Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Oct 22, 2021 at 8:15 PM
    #3241
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Aw man now I'm concerned.
  2. Oct 22, 2021 at 8:18 PM
    #3242
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    I was thinking it was normal but I still haven’t been able to get the “driving on clouds” feeling from my shocks I feel the ride is a bit harsh and I tried everything (c-load tires, “low” air pressure, torqued to spec everything, eye to eye 21”)
    So I was wondering if that sound means it’s time for a rebuild.
  3. Oct 22, 2021 at 8:41 PM
    #3243
    kazuaki
    kazuaki Well-Known Member
    2015 Tacoma DCSB 4x4 TRD Off Road
    I've heard that sound on some cars before, but we just installed Fox 2.5 DSC's front and back from Accutune and I have NOT noticed that noise.
  4. Oct 22, 2021 at 9:43 PM
    #3244
    chuymoreno
    El Paso, Texas
    Tacoma SR5
    My shocks are also tuned by accutune even on the softest setting they are a bit harsh and I don’t feel much a difference from softest to firmest.
    I do have a lot of miles on the shocks so that’s why I was wondering if it’s time for a rebuild only thing keeping me from sending them is that I have no evident leaks
  5. Oct 22, 2021 at 9:43 PM
    #3245
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    I have @AccuTune Offroad tuned Fox 2.5s as do 2 of my friends. All 3 make the "woosh" noise going over speed bumps.
    chuymoreno[QUOTED] likes this.
  6. Oct 23, 2021 at 5:23 AM
    #3246
    Bishop4WD
    Bishop4WD Well-Known Member
    San Diego until I escape Communist California
    2019 MGM Off Road
    I feel like I've heard that from time to time as well.
  7. Oct 23, 2021 at 8:05 AM
    #3247
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Anyone have any advice on rebuilding a 2.0 with 5/8" shafts? I have one leaking and it's in need of a rebuild.
    Saskabush likes this.
  8. Oct 23, 2021 at 8:27 AM
    #3248
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    @AccuTune Offroad is the 21" max measurement from the top hat to center of coilover eyelet impacted by the amount of gas in the tank (i.e empty vs full)? If so, at what tank capacity should the measurement be taken?
  9. Oct 25, 2021 at 6:59 AM
    #3249
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Sounds pretty normal, however based on your other comments shoot us a message and we can dive in deeper to diagnose some things.
  10. Oct 25, 2021 at 7:00 AM
    #3250
    AccuTune Offroad
    El Cajon, CA
    Yes, if your Fox shocks are not fully charged with Nitrogen (200PSI), the ride height may not be accurate. You will need a special gauge and needs to be measured at full extension
  11. Oct 25, 2021 at 11:37 AM
    #3251
    Tacompa
    San Jose, CA
    Sorry I meant my truck's gas tank or does the weight of the car have any bearing on the measurement?
  12. Oct 25, 2021 at 11:48 AM
    #3252
    AccuTune Offroad
    El Cajon, CA
    Doesnt matter. However its common to have different preload amounts from driver to passenger to compensate for uneven weight up front aka "Taco Lean". Obviously the truck wont weigh exactly the same 100% of the time, but usually that fluctuating weight is only in the rear.
    Tacompa[QUOTED] likes this.
  13. Oct 29, 2021 at 11:33 AM
    #3253
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    @AccuTune Offroad Hi,
    I want some Fox coilovers for a new LT kit I'm getting, Marlin Crawler's RCLT 2.75" Long Travel.
    Marlin said to get the Fox 880-02-953.
    I'm heavy 700-1000lbs and currently running 6112's with 700# springs and like it.
    Front and rear steel bumpers, winch, full armor, 2 aux batt, fridge/freezer, shell, awning, extra 10gal gas, 20gal h2o.
    I'd like to get the ones with the DSC adj, 880-06-953.
    Think I want to stick with 700# coil springs and get the Dual Sport Tune.
    Can you PM me with price, availability and any suggestions?
    I'm not going to change my rear shocks just yet but would like to discuss some Fox shocks for it now.
