2018 at 12:10 PM
    #35
    Mavrick
    2015 DCSBOR
    You have to loosen the set screw on the split ring collar and then turn the collar, if you loosen the set screw too much the collar with jump the thread and you will damage the threads. If you can't access the set screw in the split ring collar then you will have to remove the entire coil over from the truck to gain access to it, you would then turn the collar so the split ring side faces out or towards the wheel so you can get at it. Once your done adjusting your height you would leave the collar so the split ring faces out so you have access to re tighten it. You should also jack the truck up so the front wheel hang and lube the threads on the shock collar.
    I don't have these shocks yet and have yet to do this but from what I've read and understand this is correct, please correct me if I'm wrong.
  16. Apr 14, 2018 at 12:22 PM
    #36
    Yotaholic
    Oahu, HI
    I understand that it’s required to loosen the set screw to adjust coilover height. My question is, will I be able to turn the set screw to face outwards without a spring compressor?
  17. Apr 14, 2018 at 12:30 PM
    #37
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    It won’t be an easy task with the spring fully tensioned agaisnt the collar.
    Can it be done?...probably.
    Would I do it that way?...heck no.
  18. Apr 14, 2018 at 12:51 PM
    #38
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Yes. Very easily. Listen to a guy that's done it multiple times or listen to people who don't even own them yet (I'm not talking about anyone in particular). The choice is yours?
  19. Apr 14, 2018 at 12:59 PM
    #39
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Just do another half turn so it faces the front?...
  20. Apr 14, 2018 at 1:32 PM
    #40
    MCDavis
    RIC, VA
    Adjusted mine on the bench with a legitimate compressor. Not the two screw type. Still sketchy AF.
