Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. May 18, 2020 at 10:55 AM
    #2421
    EatableTaco
    EatableTaco NoDak
    Ben
    Williston, ND
    2017 Black Tacoma TRD Sport DCSB
    Yesterday the line on my rear shock 2.0 w/ remote (no adj. resi) Took a Sh*!. Started leaking really for no apparent reason. (Maybe 2k miles on them) No rubbing, no flexing, and definitely no abuse. I can't for the life of me figure it out. It's not loose. I checked. Lost all the fluid on my garage floor. Bottom line... Hose leaked. Gotta send it in for warranty work. So, looking for a replacement in the meantime, as it's my DD. I'm not against buying a brand new one and having a spare in the end. Just looking for the best deal I can find. Anyone have one laying around? Or, know where there is a great deal on picking up a new single replacement?
    2017 DCSB 4X4
    Toytech 1.5"-2.5" Progressive 3 leaf AAL
    FOX 2.0 w/remote reservoir 985-24-117
  2. May 18, 2020 at 12:26 PM
    #2422
    fkLymphoma
    fkLymphoma Well-Known Member
    Seth
    2020 Cement Tacoma OffRoad
    Anyone have a Fox Lift and replace their coil with something to enable a 3" lift and handle weight of some armor?
  3. May 18, 2020 at 12:33 PM
    #2423
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
  4. May 18, 2020 at 8:57 PM
    #2424
    jaymz25
    jaymz25 Well-Known Member
    Edward
    2020 Midnight Black Metallic Tacoma TRD Pro
    if you are looking to stick with the pro fox oem suspension. i am replacing my 1 month old trd pro fox suspension less than 500 miles next week. will sell it as a set though
  5. May 19, 2020 at 1:50 AM
    #2425
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    may i ask what you are replacing it with. i dont think i will stick with fox, got an email out to fox for a replacement coil, but dont expect to hear back.
    what would equal the ride quality of my current Pro fox front setup, thanks
  6. May 19, 2020 at 2:43 AM
    #2426
    bludweiaer
    pa
  7. May 19, 2020 at 3:32 AM
    #2427
    jaymz25
    Edward
    going with 33 tires and bigger offset. don't want to use spacer to achieve 3" and the one that i will get is the coilover with resevoir and adjustable dsc
  8. May 19, 2020 at 8:30 AM
    #2428
    Tyler Andrews
    Tyler Andrews Well-Known Member
    Tyler
    Portland
    2018 Super White Sport 4x4
    Been watching this fox thread (Along with some others) for a while now. Gotta say, I'm inches from pulling the trigger on the 2.0 setup. I haven't gotten a solid answer yet so I thought I would just ask. Straight out of the box without any adjustments, are you guys running a differential drop to offset any positive angles on your CV's? My understanding is that out of the box will provide roughly 1' of lift, doesn't seem like it would require a differential drop but unsure on how much the 2.0 setup will affect the CV angles.
    Other question, are you guys running any rear lift option when just using the 2.0's out of the box without any adjustment? Looking for a level stance since I don't tow or put much weight in the bed. Thanks!
    m603holden likes this.
  9. May 19, 2020 at 8:49 AM
    #2429
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Just to play devil's advocate, if you're looking at the 2.0 fox's, have you also looked into the bilstien 6112/5160?
  10. May 19, 2020 at 3:05 PM
    #2430
    Tyler Andrews
    Tyler
    Portland
    Yeah I've looked at that setup, and ran 5100's on my first gen for over 6 years. Mostly curious in trying another manufacturer, I also remember the 5100's being pretty stiff (Eventhough the 6112/5160 would probably be a little more forgiving than the 5100's.)
  11. May 19, 2020 at 4:03 PM
    #2431
    m603holden
    Marteeen
    New England
    The 6112 have a 60mm piston vs what is probably around a 43mm piston for the fox. Plus paired with the 5160 in the rear with the resi might be a better route for that price point.
