Fox coil over adjusters NOT turning
Discussion in 'Suspension' started by crux, Jun 25, 2020.
  1. Apr 24, 2021 at 7:07 PM
    Darth_Smittious
    Darth_Smittious Active Member
    2015 Tacoma PreRunner SR5
    Fox 2.5 DSC Coil overs, Icon Delta Joint UCA,'s, Fox 2.5 DSC Shocks, Full Icon RXT leaf pack, Archive Garage Flip with 2.7″ Super Bumps
    I think they do know. I think a lot of the dealers know. I just think not enough people are complaining. They might be embarrassed they paid 2k + for something that doesn’t work.
  2. Apr 27, 2021 at 6:05 AM
    Darth_Smittious
    The tool ended up working:sawzall: I was ready to be disgruntled too.
  3. Apr 27, 2021 at 6:48 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Please tell me you used a sawzall on your shocks
    TXpro4X4 likes this.
  4. Apr 27, 2021 at 7:42 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Once you cracked it loose, is it much easier to rotate now?
  5. Apr 27, 2021 at 7:59 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I had to, to remove my 5100 top nut. Pour design.
    It was fun
  6. Apr 27, 2021 at 9:42 PM
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    Anyone on here taken apart the DSC?
    Anyone have an exploded view of a DSC?
    AccuTune Offroad likes this.
  7. Apr 27, 2021 at 9:53 PM
    Darth_Smittious
    It’s stiff but turns like the rest. That initial crack is something. But afterwards it notches like it’s supposed to.
  8. Apr 28, 2021 at 7:02 AM
    AccuTune Offroad
    El Cajon, CA
    Yes. Trying to find time to put together an article showing all the components
  9. Apr 28, 2021 at 7:17 AM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    https://rangeoffroad.com/shop/ols/products/fox-dsc-adjustment-helper-knob
    I also have Japanese soft jaw pliers.
    Similar to this item https://whitlampaint.com/product/soft-jaw-pliers/
    I have a hard time with my hands, so little things like that help.
  10. Apr 28, 2021 at 7:22 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Note to self: do I REALLY need remote reservoirs with damping adjustment knobs, or would a large shock body suffice?
  11. Apr 28, 2021 at 10:01 AM
    AccuTune Offroad
    El Cajon, CA
    deanosaurus likes this.
  12. Apr 28, 2021 at 11:13 AM
    Darth_Smittious
    I like to go fast on dirt trails and utility roads. I also enjoy Speeding through my friends farm land with my night vision on. When the weekend is over I adjust them back to a nice balanced street tune.
    Crikeymike and AccuTune Offroad like this.
  13. Apr 28, 2021 at 11:16 AM
    Darth_Smittious
    ctheulen and AccuTune Offroad like this.
  14. Apr 28, 2021 at 12:20 PM
    zippo88
    L
    2012 sport
    That's incredible! Thank-you!!
  15. Apr 28, 2021 at 12:27 PM
    #35
    gillies66
    2020 DCSB OR
    I agree shock bodies and dampening adjustors are completely different things. Admittedly, I'm new to four-wheel off road, but I have decades of experience with MX and Enduro suspension for two wheels. On a motorcycle, the whole idea of suspension is to keep tires on the ground. Given the terrain, speeds involved, and light weight of the bike, the tuning is often fine. Sag is critical, so spring rate and preload are typically considered first. The goal is generally 30% sag to accommodate down travel, leaving 70% for up travel. We then considered shim stacks and, possibly, oil viscosity for general dampening characteristics. The fine tune of high and low speed compression and rebound adjustors, if so equipped, would happen with laps on the track/in the field. Those settings were meant to suit terrain and rider preference.
    I find the general approach to suspension on TW to be much, much different. I can fully appreciate the desire for a larger shock body and accompanying components for strength and the benefit of additional oil over OEM. Broken parts and fade through hot oil and cavitation are to be avoided. On the other hand, lifts that eliminate virtually all sag are common, and remote reservoirs with various dampening adjustors are desired for purposes other than racing. Buy what makes you happy. I only chimed in because someone was having problems with delicate, complex system components that may not be necessary for the vast majority of off road activity.
  16. May 5, 2021 at 10:46 AM
    #36
    AccuTune Offroad
    El Cajon, CA
    Alright you guys will be the first views on this brief Tech Article about DSC adjuster knobs. Hopefully this clears up some questions on how these are assembled and can be taken apart. Post up any questions and hopefully I can help answer them for you
    https://accutuneoffroad.com/fox-dsc-adjuster-assembly/
    teaser image:
  17. Jul 10, 2021 at 12:51 PM
    #37
    Don Vergas
    Don Vergas Well-Known Member
    Adrian
    NorCal
    06 Tacoma DBLCB Trd Offroad
    just got the shocks on and mine are a bitch to turn too.. did the helper knob “help” at all
  18. Jul 10, 2021 at 1:00 PM
    #38
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    WOW...Glad I went with ADS. But Fox was in my Thinking About it ballpark.
    Kolter45 likes this.
  19. Aug 7, 2021 at 12:27 PM
    #39
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    I had a hard time turning it too. Use gloves when you do this. I did after every few hours to muster up some energy. Once you’ve done it the first time, adjust them back and forth. It will be easy moving forward. I did order the adjuster knob from Range off-road to make it easier to adjust since it’s summer and 110 degrees outside even with gloves on.
  20. Aug 7, 2021 at 1:29 PM
    #40
    Don Vergas
    Adrian
    NorCal
    the adjuster knob works wonders, first time turning adjusters without it left my knuckle fucked up definitely worth the money
