Fox Coilover Kit
Discussion in 'Suspension' started by JeremyGrey, Apr 4, 2012.
  1. Apr 4, 2012 at 8:51 AM
    JeremyGrey
    JeremyGrey [OP] Well-Known Member
    Ahwatukee, AZ
    2012 DCSB TX Pro Prerunner
    I am looking to put this "lift kit" on my 2012 DCSB TRD offroad Tacoma Prerunner. It come with front coilovers, UCA, and rear resi shocks. Does anyone have this lift? Am I going to need a AAL in the rear? What size tires would look good with this lift(on stock rims). I like the boxy style tires(toyo, terra grapplers)...will these fit stock rims? thanks
    http://www.offroadwarehouse.com/products/sfID1/4/sfID2/78/sfID3/83/productID/39119
  2. Apr 4, 2012 at 8:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Thats a good set up. you dont have to lift the rear if you dont want to. you can adjust the CO's to about 2" of lift to level it out with the rear.
    if you only plan on doing a 2 - 2.5" lift then I would say 265-75- tires.
    for a 3" lift you could get 285's
  3. Apr 4, 2012 at 9:01 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    That's a really good lift. If I were you, instead of getting an add a leaf, I'd get a whole new leaf pack. Allpro and Old Man Emu make great ones. As for tires, 285s or 305s would look great but you may have to trim some of the fender invade you rub. Also, front wheel spacers from spidertrax wouldn't be a bad idea either.
  4. Apr 4, 2012 at 9:04 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    think about getting spindles instead of a coilover for your truck. or get both. best of both worlds!
  5. Apr 4, 2012 at 9:12 AM
    JeremyGrey
    Ahwatukee, AZ
    What is the advantage of spindles? I've driven a tacoma with just CO and it handled amazing.
  6. Apr 4, 2012 at 9:14 AM
    JeremyGrey
    Ahwatukee, AZ
    I see, I have a hook up at deaver. If I go with a whole new pack, I think I will give deaver a call.
  7. Apr 4, 2012 at 9:23 AM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    Street, MD
    11 Tacoma TRD DCLB 4X4
    Bilstein 5100 all around with front set at .85 w/Eibach coil and 1/2 spacer, Rear 2" Deaver AAL, SCS Steath 6 matte black rims wrapped in 265/70/17 Duratracs, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 20% up front and 50% on windsheild), HID 35W 6000K headlights and 35W 4300K fog lights, Smoked Tail lights and 3rd brake light, T-Rex 2 eyelids colormatched, Foglight anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Doug Thorley LT Headers, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, Hella 700FF HID 55W 6000K behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Omega Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns
    I want that exact lift so bad with some all pro leafs. Im trying to save up the money just taking longer than I thought :(
  8. Apr 4, 2012 at 9:24 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Spindles allow you to achieve 4" lift with zero preload on the coilovers. Plusher ride. Also they are much stronger than factory ones.
  9. Apr 4, 2012 at 9:33 AM
    JeremyGrey
    Ahwatukee, AZ
    I like the idea. If they made the trd offroad in DCLB I would probly go 4". I think I'm leaning more towards 2-3" of lift(I like better on DCSB). I'm doing the fox set up more for ride quality(offroad) than looks. I almost bought the wife a DCLB this weekend(in that case I would have gone 4" on her truck). She got a Jetta instead :(
  10. Apr 4, 2012 at 9:49 AM
    PLC721
    Patrick
    Chandler, Az
    well i think the total chaos spindle is 3" and the cam burg is 4", i might be wrong as i haven't researched spindles being 4x4 lol
  11. Apr 4, 2012 at 9:55 AM
    JeremyGrey
    Ahwatukee, AZ
    I will definitely look into spindles
  12. Apr 4, 2012 at 6:09 PM
    JeremyGrey
    Ahwatukee, AZ
    if i keep the stock tires do i need to do wheel spacers?
  13. Apr 19, 2012 at 1:48 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    Looks like an awesome lift, definitely go for the new leafpack in the rear. If you plan on doing some good offroading, I wouldn't put 33's on unless you go to at least a 4" lift. Even with trimming you'll be stuffing your wheels into your fender wells while offroading with a 3" lift.
  14. Apr 28, 2012 at 12:29 PM
    JeremyGrey
    Ahwatukee, AZ
    If I do a new leaf pack with the CO/UCA wouldn't that give me factory rake? I want it to be level. I can't find a new leaf pack under 3" lift. The AAL come in 1.5" lift. Am I wrong?
  15. Apr 28, 2012 at 5:02 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    2.5" up front and 1.5" in the rear is pretty level! Factory rake is 1.5" usually! Deavers give 1-1.5" of lift!
  16. Apr 30, 2012 at 9:25 AM
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    least they could do for that price is throw in the spanner wrenches.
  17. Apr 30, 2012 at 9:53 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    You "shouldn't" need one......its for performance not lift! I'd try to keep it in the designed "sweet spot! Its nice to make adjustments but some people crank them up so high they ride like shit and have no down travel....then they think that particular brand sucks!