    Fox will try to push the ifp but it's still a 2.0. I think a lot of that goes to brand at that level for them. It's stuff over recently looked into for a sole purpose trail truck.
    Those and the dobsons.
    I don't think I'd go fox until their 2.5 line. Just a personal preference.
  12. May 19, 2020 at 4:25 PM
    #2432
    Tyler Andrews
    Tyler
    Portland
    Thanks for the points you provided, all makes sense. I believe with the type of driving I do the 2.0's would be more than adequate.
    Still curious for answers to my original questions!
    m603holden[QUOTED] likes this.
  13. May 19, 2020 at 4:32 PM
    #2433
    m603holden
    Marteeen
    New England
    Won't need a duff drop. A carrier bearing drop is used at higher lifts
  14. May 19, 2020 at 8:09 PM
    #2434
    1TACOTONY
    1TACOTONY Well-Known Member
    Tony
    MICHIGAN
    2017 Inferno TRD Sport 4x4 M/T
    MISC. MODS WEBOOST overland cell booster Blacked out badges Black bedside decal Uptop overland alpha roof rack with inferno armortek and baja designs scenelighting EYECATCHER PRO Tacoma tailgate letter inserts Trd Pro grill with raptor lights(REMOVED) DB CUSTOMS Toyota halo grill with backlighting TRD color match grill badge Color matched Trd Pro shifter Tinted windows Front and Rear MBRP 3" side exit exhaust w tip OCD center console organizer Meso Customs Flip Fob Key Meso Customs blacked out climate control rings Meso Customs blacked out vent rings Meso Customs blacked out 4x4 ring Meso Customs coin organizer M/T Meso Customs blacked out steering wheel emblem overlay Meso Customs blacked out handle covers Meso Customs Overhead hex rack (sunroof model) KTJO4X4 HUD FOR TACOMA Trd pro skid plate Tufskinz glovebox insert ch4x4 custom switches w/ cubby panel Lil B's bed stiffeners with bottle opener Inferno Door sill guard inserts Rear passenger dual USB charge port Rear window switch relocation mod Taco Time plate frame AVS low profile in channel vent shades URD short throw shifter kit Cravenspeed Gauge mount JLT oil catch can N2 Designs remote start with smartphone module Trailer hitch step guard with locking pin Hondo garage unholy mount with ohnap magnetic mounts(driver and passenger side) Diamondback HD smooth bed cover Uptop Overland Diamondback truss rack system Ikamper Skycamp 3.0 mini with insulation liner Wolfbox G900 mirror and dashcam front and rear camera Seat jackers front and rear driver and passenger side Front seat jacker multi panel mounts driver and passenger side ////// (AWAITING ARRIVAL) None at this time (AWAITING INSTALL) Uptop overland rack lights dual function white and amber x8 /////// SUSPENSION COMPONENTS FRONT Fox 2.5 extended travel coilover remote resi with adjuster and added protection for the reservoir Sway bar relocation kit Spc adjustable uca (removed) Icon billet UCA Durobump bumpstops Runnin 4 Tacos lower control arm skids REAR Fox 2.0 extended travel remote resi with adjuster and Fox roost guards Toytec (Deaver)3 leaf progressive aal Durobump 4.25 bumpstops with Ubolt flip kit ///// WHEELS AND TIRES FN FX Pro matte black w import equipment center decal BFG KO2 285/70/17 ///// AUDIO Stinger Heigh10 10in multimedia display w/ tacoma flush mount integration kit and wireless AA adapter OEM Audio Reference 450Q w/ subwoofer Soundskin Pro sound deadening doors,panels,counsol and rear wall ///// LIGHTING Rigid Radiance+ Amber backlighting 30" Hidden Bumper Light Bar Rigid Radiance Scene pods with amber backlighting Morimoto XB Led projector Gen 2 Black headlights with sequential turn signal MESO Customs/ Morimoto led sequential tail lights Morimoto XB Led projector fog lights Meso Customs blacked out ultimate turn signals (REMOVED) Meso Customs blacked out ultimate v5 turn signals with white drl and sequential turn signal (INSTALLED) Meso customs puddle lights w switch TRD pro