Fox coilover leaking
Discussion in 'Suspension' started by Supertramp, Feb 18, 2013.
  1. Feb 18, 2013 at 6:01 PM
    Supertramp
    Supertramp [OP] dismember
    NC Mountains
    2002 Access cab TRD
    3 inch lift, Fox coilovers
    Hello folks, I know this is my first post and I show up with my hat in my hand asking for input but please excuse my rudeness. :)
    I bought an 02 Taco with Fox coilovers and the driver's side is leaking some oil from the seals... I think. The passenger side has leaked some in the past but it doesn't appear that it has leaked in a while. My question is, how big of a deal is it to rebuild these as I have never owned a set of coilovers. Is it possible to install standard struts (OE) while I have these rebuilt or am I stuck with running coilovers now?
    Thanks in advance for any help/input. :D
  2. Feb 18, 2013 at 6:12 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Welcome! Rebuilding the coilovers isn't terrible and not overly expensive. Check youtube for videos of rebuilding these. Also check out Downsouth Motorsports, they are vendors on this website and know their stuff on suspension. They could sell you the parts to do the rebuild yourself or do the work for you.
    There's no reason you couldn't go back to an OEM shock/coil.
  3. Feb 18, 2013 at 6:19 PM
    Supertramp
    NC Mountains
    2002 Access cab TRD
    Thanks Pugga!
    Would I need to change anything out as far as control arms, etc to install a standard shock while I get these rebuilt or would they just bolt up?
  4. Feb 18, 2013 at 6:23 PM
    Pugga
    Massachusetts
    F-150 Mod
    OEM shocks/coils should bolt right up. I'm not overly familiar with 1st Gens but, from your picture, I don't see anything that would prevent you from going back to stock. I'm not sure if you could use the Fox coils with OEM shocks (someone more familiar with 1st Gens might know for sure if they're compatible) but there's no reason OEM shocks and coils couldn't be bolted up.
  5. Feb 18, 2013 at 6:28 PM
    Supertramp
    NC Mountains
    2002 Access cab TRD
    Thanks again Pugga, I'll give Downsouth a call and see what kind of turnaround they have on rebuilding these. This is my daily, so I can't keep it down too long.
  6. Feb 18, 2013 at 6:33 PM
    Pugga
    Massachusetts
    F-150 Mod
    If you get the rebuild kit, there's no reason you can't get them off the truck, rebuilt and remounted in under a day.
  7. Feb 18, 2013 at 6:41 PM
    winL
    winL Well-Known Member
    Bay Area, CA
    PreRunner
    Leer 100R Cap, OEM Hood Protector, Bilstein 5100's @0, Wheeler's 3leaf AAL no TSB, Replaced oem OL, OME 885, Pioneer AVIC-D2
    from the looks of it, no other aftermarket parts are bolted on, only the Fox bit. OE should bolt right on!
  8. Feb 18, 2013 at 7:12 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    This
    It's easy to do yourself, before you pull them contact DSM, fox, or polyperformance and get oil/seals. You can do it under one day if you have easy access to nitrogen or whatever they use. If you want someone to do it for you stock coils will bolt right on. I had to bolt stock coils back up to take my sway aways to get filled.
    Wheres WNC? there might be a mod day nearby if you needed help.
  9. Feb 18, 2013 at 7:14 PM
    Anthony250
    Anthony250 E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Ive rebuilt these before, wayy easier to do than any other shock out there.
  10. Feb 18, 2013 at 8:30 PM
    Supertramp
    NC Mountains
    2002 Access cab TRD
    Western North Carolina.
    I've owned Tacomas and 4Runners for the majority of my driving career, but this Taco came with the mods already done so I am learning in reverse. :)
    Thanks for all the answers guys.
  11. Feb 18, 2013 at 8:53 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
    Thought so, I'd offer to help but I'm a bit far :p
    This is my first Tacoma so I'mlearning too. Lots of info here and at ttora.
    And it want rude for your first post to be a question, that's what we're here for:D
