Fox coilover rebuild still leaking
Discussion in 'Suspension' started by shaman06, Oct 19, 2020.
  1. Oct 19, 2020 at 10:25 AM
    shaman06
    shaman06 [OP] Well-Known Member
    SoCal
    2013 sport
    Quick question, I’ve had my driver side fox 2.5 DSC C/O rebuilt twice now at outlaw off-road. The first time the coilover was dumping out oil, had them rebuilt and now there appears to be a small leak (just enough to wet the bottom of the shock body). After posting about this last time I brought it to Outlaw and they said this was just residual oil. My question is should I have them rebuilt a third time or just buy a new set of coilovers as this is getting frustrating. Thanks y’all.
  2. Oct 19, 2020 at 2:35 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    They've been rebuilt 2x now and still leaking? Approx how many miles on them?
    Residual oil can definitely be the case if they were not cleaned very well when put back together. If its still leaking, and a good amount there is either something very wrong, or rebuild was not done very well. We are in Carson if you want to have someone else take a look at it. You should NOT need to replace the entire shock.
  3. Oct 19, 2020 at 2:40 PM
    shaman06
    SoCal
    2013 sport
    Initially they had 30k miles on them and then started leaking so I had them rebuilt, then they immediately started spraying oil so I had them rebuilt a second time. Then after the second rebuild I noticed the bottom of the shock body became wet with a small amount of oil, I’ve cleaned it off several time and it keeps coming back. It’s not nearly as bad as the first time there is no oil dripping down to the lower control arm. I think I messaged you guys about them, I’d have to remove the coilover and bring it in to you guys right? Or would you guys be able to remove the coilover and rebuild it? Thanks
  4. Oct 19, 2020 at 2:50 PM
    AccuTune Offroad
    El Cajon, CA
  5. Oct 19, 2020 at 2:52 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Sounds like you should have a pro check out your shock. Bet you @AccuTune Offroad can find the issue without even breaking into the shock.
    Do you have any pitting on the shaft?
  6. Oct 19, 2020 at 3:46 PM
    shaman06
    SoCal
    2013 sport
    Not that I can see, but ya I agree this is getting old! I’ll take it to them
