Fox 2.5s question
Discussion in '3rd Gen. Tacomas (2016+)' started by CHASE2016, Jan 12, 2018 at 4:47 PM.
  1. Jan 12, 2018 at 4:47 PM
    CHASE2016
    CHASE2016 [OP] Member
    chase
    Northwest GA
    2012 dcsb 4x4
    Pelfreybilt Bumper, 6112's, Fox 2.0 rear shocks, wheelers 1.5” aal
    my dad just got some Fox 2.5 front coilovers for his 3rd gen, and is wondering how much lift out of the box it will give his truck. He’s looking to get 2” lift out of it. If someone could please advise. DFA6135A-D9C8-4EE9-8A7B-CCA0400960B7.jpg
  2. Jan 12, 2018 at 5:12 PM
    browndirtcowboy
    browndirtcowboy Well-Known Member
    Manteca
    You will get 2" no problem.
    CHASE2016 [OP] likes this.
  3. Jan 12, 2018 at 5:15 PM
    CHASE2016
    chase
    Northwest GA
    2012 dcsb 4x4
    So you think it will be 2” based on the threads showing?
  4. Jan 12, 2018 at 5:23 PM
    browndirtcowboy
    Manteca
    Yes. It loooks like you have about 2"of thread showing. On my truck I have about 2.25" showing and I have about 2" of lift. but I am running sliders, winch, bumper and a camper shell. So about 2"of thread showing and no armor you should be about 2 to 2 1/2 " in lift.
  5. Jan 12, 2018 at 5:54 PM
    CHASE2016
    chase
    Northwest GA
    2012 dcsb 4x4
    thanks for the help
  6. Jan 12, 2018 at 6:23 PM
    k-rackit'skish
    k-rackit'skish Member
    2017tacotrdproser
    out of the box going be around 1''
  7. Jan 12, 2018 at 7:18 PM
    ticketflipper
    ticketflipper Member
    18 TRD OR
    This ^.
    I installed a set a couple of weeks ago and out of the box it was right at 1” of lift. I turned them up last week and now have 2”.
    Warning: it was a mother... I bought the fox Spanner, took them out and it still took a lot to get that much. Not sure the spring rate, but they are stiff. I had to use a big spring compressor, the little loaner ones from the parts store wouldn’t even touch them.
    To get 2” you’ll need about 3” of thread showing.
  8. Jan 12, 2018 at 7:24 PM
    RangerComa
    RangerComa High Speed Dirt Limo Adventure Rig
    Adam
    Bay Area, CA
    17 DCLB Sport
    list is growing fast
    I'm DCLB 4x4, no armor. I got 1" on factory setting. Which is the same as the pic you posted. Crank it up if you want 2".
  9. Jan 12, 2018 at 7:33 PM
    CHASE2016
    chase
    Northwest GA
    2012 dcsb 4x4
    Is the spanner wrench required to adjust them?
  10. Jan 12, 2018 at 7:41 PM
    mesojdm
    mesojdm Well-Known Member
    State of Jefferson
    2016 DCLB TRD OR QS
    I had the same problem. even with the truck lifted and the preoload off the were a PITA. I sprayed the threads with lube, then hit the spanner wrench with a mallet. Ended up working but was a workout and a half.
  11. Jan 12, 2018 at 7:49 PM
    Tac0maSteve
    Tac0maSteve Well-Known Member
    East Bay, CA
    '15 TRD Off Road Icon Ext. Travel
    DCSB... No mods here
    The spanner will make it a heck of a lot easier to adjust but it can be done with other tools. Also the amount of lift will be determined on how much weight he has on the front of the truck.
  12. Jan 12, 2018 at 8:39 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    A 5/16" pin punch will work and a can of wd40. The springs are 600# but are PITA to crank. I have the fox spanner wrench i'd sell to you since it doesn't work with remote resi's.
  13. Jan 12, 2018 at 8:47 PM
    Bluebear
    Bluebear Well-Known Member
    OC CA
    2014 Tacoma V6 DCLB 4wd TRD Sport
    Icon Stage 4 ..now minus their coilovers (FOX 2.5 resi) / Billet UCAs, Icon Bump Stops, Demello flat bumper/Hybrid Sliders, Cooper S/T Maxx 255/80s 17s, TRD Pro Sema Wheels, Baja Squadron R-Sport LEDs, McNeil 2" front glass; RCI front skid; Bakflip HD; solid motor mounts
    I wish the factory set them at 2.” I’m not sure who would just want an inch. My truck looks stock height...haven’t gone thru the headache to adjust them yet.
  14. Jan 12, 2018 at 11:52 PM
    stevenjasmin
    stevenjasmin Well-Known Member
    TRD OFF-ROAD
    If it helps I installed these last night, I was at 21 inch from center axle to fender, now about 23 1/8 . I am running 24 exposed threads on drivers and 21 on passenger.
    Oh and I had no issues adjusting on truck with wd40 and a cut off #3 philips screw driver(equivalent to 5/16 punch)
    Lesson learned on one coil over I installed then realized that the set screw was facing in ward, so I couldn’t loosen to adjust. Something to check before you install, so I had to tear it all out again to loosen the set screw so I could then Later adjust on the vehicle.
  15. Jan 13, 2018 at 6:32 AM
    ticketflipper
    18 TRD OR
    I bent 2 punches and a hardened drill bit trying to get them to move.
    Maybe it was just bad luck. but with no weight on the suspension, pb blaster, and a lot of cursing they still wouldn’t move.
    2nd double checking the set screw location. Mine were both on the backside. To me it didn’t matter though, I knew I was going to have to remove them to adjust.
    soup222002 and CHASE2016 [OP] like this.
  16. Jan 13, 2018 at 7:06 AM
    CHASE2016
    chase
    Northwest GA
    2012 dcsb 4x4
    That’s a lot of work just to adjust them a little. It would be nice if Fox would mark the threads to show different ride heights. I’m worried we will be in the situation you described where we install them just to see where it sits and have to take them off to adjust them.
  17. Jan 13, 2018 at 7:17 AM
    RangerComa
    Adam
    Bay Area, CA
    17 DCLB Sport
    What year, model and how much extra weight if any do you have?
  18. Jan 13, 2018 at 7:24 AM
    CHASE2016
    chase
    Northwest GA
    2012 dcsb 4x4
    Thanks this is some good info, I believe there are around 24 threads showing. So hopefully it will be around 2” lift like yours turned out.
  19. Jan 13, 2018 at 7:31 AM
    stevenjasmin
    TRD OFF-ROAD
    2017 trd off road no armor
    CHASE2016 [OP] and RangerComa like this.
  20. Jan 13, 2018 at 7:49 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR 6MT 350Z 6MT
    Are those new or used? They definitely looked cranked up for 2"+ of lift but thats unusual. Normally they come with only a couple threads showing and that gets you 1" or less.
