Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Sep 1, 2020 at 7:04 AM
    #2621
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    gordi likes this.
  2. Sep 1, 2020 at 7:24 AM
    #2622
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I stock them.
    https://www.303shockservices.com/product-page/com10t-bearing-kit
    Use TW10 for an extra 10%
  3. Sep 1, 2020 at 7:35 AM
    #2623
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
  4. Sep 1, 2020 at 2:26 PM
    #2624
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    I've found my 2.5 DSC run alot nicer now with added weight. They were pretty jarring without any armor. Ironically I've heard they come valved off the shelf too soft. Anyone else find this to be the case for them too?
  5. Sep 1, 2020 at 6:23 PM
    #2625
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    I find some weight helps to ride smoother. Where did you have the low speed knob before the weight? Seems I need to run 1 or 2 clicks from fully open.
    zippo88 likes this.
  6. Sep 1, 2020 at 7:45 PM
    #2626
    zippo88
    L
    2012 sport
    I've run them fully open since install anything else seems too harsh. Only hit front bumps a couple times I also have rear 2.0 with low speed adjuster/iconrxtleafs/timbren bumps in the back. I've since removed my sway bar and found that closing the adjusters a few clicks help with body roll alot
  7. Sep 1, 2020 at 7:46 PM
    #2627
    zippo88
    L
    2012 sport
    What stops you from running them fully open? Nose dive or body roll issues?
  8. Sep 1, 2020 at 8:50 PM
    #2628
    cmbondo
    San Diego CA
    Seems fully open is too soft for me. It's hard to explain but it's like it's harsh because it's too soft.
    I will say that getting a new rear spring pack and going from 2.0 to 2.5 DSC also helped.
    OhioTXbaja and zippo88 like this.
  9. Sep 2, 2020 at 7:56 AM
    #2629
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    Every truck and driver ride quality preference is different. We can definitely help the shocks perform better with our custom valving. In certain occasions we can even revalve the DSC. We usually valve the shocks to be nice and soft with DSC open, then customers can stiffen it up from there.
  10. Sep 2, 2020 at 9:09 AM
    #2630
    zippo88
    L
    2012 sport
    That sounds like a good way of making things work. Do you guys sell a rebuilt kit for fox 2.5 DSC and fox2.0 resis with adjusters?
    I'd like to do the rebuild/revalve myself. I've contacted fox and never got a reply :annoyed:
  11. Sep 2, 2020 at 9:26 AM
    #2631
    AccuTune Offroad
    zippo88 likes this.
  12. Sep 2, 2020 at 4:14 PM
    #2632
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  13. Sep 2, 2020 at 7:28 PM
    #2633
    CBrob
    CBrob Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    What is the difference between factory series and performance series?
  14. Sep 2, 2020 at 8:22 PM
    #2634
    RangerComa
    RangerComa 58008
    Adam
    Bay Area, CA
    17 DCLB
    list is growing fast
    CBrob likes this.
  15. Sep 4, 2020 at 12:31 PM
    #2635
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    How long does it take for fox 2.5 coilovers and tundra rear shocks to settle? Also, how much ride height reduction should I expect?
  16. Sep 4, 2020 at 3:22 PM
    #2636
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    SoCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    couple of weeks, I think mine settled in around 10 days. Lost maybe 10%, if that. Probably less. I think it depends on how much preload you put on.
    front coils settle. Rear shocks won’t settle, new leaf pack or add a leaf will in the rear
    Island Cruiser likes this.
  17. Sep 4, 2020 at 5:56 PM
    #2637
    Tacompa
    San Jose, CA
    I'm on Fox 2.5 coilovers with dsc (14" 650 lb spring) and I'm currently sitting at 3.5" and 3.75" center hub to fender. Should I adjust them down to 3.0" on both sides or leave them at 3.25" so they settle to 3.0"? I want a 3" left in the front.
  18. Sep 4, 2020 at 8:39 PM
    #2638
    RangerComa
    RangerComa 58008
    Adam
    Bay Area, CA
    17 DCLB
    3” over stock height on a 3rd gen is too much. You should stay at 2” above stock height or less. You’re ride will suffer. You don’t want that now do you.
  19. Sep 4, 2020 at 9:06 PM
    #2639
    Tacompa
    San Jose, CA
    Clarifying my previous post.
    Stock I was sitting at 21" and 21 1/8".
    After lift I'm at 23 1/2" and 23 3/4". In the end I want a 3" lift upfront (2" over stock). My question is since there seems to be a settling effect on the coilovers should I...
    A. Shoot for 3"
    B. Shoot slightly higher than 3" to compensate for the settling effect?
    I'm totally new to this please excuse the ignorance.
  20. Sep 5, 2020 at 2:25 PM
    #2640
    cmbondo
    San Diego CA
    I suggest reading this.
    https://accutuneoffroad.com/articles/tacoma-4runner-coilover-preload-faq/
    Tacompa likes this.
