Fox coilovers, rear shocks w/ reservoir
Discussion in 'Suspension' started by Beltfed762, Mar 15, 2021.
  1. Mar 15, 2021 at 1:56 PM
    Beltfed762
    Beltfed762 [OP] Well-Known Member
    Virginia
    2011 DCSB TRD Offroad
    6" lift, 35x12.50R20 Firestone m/t, 20x10 XD Spy wheels, Fox shocks/coilovers, dif breather mod, SAIS delete, Alcan +5 leaf springs, U-bolt flip kit, Superbump bump stops, cab mount chop, poly performance leaf bushings, taco tabs, all-pro cam tab gussets, diy fender trim, fender flare delete, pinch weld smash, cloth seat delete + factory leather swap, seat heaters, remote start, 20% tint, ARE camper shell, ... im sure im forgetting something.
    nevermind
    AccuTune Offroad likes this.
  2. Mar 15, 2021 at 3:39 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    @AccuTune Offroad would probably be happy to answer your questions. I've worked with them and they're straight shooters and not trying to sell you something you don't need.
    I would say that for a truck that never offroads, remote reservoirs are probably not needed. However, I'm not overly familiar with drop bracket lifts (assuming that's what you have to achieve 6" of lift). No matter who is helping you, they'll need more info on your truck. What exactly is your current suspension set up. Coil spring rates? Leaf pack? Spacers? Also, they'll need to know what modifications you've made to the truck, so they can estimate your axel weights.
    Good luck.
    AccuTune Offroad and PinStripes like this.
  3. Mar 15, 2021 at 3:43 PM
    tcjacado
    tcjacado Well-Known Member
    You are in over your head.
