Fox coilover + lift block?
Discussion in 'Suspension' started by Jkohler, Apr 18, 2013.
  1. Apr 18, 2013 at 10:08 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    Hey all, I am looking to purchase some fox 2.0 coilovers soon and was wondering if I could have a 3 inch lift block on top of it to have a 6 inch lift? Would this cause any problems? Right now I have bilstein 5100 height adjustable shocks in combination with a lift block, toytec upper control arms, and fabtec 6 inch lift spindles. It pretty much rides like a tank :/ I have actually blown out 3 of the bilstein shocks in two different incidences. I believe this is because I have extremely low down travel on the shock, and if I jar it hard, it makes an unpleasant sound and hard hit. Any suggestions or advice? I am looking to spend around $1,000 bucks. It is my daily driver and weekend warrior. I took it down to moab this year for the safari and took it on steel bender and golden spike and did well.
  2. Apr 18, 2013 at 10:19 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Nope 3" is the max unless you do a drop bracket or a body lift.
  3. Apr 18, 2013 at 10:21 PM
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
    Im not sure what you mean by lift block. I'm not an expert on lifts but I have 5" drop bracket with strut spacers and I put on Icon coilovers. It improved my ground clearance and added some height. What are your CV's looking like right now?
  4. Apr 18, 2013 at 10:22 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    Thats what I dont really understand because I have 6 inches of lift on it right now..What would be the dangers/problems with using a block on top of the coil over?
  5. Apr 18, 2013 at 10:25 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    A block is a round metal 3'' puck that goes between where the coilover and bracket where the coilover bolts in on the top
  6. Apr 18, 2013 at 10:27 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    And the cv's aren't terrible, they are at a little bit of an angle. I replaced them about 20,000 miles ago and have had no issues so far. I just got back from moab as well.
  7. Apr 18, 2013 at 10:29 PM
    JLee
    Jerry
    Benicia, CA
    How do you have 6" lift spindles with a 4wd :confused:
  8. Apr 18, 2013 at 10:30 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Sounds like he has a drop bracket already...
  9. Apr 18, 2013 at 10:33 PM
    JLee
    Jerry
    Benicia, CA
    He must then i guess you could stack a 3" block on the co's if in fact you do have a drop bracket.
  10. Apr 18, 2013 at 10:38 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
  11. Apr 18, 2013 at 10:38 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    throwing a block/spacer/or whatever on the FOX's is like pouring ketchup on a Ribeye... ya just don't do it.....:notsure:
  12. Apr 18, 2013 at 10:38 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    OP, I'd like to see pics of your front suspension. I'm very confused lol
  13. Apr 18, 2013 at 10:39 PM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    K Pics coming in the morning
  14. Apr 18, 2013 at 10:39 PM
    NW4RUNNER
    4 runner trail
    Yea maybe its semantics but I don't understand if we are talking about the same thing. Can you post some pics of the truck?
  15. Apr 18, 2013 at 10:42 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    The truck looks like it has 6" of lift with something smaller than 35s.
  16. Apr 18, 2013 at 10:42 PM
    JLee
    Jerry
    Benicia, CA
    That is a drop bracket 6" lift and it rides like crap because you have the stage one you need to get stage 2 coil overs for a better ride. They get rid of that spacer you have and are the full lenght.
  17. Apr 18, 2013 at 10:43 PM
    NW4RUNNER
    4 runner trail
    Yes. Looks like you have a drop bracket. You can run aftermarket coilovers just fine with most of these, although I don't know anything about that kit specifically.
  18. Apr 19, 2013 at 6:40 AM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    Heres some pictures I snapped this morning of what I have.
    Is this a Drop Bracket Lift? As far as I know the aftermarket mods are as follows: new cross members, after marked 6'' spindles, aftermarket upper control arms, replacement bilstein 5100 adjustable shocks on 2nd setting, 3'' spacer (was originally a 6'' spacer if you can believe it, cut down to 3") differential/3rd member drop kit, rear driveline SYE drop kit, and aftermarket sway bars. This is my first yota, I have always had jeeps with solid axles so IFS is a new thing to me and I have been learning as I have been going. I should probably clarify that when I bought the truck it had what I was told was a truck outfitters lift. I have replaced everything except the cross members.
  19. Apr 19, 2013 at 7:52 AM
    JLee
    Jerry
    Benicia, CA
    That is a drop bracket lift.
  20. Apr 19, 2013 at 8:11 AM
    Jkohler
    Jkohler [OP] HUH?
    Justin
    UT
    Glad we figured that out haha. I am fairly new to IFS lifts. This might be a stupid question, but how does a DB lift work? Is there a way to tell how much of a DB lift I have? What would be the best coilovers to go with this DB to get a 6'' lift? Do I need to buy 6'' lift coilovers?
