Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Mar 2, 2020 at 10:05 AM
    #2181
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    -Measuring the shock like you mentioned will need to be done with the full weight of the vehicle on the coilover, not sitting on the ground. Odds are, the old setup will not be lifted, so matching to that height isn't ideal. Also, not sure why you referenced "stock LCA's", meaning stock lower control arms?
    -Adjusting the preload nut at the very least needs to have the weight of the vehicle OFF the shock. Adjusting that preload nut with a 600lb spring will be extremely difficult, dangerous and you will most likely damage the aluminum preload nut. When we do installs here in the shop, we will install the coilovers as is... drive it around the block, bring it back in and remove the coilovers to adjust preload. We have a heavy duty spring compressor we use when adjusting preload. I'm aware this is not always an option for most.
    -Every truck is different, weighs different and will require its own amount of preload to get the lift height you want. Threads showing will also depending on shock brand and spring length/rate.
  2. Mar 2, 2020 at 10:07 AM
    #2182
    AccuTune Offroad
    El Cajon, CA
    Are the front 2.5 Coilovers extended travel? If they are, you can simply add more preload to the spring. Not necessary to swap out to a longer spring. Longer spring does not increase lift height, it will just decrease the amount of preload needed to achieve X height.
  3. Mar 2, 2020 at 12:58 PM
    #2183
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    Thanks for your help with this and for answering my questions. This is how much preload I have now on the driver's side. There is less on the passenger side but not by much. Do you still think it's still ok to add more preload? If you think it's ok I'll leave the 13" springs on but if you think I will benefit from longer springs I'm ok with having them swapped out since I have them sitting in my garage. Don't get me wrong, I wouldn't mind selling them to put $$$ towards mountain bike gear.
  4. Mar 2, 2020 at 1:03 PM
    #2184
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    10-4, thanks.
  5. Mar 2, 2020 at 1:07 PM
    #2185
    AccuTune Offroad
    El Cajon, CA
    What is the shock length measurement from top of the top cap to lower shock bolt? (sitting at ride height on level ground)
  6. Mar 2, 2020 at 2:03 PM
    #2186
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    What did you use to mount your rear resi's? Mine are piggy backed and i hate it.
  7. Mar 2, 2020 at 2:18 PM
    #2187
    AccuTune Offroad
    El Cajon, CA
    You have Fox piggyback rear shocks?
  8. Mar 2, 2020 at 3:28 PM
    #2188
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Probably very old steel bodied 2.0's that are inverted. I've seen a few of them on 05+ tacoma's
  9. Mar 2, 2020 at 3:47 PM
    #2189
    Russty__
    Russ
    Maryland
  10. Mar 2, 2020 at 4:19 PM
    #2190
    AccuTune Offroad
    El Cajon, CA
  11. Mar 2, 2020 at 6:08 PM
    #2191
    Russty__
    Russ
    Maryland
    I dont like that they have the chance of rubbing on things (Ive had to adjust them probably 5 different times from rubbing on other parts of the truck) the Resi's are getting beat up by trail use. Id rather have them up out of the way from everything.
  12. Mar 2, 2020 at 8:58 PM
    #2192
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Those look sweet. Make sure to post pics when installed. Also what did you go with for the rear and what time did you go with?
  13. Mar 2, 2020 at 9:24 PM
    #2193
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    A new extended resi hose that mounts the resi to the frame will solve your issue. I have fixed many of those shocks because the shock rotates and gets caught under the frame, it happens on 4runners and Tacoma's.
    Russty__[QUOTED] likes this.
  14. Mar 2, 2020 at 9:58 PM
    #2194
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Yeah, as others have mentioned you have the 2.0s. I've got 2.5s mounted with the mount/clamps that came with them (drilled to frame) but I'm sure a universal would work. I've seen a couple folks on here chaff or pinch a line on those 2.0s. Theres a piggy back shock out there somewhere that I've seen.
  15. Mar 3, 2020 at 5:40 AM
    #2195
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Will do! The rears are 2.0RR with Dakar/cs047’s.
  16. Mar 3, 2020 at 7:58 AM
    #2196
    sicki
    sicki Well-Known Member
    Does anyone else think that might be too much preload? shocks might be close to fully extended at ride height no?
  17. Mar 3, 2020 at 8:11 AM
    #2197
    AccuTune Offroad
    El Cajon, CA
    Yes, thats why I asked for measurements from top of top cap to center of lower shock bolt. Looks excessive, but maybe it's a heavy truck. Threads showing can be deceiving
    sicki[QUOTED] likes this.
  18. Mar 3, 2020 at 7:43 PM
    #2198
    TheBlueBeast15
    Kevin
    H-Town
    Nice. What are your first impressions with just the rears on? And there was a typo in my last post. What tune did you decided to go with from accutune?
  19. Mar 4, 2020 at 11:03 AM
    #2199
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Don't know if it's been posted before but I just replaced the lower bearings (LCA/Shock attachments) on my Fox 2.5 coilovers. The bearings were labeled FKS10T if anyone looking to do the same needs p/n info to order. Saw them available at Summit for less $$$ than I paid from DSM.
    Russty__, TVH475 and sicki like this.
  20. Mar 4, 2020 at 4:53 PM
    #2200
    Russty__
    Russ
    Maryland
    Rite rite, i think the hose is long enough its just figuring out a bracket solution to mount to the frame I suppose.
    boston23 likes this.
