Fox Coilovers for Front Level/lift??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by k9ace, Feb 5, 2016.
  1. Feb 5, 2016 at 11:19 AM
    k9ace
    k9ace [OP] Member
    Anyone running a Fox setup on their 2016? Any input/pics would be much appreciated. Thanks..
  2. Feb 5, 2016 at 7:39 PM
    dirkupson
    dirkupson Active Member
    2020 Toyota dclb trd off road
    2.5 fox shocks ,trd 4runner wheels , toyo tires
    curious, too.....
  3. Feb 5, 2016 at 8:05 PM
    RC4x4
    RC4x4 Super White SR 4X4 4cyl
    Lee
    2016 AC 4x4 MT 4cyl Utility Pkg
    BFG KO2's
    k9ace. I just spoke with Headstrongoffroad this afternoon. I have a white AC 4cyl m/t 4x4 on order. I`m planning on running the Fox 2.5 standard coilovers. the 2.5`s are easily adjustable when installed. The rake on the 2016 tacoma is 1.5" front to rear, I plan on raising the front an inch only. this will almost level the truck and hopefully avoid the dreaded needle bearing vibration. BTW, the Fox 2.0 are not recommended to be adjusted without releasing the coil spring pressure. Also these 2.5`s can be installed in about an hour in your garage.
  4. Feb 8, 2016 at 7:57 AM
    k9ace
    k9ace [OP] Member
    Nice info. Thank you
  5. Feb 18, 2016 at 6:24 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    I also have a 2016 AC 4cyl 4x4 and am interested in 2.5 coilovers (most likely fox) to level my truck and improve suspension performance. Any feedback about how this setup works would be greatly appreciated.