tail lights Mic tuning 2 bar triple row tailgate bar with brake,reverse and sequential turn VLed upgrade vanity lights Meso Customs ultimate map light Meso Customs dual brightness cab light Led upgrade turn,brake,side markers and plate lights (changed to meso customs headlight and taillights) Import equipment 3rd brake light cover Raptor grill lights (REMOVED WITH PRO GRILL) KTJO4X4 door handle lighting Yota mafia KC hilites v2 rock light 6 light kit with auto on feature UPTOP Overland Underhood lighting with Baja designs pods Baja designs rock lights with scenepods 2.0 for roof rack
    @Tyler Andrews the 2.0s are a pain to adjust because a spring compressor is needed due to them being aluminum and will destroy the shock without compressing the spring. If your looking for adjustability i highly recommend the 2.5s being as you can adjust them easily on the vehicle and get them right where you want. I am a bit biased seeing as I have the 2.5s but a big reason I went with them was to be able to fine tune the suspension to the height and ride quality I am looking for at any given time. My truck sits pretty level with the setup I have and where I have it set and the ride is amazing. I have some pics in my profile album if you wanna check it out or would be happy to post some more on here if interested. Hope whichever you choose you are happy with it and enjoy it as I do mine :fistbump:
    Tyler Andrews likes this.
  15. May 19, 2020 at 8:38 PM
    #2435
    419DewMort17
    419DewMort17 Active Member
    Andrew
    Colorado
    2020 Super White TRD OR DCSB
    It has a nice rack
    Hey there boys and girls, I thought I'd join the party. I'm in the process of getting a FOX 2.5 kit together. Tell me I'm making a fantastic choice... I'll be combining them with Dirt King Uppers and Lowers in the front.
  16. May 19, 2020 at 8:50 PM
    #2436
    Tyler Andrews
    Tyler
    Portland
    really appreciate all of the advice and recommendations. Your truck is definitely dialed in :thumbsup:
  17. May 19, 2020 at 9:10 PM
    #2437
    1TACOTONY
    Tony
    MICHIGAN
    I only offer opinion based on my hrs of research and reading on this forum but if it helps I'm happy. Also thank you on the compliment. I have spent alot of time along with put a hurtin on the wallet:rofl: but all well worth it in my eyes:notsure:. It is slowly becoming all of what I wanted it to be from the day I bought it so it feels pretty good. Just know whatever you do go with we all wanna see some pics of the newly lifted taco :thumbsup:
    Tyler Andrews[QUOTED] and TVH475 like this.
  18. May 19, 2020 at 9:16 PM
    #2438
    1TACOTONY
    Tony
    MICHIGAN
    @419DewMort17 Fantastic choice :fistbump:. What made you want to go with the dirt king upper and lowers out of curiosity? Also like I said to @Tyler Andrews make sure you post up pics when you get the everything installed. Always enjoy seeing all the different setups and sharing the joy of having the best trucks on the road:bananadance::rofl:
  19. May 19, 2020 at 9:39 PM
    #2439
    419DewMort17
    Andrew
    Colorado
    It has a nice rack
    Jumped in on a group buy I found on this forum. Also, I had Total chaos uppers on my 3rd gen 4runner and I absolutely hated them. Going with dirt kings and fox because, you know.. go big or go home.
  20. May 19, 2020 at 9:52 PM
    #2440
    1TACOTONY
    Tony
    MICHIGAN
    Gotta love this forum for them group buys for sure,helps us all save money :D. You say go big or go home does that mean you are going with the dirt king long travel kit? I have seen a few long travel setups and it seems kickass but was a bit out of my price range for everything needed to put it together. If you are going that route props to you and that is for sure gonna ride smooth over the whoops. What size wheel and tire are you planning for your lift.
