Fox Coil-over Question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by goomba, Sep 3, 2010.
  1. Sep 3, 2010 at 6:54 AM
    goomba
    goomba [OP] It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
  2. Sep 3, 2010 at 6:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! I dont think those are the right ones for your truck, but someone else should chime in soon.
  3. Sep 3, 2010 at 7:03 AM
    goomba
    Josh
    San Antonio Fl
    I do not intend for them to OME replacement but for a custom application.
    They will still go where the old shock goes but in the log run I am working on a LT (long travel) kit.
  4. Sep 3, 2010 at 7:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well then you should be OK. The stroke seems a little short though...
  5. Sep 3, 2010 at 7:12 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    x2 especially if you plan to LT the rear.
  6. Sep 3, 2010 at 7:23 AM
    goomba
    Josh
    San Antonio Fl
    This is for the front. I was going to run these in place of my strut until I have money for the LT kit. And these are just short enough in collapsed length to where the bump stops hit be for the shock bottoms out, but could I put a bump stop on the shaft of the coil-over?
  7. Sep 3, 2010 at 7:28 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Why waste the money (that you will need for the LT) to buy those and customize the front end to get them to fit, then turn around and have to uncustomize the front to get the LT to fit?
  8. Sep 3, 2010 at 7:48 AM
    goomba
    Josh
    San Antonio Fl
    I was thinking there was little customization to the front end for these to fit. I think I will only have to move the brake lines and drill holes, or find a place to mount my reservoir. The LT kit is a long way off, until I am done with high school/college, and this is my senior year in high school. ( no time to work because I play football, basketball, and run track )
  9. Sep 3, 2010 at 8:06 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    I wouldn't recommend those for you, for the fact that they're only available with a 5/8" shaft. You should really be running a 7/8" shaft....
    Marco
  10. Sep 3, 2010 at 9:34 AM
    goomba
    Josh
    San Antonio Fl
    Would it be fine if I were to only use it without a LT kit or is the 5/8" shaft just too small for my truck?
