Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Feb 27, 2021 at 4:29 PM
    #2881
    1E7DCSB
    1E7DCSB Well-Known Member
    NH
    OME EL095R, no blocks, super bumps, wheelers extended brake lines and ubolt flip kit
    Don’t have any pictures on my phone
  2. Feb 27, 2021 at 4:44 PM
    #2882
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Just took a close look at those rear dampeners.. pretty much entry level disposable stuff. Doesn't seem to be well matched for the rest of your rear suspension.
  3. Feb 28, 2021 at 7:04 AM
    #2883
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    i have the close to the same set up in the rear (I’m on the 9.6 inch travel fox 2.0), everything else is the same. Mine lasted 55k miles on some serious wheeling and desert running. Just started leaking driver side this month. And not from bottoming out, it’s leaking from the hose next to the cd adjuster. I have about an inch of shock travel that’s never been used because of the superbumps and flip kit. I liked this set up personally.
    TacoSurfer27 likes this.
  4. Mar 6, 2021 at 6:41 PM
    #2884
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    howd you get the ifp out? compressed air into where the hydraulic fitting goes? theres no 1/4-20 threads on the nitrogen fill side that i was expecting to see.. just a plastic honeycomb looking shitty plastic ifp haha
  5. Mar 6, 2021 at 7:00 PM
    #2885
    zippo88
    L
    2012 sport
    just to save you from some potential damage.. I personally placed the piggyback reservoir on the other side of the shock body... at full compression you may smash your axle into the piggyback resi where its currently mounted!
  6. Mar 6, 2021 at 7:11 PM
    #2886
    zippo88
    L
    2012 sport
    Do you by chance know the IFP depth for these coilovers?
  7. Mar 10, 2021 at 10:50 AM
    #2887
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    i feel like im always spending money :rofl:
    if im adding a bumper and winch will the coils that come with the 2.5s sag alot? i really dont feel like buying new coils..
  8. Mar 10, 2021 at 10:55 AM
    #2888
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    coopcooper[QUOTED] likes this.
  9. Mar 10, 2021 at 10:58 AM
    #2889
    coopcooper
    alberta canada
  10. Mar 10, 2021 at 11:11 AM
    #2890
    AccuTune Offroad
    El Cajon, CA
    You are right in the middle since the standard spring comes with a 13" x 600lb spring. A 14" x 600 spring may be something you want to look into in the near future. What year truck?
  11. Mar 10, 2021 at 11:15 AM
    #2891
    coopcooper
    alberta canada
    2005 tacoma
  12. Mar 10, 2021 at 12:34 PM
    #2892
    AccuTune Offroad
    El Cajon, CA
    Got it, I would run it as is, adjust preload a bit if needed.
    ARoman83 and coopcooper like this.
  13. Mar 10, 2021 at 4:53 PM
    #2893
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I've adjusted preload several times and didn't gain much. It's weird. I know preload != lift but about an inch of more preload has barely given 1/4" and I've got a hell of a rake. But looks like a 14" spring is in the works. I'm looking at Eibach. How much would you expect for a shop to do the swap?
  14. Mar 10, 2021 at 5:30 PM
    #2894
    scottiedeaks
    scottiedeaks Member
    2010 DCLB Sport
    Im looking for some info for the Fox 880-02-418 regarding pre load not sure if anyone can clarify.
    I just picked up a set for my truck and noticed there was only about 1 and 1/2 inches of pre load. I contacted Fox and they told me I should only add another 1/2 inch of pre load. I have read that some of you guys are putting 2.9 inches of pre load on your shocks which is way more then Fox recommended me to do.
    Does anyone have a proper measurement for what is safe as well as getting the most lift out of the shocks.
  15. Mar 10, 2021 at 5:36 PM
    #2895
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    All of your questions answered here:
    https://accutuneoffroad.com/oem-front-coilover-shock-setup/
    AccuTune Offroad likes this.
  16. Mar 10, 2021 at 5:41 PM
    #2896
    cmbondo
    San Diego CA
    Invest in a good set of spring compressors for about $60 and do it yourself. I just reassembled mine last weekend after a rebuild to install on my new truck. If you can remove them yourself (which also is not hard) you can do it...safely.
    Edit: I recommend these or similar. They are very sturdy and get the job done with ease. I never felt unsafe using them.
    https://www.amazon.com/dp/B08MQPF6M3/ref=cm_sw_r_cp_apa_fabc_RPNSN52B1470881QSMXZ?_encoding=UTF8
    CAG Gonzo[QUOTED] likes this.
  17. Mar 11, 2021 at 7:19 AM
    #2897
    AccuTune Offroad
    El Cajon, CA
    So you cranked down the preload nut 1" further than where it was originally and only got 1/4" lift? Something is definitely wrong there.
    ARoman83 likes this.
  18. Mar 11, 2021 at 8:17 AM
    #2898
    CAG Gonzo
    2018 OR DCLB BarRed
    Roughly, yes. I got increased lift while the truck was raised and after I lowered it, but once it settled after a quick test drive a lot of that lift was gone. It was maybe 37 3/4" ground to fender before settling and around 36 1/2" after. Visually, it looks like no change though I did measure and got roughly 1/4" more. I think I only have a few more threads to expose before I hit 2" of preload.
  19. Mar 11, 2021 at 8:53 AM
    #2899
    AccuTune Offroad
    El Cajon, CA
    Threads showing does not equal preload. Take a look at this article, may help clear up some things:
  20. Mar 11, 2021 at 9:04 AM
    #2900
    CAG Gonzo
    2018 OR DCLB BarRed
