Fox C/O adjustment question
Discussion in 'Suspension' started by masshole taco, Feb 28, 2013.
  1. Feb 28, 2013 at 11:19 AM
    masshole taco
    masshole taco [OP] Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    I brought my truck to a buddy of mine who's a mechanic and asked him to adjust the coilovers as I still think I can get some lift out of. He called and said everytime he loosens the nut to adjust it the tension on the spring just push it right back to where it was.I said what about taking off the spring and adjusting without the spring but he said his spring compressor isn't that bad to take it off....
    Anybody have some thoughts on how to handle this problem.. Fox 2.5 C/O's.
  2. Feb 28, 2013 at 11:25 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    are you taking the load off the truck? you need to jack the front end off the ground using the jack point on the frame. Both of the wheels need to be off the ground. then loosen the bolt on the collar then adjust to desired height.
  3. Feb 28, 2013 at 11:53 AM
    masshole taco
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    yeah it's on his lift.. basically he loosens it all up adjusts it with three half turns then due to the tension on the spring it's going right back to where it was???
  4. Feb 28, 2013 at 11:55 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    its lifted on the frame not the control arms right?
  5. Feb 28, 2013 at 12:02 PM
    masshole taco
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    I would definetly hope so.. LOL.. I'm not there so I can't see what he's talking about.. errgh..
