Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Aug 31, 2020 at 10:47 AM
    #2601
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Yes, pretty straight forward.
  2. Aug 31, 2020 at 10:51 AM
    #2602
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    Thanks!!
  3. Aug 31, 2020 at 8:12 PM
    #2603
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Anyone know where to order new lower shock bearings. It’s the bearing that the lower shock bolt goes through to anchor it to the lower control arm.
    fox 2.5 ext travel
    Coilover on a 2011 double cab.
  4. Aug 31, 2020 at 8:24 PM
    #2604
    Tacompa
    San Jose, CA
    Call fox and ask them for the part number you need, then you can search for it online. I found what I was looking for with quick turnaround from summit racing.
  5. Aug 31, 2020 at 8:26 PM
    #2605
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    save up for 2.5 or you will be sorry
  6. Aug 31, 2020 at 8:27 PM
    #2606
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Pretty sure I have 2 of them.
  7. Aug 31, 2020 at 8:29 PM
    #2607
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Let me
    Know
  8. Sep 1, 2020 at 7:04 AM
    #2608
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    gordi[QUOTED] likes this.
  9. Sep 1, 2020 at 7:24 AM
    #2609
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I stock them.
    https://www.303shockservices.com/product-page/com10t-bearing-kit
    Use TW10 for an extra 10%
  10. Sep 1, 2020 at 7:35 AM
    #2610
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  11. Sep 1, 2020 at 2:26 PM
    #2611
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    I've found my 2.5 DSC run alot nicer now with added weight. They were pretty jarring without any armor. Ironically I've heard they come valved off the shelf too soft. Anyone else find this to be the case for them too?
  12. Sep 1, 2020 at 6:23 PM
    #2612
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    I find some weight helps to ride smoother. Where did you have the low speed knob before the weight? Seems I need to run 1 or 2 clicks from fully open.
    zippo88[QUOTED] likes this.
  13. Sep 1, 2020 at 7:45 PM
    #2613
    zippo88
    L
    2012 sport
    I've run them fully open since install anything else seems too harsh. Only hit front bumps a couple times I also have rear 2.0 with low speed adjuster/iconrxtleafs/timbren bumps in the back. I've since removed my sway bar and found that closing the adjusters a few clicks help with body roll alot
  14. Sep 1, 2020 at 7:46 PM
    #2614
    zippo88
    L
    2012 sport
    What stops you from running them fully open? Nose dive or body roll issues?
  15. Sep 1, 2020 at 8:50 PM
    #2615
    cmbondo
    San Diego CA
    Seems fully open is too soft for me. It's hard to explain but it's like it's harsh because it's too soft.
    I will say that getting a new rear spring pack and going from 2.0 to 2.5 DSC also helped.
    OhioTXbaja and zippo88[QUOTED] like this.
  16. Sep 2, 2020 at 7:56 AM
    #2616
    AccuTune Offroad
    El Cajon, CA
    Every truck and driver ride quality preference is different. We can definitely help the shocks perform better with our custom valving. In certain occasions we can even revalve the DSC. We usually valve the shocks to be nice and soft with DSC open, then customers can stiffen it up from there.
  17. Sep 2, 2020 at 9:09 AM
    #2617
    zippo88
    L
    2012 sport
    That sounds like a good way of making things work. Do you guys sell a rebuilt kit for fox 2.5 DSC and fox2.0 resis with adjusters?
    I'd like to do the rebuild/revalve myself. I've contacted fox and never got a reply :annoyed:
  18. Sep 2, 2020 at 9:26 AM
    #2618
    AccuTune Offroad
    El Cajon, CA
  19. Sep 2, 2020 at 4:14 PM
    #2619
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  20. Sep 2, 2020 at 7:28 PM
    #2620
    CBrob
    CBrob Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    What is the difference between factory series and performance series?
