FOX Coilovers reviews
Discussion in 'Suspension' started by jackn7, Aug 6, 2017.
  1. Aug 6, 2017 at 9:53 PM
    jackn7
    jackn7 [OP] Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Everybody talks about Icon and King coilovers being better than Bilstein, OME and pretty much everybody else. Don't hear much about FOX though. How do they compare to them? They are priced much lower, but other than that...
  2. Aug 6, 2017 at 10:20 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  3. Aug 7, 2017 at 6:52 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    As Sic already said, you can search the suspension section and find a lot more info. Fox makes great suspension components.
    Though I'm curious where you are finding them cheaper than King or Icon? From my searches they typically seem to be the most expensive by a small margin.
  4. Aug 7, 2017 at 7:17 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Yeah, you're probably right about me being crazy but that besides the point! I was looking at the FOX 2.0 no res, just the stock replacement ones. I want to upgrade my suspension with something better than what I've got now. Was thinking bilstein or OME. Saw Fox shocks on the Allprooffroad.com site and thought they would be doable, but now I think I just misread the price. I'm sure they're not $859 for a PAIR. That's more likely each, right?
    Here's the page:
  5. Aug 7, 2017 at 7:22 PM
    Sodom
    Sodom Well-Known Member
    New England
    2001 Xtra Cab SR5 4x4 3.4L 5-Speed Gold
    Rust
    I got my Fox 2.0 Coilovers for just shy of $800 shipped from Headstrong Offroad. Would recommend.
    I was originally considering OME or 5100s, but I ultimately went with performance coilvers. I decided against lifting so I wouldn't have to deal with CV angles and driveshaft vibration issues.
  6. Aug 7, 2017 at 7:25 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    That's for the pair?
  7. Aug 7, 2017 at 7:25 PM
    Sodom
    New England
    Rust
    Sorry, yes for the pair.
    It says sold as pair on your link as well.
  8. Aug 7, 2017 at 7:27 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Wow! How's the ride compared to bilsteins or ome? I'm not looking for a lot of lift, just enough to clear the 32s I'm running now.
  9. Aug 7, 2017 at 7:29 PM
    McMash
    Tyler
    Gig Harbor, Wa.
    May be worth checking out Wheeler's Off Road as well. Great service and competitive on price. Just select your vehicle and start browsing.
  10. Aug 7, 2017 at 7:29 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Will do. Thanks!
  11. Aug 7, 2017 at 7:30 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Ride quality is significantly better than bilsteins or OME. Fox's can be fully tuned to suit your preference, and rebuilt instead of replaced.
    @*TRD*
    *TRD* and jackn7[QUOTED][OP] like this.
  12. Aug 7, 2017 at 7:31 PM
    Sodom
    New England
    Rust
    I couldn't say. I've never tried either.
    I went from stock Tokios to these - huge improvement. You can adjust the preload on these, but I haven't fooled with that yet.
    I bought rears as well but haven't installed them yet. Note the rears are only supposed to work with 0-1" of lift.
    jackn7[QUOTED][OP] likes this.
  13. Aug 7, 2017 at 7:34 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Thanks to both of you for the help!
    Sodom likes this.
  14. Aug 8, 2017 at 7:13 AM
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    Fox actually makes the highest quality off-road shocks, which is why the OEM manufacturers use them (Toyota, Ford, Polaris, Yamaha...)
    Here's a detailed comparison of some of their race shocks: http://accutuneoffroad.com/articles/fox-vs-king-2-0-coilover-shock-comparison/
    Here's a detailed summary of how well their adjusters work: http://accutuneoffroad.com/articles/how-fox-dsc-dual-speed-compression-adjusters-work/
    Performance wise they are on par with other manufacturers, and I'd recommend having them custom tuned for your application.
    If you're doing anything other than miles of washboard all of the Tacoma front shocks are too soft and bottom out too easily.
    McMash and jackn7[OP] like this.
  15. Aug 8, 2017 at 7:51 AM
    *TRD*
    Carson, Ca
    To expand on that a bit more.
    It used to be difficult to make shocks because common machines couldn't hold the necessary tolerances.
    But advancements in CNC technology and coatings in the last 15-20 years have made it very easy to produce shocks, hence the flood of new manufacturers.
    The trouble is that all the parts inside of a shock need to work together in ways that can't be accurately measured.
    So it requires A LOT of testing and experience to get it right. Most new manufacturers (and some old ones) can't or don't invest properly in R&D and are selling 15 year old designs.
    The industry has had a lot of incremental advancement in 15 years in terms of performance and durability.
    So this day in age it's really easy to make a shock, but it's still very difficult to make a good one.
    The last thing you should consider is the design intent of the shock.
    A shock & seal package designed to run the baja 1000 is much different than one designed to run 100k miles on the street.
    Very few can do both.
  16. Aug 8, 2017 at 8:02 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    Bilstein make a great OEM replacement for the price.
    If you can spend a little bit more $$, go with the Fox 2.0.
    If you can spend MORE $$$, go with King, Fox or Icon 2.5's
    You will be happy which ever way you go as these are all better than stock.
    In the end, it'll just come down to how much you want to spend.
    If you want Kings, i'll get you taken care of! :thumbsup:
