Fox Level 2 kit with or without OME Dakar Pack
Discussion in 'Suspension' started by synaps3, Mar 11, 2017.
Which kit would you choose?
  1. Fox Level II -- AAL
  2. Fox Level II -- Dakar Leaf Pack
  3. Fox Level I - AAL
Results are only viewable after voting.
  1. Mar 13, 2017 at 7:47 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Have the Fox 2.5 RR 3" lift Front and Fox 2.0 RR rears extended with dakar leaf packs. The rear is stiff till you get around 300 lbs in the bed then it starts riding smooth. Remember suspension is all a balancing act the more weight you load in the rear and shit the center of gravity the front will get stiffer. FYI at slower speeds under 30-40 mph the ride will be rougher than stock since the valving is greater. I wouldn't recommend going down to Fox 2.0 just the fact you reduce your oil capacity and the body material of construction isnt the same quality to hold up against corrosion. If you do go Fox 2.0 buy used.. you can find them half the price as new and just get them rebuilt for nothing. I would recommend going with 3" lift coilovers in case you ever wanted to bigger and extend travel rears shocks. The UCA are pricey but aren't needed till you push more than 2" lift so you can always upgrade later. Just to let you know your shocks will be the limiting factor in the rear for droop which is more important than compression since off roading is all about traction. My extended travel 2.0 3-5" lift are still the limiting factor on my dakar leaf pack.
    supralee and synaps3[OP] like this.
  2. Mar 13, 2017 at 7:47 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    whats nice is the coilovers are fully adjustable so you can change the ride height to sit how you want it. The less you crank down on them the better, since the more pre-load you put on them to raise the ride height, the shittier the ride will be
  3. Mar 13, 2017 at 7:49 AM
    TacoRD16
    Houston, TX
    They will work but will be the limiting factor for droop. I have fox 2.0 RR extended travel for 3-5" lifts on dakar leafs and my shocks are still the limiting factor by 1-1.5" after brake line extension.
  4. Mar 13, 2017 at 7:51 AM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    When i called toytec they said leave it at is , its set up at 2.5 but can go to 3 but might run a lil rougher at 3
  5. Mar 13, 2017 at 7:52 AM
    TacoRD16
    Houston, TX
    Joe23 likes this.
  6. Mar 13, 2017 at 7:53 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Do they even have them in stock? I was going to purchase the same kit but Marie said (and I checked with other vendors) that the fronts were not in stock and no ETA for shipping. I ended up with an Icon stage 1 kit instead.
  7. Mar 13, 2017 at 8:06 AM
    jztacoma
    Upstate NY
    Semi Stockish
    Yeah if you are nose high might have to loosen them a bit. But it will def ride rougher the closer you get to 3inches
  8. Mar 13, 2017 at 8:40 AM
    SocalOC
    2015 Sport
    I plan on tossing a 285 75 17 toyo under there so as long as it fits under 2.5 i wint touch them
  9. Mar 13, 2017 at 8:46 AM
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    Totally different lift. However, I have the Icon stage 2 with TC's and their AAL and wish I would of just bought the suspension components separate and then a whole new leaf spring kit (IE: Dakars or All Pro expedition) with a all pro Ubolt flip kit with timbrens bumpstops & Ext break lines. That will be my next purchase... An AAL IMO is a band-aid for the time being until you realize you want more. Buy once cry once is a common phrase used on here :D Good luck man!
  10. Mar 13, 2017 at 9:22 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    My rear fox 2.0 RR extended are still on back order. Eta is end of April.
  11. Mar 13, 2017 at 9:52 AM
    browndirtcowboy
    browndirtcowboy Well-Known Member
    Manteca
    Lucky for you My icon stage 3 setup is leaking oil after 6 months. Called Icon from the number on the website I got this number has been disconnected. Icon=fail
    Midknight and Joe23 like this.
  12. Mar 13, 2017 at 9:54 AM
    AgedFlatulence
    AgedFlatulence Well-Known Member
    SoCommiefornia
    16 TRD OR DCSB 4x4 Quicksand
    OVTune 4.88 Kings remote w/adjustment Add a Leaf 2"lift RCI Skids RCI Differential Cover RCI lower A arm covers Demello sliders Snugtop windoors Yakima Skyline TRD Pro Grill knockoff 265r75/16 Falken ATW3 Anytime camera Recovery gear
    I have some Fox 2.0 rear w/RR for sale. Had them on less than a month, never went offroad and the braided line blew out. Selling cheap!
  13. Mar 13, 2017 at 10:02 AM
    SocalOC
    2015 Sport
    Icon is down the street from me so that played a big factor for me but i dont like waiting so i guess it helpped me out this time
  14. Mar 13, 2017 at 2:36 PM
    synaps3
    synaps3 [OP] Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    The kit comes with shocks...
  15. Mar 13, 2017 at 2:38 PM
    #35
    synaps3
    Dave
    Los Alamos, NM
    This is all good feedback, thanks. I'll definitely make sure to at least put some weight back there.
    Are either of you running extended brake lines in the rear with the kit, or are the stock ones fine?
  16. Mar 13, 2017 at 3:12 PM
    #36
    synaps3
    Dave
    Los Alamos, NM
    Marie just answered, and I should have just read the product page "Kit includes the following... Extended length rear brake lines"
    I'm going with the Dakar packs, placing the order now. I'll reply back with my impressions.
  17. Jun 28, 2017 at 10:37 PM
    #37
    Rileyk700
    Rileyk700 BigRedMachine
    Carl
    2017 Tacoma Off-Road
    Fox 2.5 lift. Pelfrey built rear bumper.
  18. Jun 29, 2017 at 8:41 AM
    #38
    synaps3
    Dave
    Los Alamos, NM
    We just had a baby, so the parts are in my garage. Nothing yet, sorry. :)
  19. Jun 29, 2017 at 12:47 PM
    #39
    Rileyk700
    Carl
    Congrats on the baby!! Thinking about getting the same kit minus the baby. Lol
    Cascade_Concrete and synaps3[OP] like this.
  20. Jun 29, 2017 at 12:50 PM
    #40
    synaps3
    Dave
    Los Alamos, NM
    We're closing on a new house tomorrow, so it'll probably be at least a few weeks. Don't wait up on my feedback. :ballchain:
    Babies aren't too bad. Makes you appreciate your family and spouse more. Long-term, I've got two camping buddies too. I keep telling my older son (he's 3) that he'll get my truck as his first car in another 12 years. I'll need an excuse to upgrade to a gen 5 then anyways. :thumbsup:
    Rileyk700 likes this.