    My current rear set up: Deaver stage 3, BAMF shock relocate and HD Hangers, 14" Bilstein 7100 short body shocks w/res.
    Need shocks close to 19.5"+-.75" collapsed, 12-14" stroke.
    How would the following Fox shocks work with the 880-06-953 in front?
    Can DSC be put on these types?
    FOX-985-26-054
    Fox Shock, Eyelet Ends, 2.0 Performance Series, Remote Reservoir, 12.1" Travel, CD Adjuster - AccuTune Off-Road
    Can these use a shorter rod end and be shortened 1" to 20.18" collapsed length?
    Also, can the DSC adj be added to these?
    FOX-980-02-046
    Fox 2.0 x 14" Smoothie, RR - PreTuned | AccuTune Off-Road
    How would these work with the 880-06-953 in front?
    I like how these are made, would prefer a SS shaft, is that an option?
    What's the availability of these?
    These look like a good fit just a bit longer than I'd like.
    FOX-980-06-102-SRT
    Fox 2.5 x 12 Smoothie, RR, FS, DSC | AccuTune Off-Road
  14. Oct 29, 2021 at 12:58 PM
    #3254
    AccuTune Offroad
    El Cajon, CA
    PM sent
    PLEASE send us a message for a quote or personal questions about your vehicle
    TacoEspecial[QUOTED] likes this.
  15. Nov 10, 2021 at 11:03 AM
    #3255
    AccuTune Offroad
    El Cajon, CA
    *heads up* For those interested in getting a nice Fox suspension kit for their 05+ Tacoma, and not wanting to wait 8+ months, we are expecting a large batch of Tacoma shocks very soon. We should be able to get shocks tuned and shipped to your door by the end of the year. Rear shocks below are in stock and we can take a 50% deposit to reserve a set of front coilovers that we expect to see in a few weeks. Please shoot us a message for a quote, thanks!
    Specific shocks coming soon:
    Fox Shock Kit: 05-21 Toyota Tacoma, Front 2.5 Coilover, Remote Reservoir, UCA Required, 0-2″ Lift, 0-3″ Lift, DSC | FOX-880-06-418
    (IN STOCK) Fox Shock Kit: 05-On Toyota Tacoma Rear, 2.5 Series, Remote Reservoir, 9.4″, 1.5-3.0″ Lift, DSC | FOX-883-26-006-TACO
    Build your custom stage kit here: https://accutuneoffroad.com/product/05-tacoma-mid-travel-suspension-kit-custom/
    TacoEspecial, dpf88101 and TMFF like this.
  16. Dec 4, 2021 at 8:19 PM
    #3256
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    Just wanted to say thanks to @RangerComa :cheers: (and others) for the tips for what to do if you are a dummy and install the coil-overs without checking which way the set screw is facing. Not really fun but definitely doable.
    As others have suggested, I blasted the collar the night before with T9 and used a piece of 5/16 steel I bought at Home Depot which I cut in half and it worked like a charm. The spring compressors that I borrowed didn't fit so I used the tie-down method which worked surprisingly well. Thanks again for everyone on here providing help and feedback. The front is now perfectly level and I am at a smidge under 21" top plate to eyelet and 1.9" of thread showing. (passenger side is a little less)
    AccuTune Offroad and RangerComa like this.
  17. Dec 4, 2021 at 8:56 PM
    #3257
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Daaamm. Glad I could help haha. :cheers:That was a PITA.
  18. Dec 7, 2021 at 2:21 PM
    #3258
    AccuTune Offroad
    El Cajon, CA
  19. Dec 16, 2021 at 7:51 PM
    #3259
    cmbondo
    San Diego CA
    @AccuTune Offroad
    Any reason I can't put Fox 14x600 springs from the 4RUNNER Fox 2.5s onto Tacoma Fox 2.5s?
  20. Dec 16, 2021 at 9:45 PM
    #3260
    chuymoreno
    El Paso, Texas
    Tacoma SR5
    You shouldn’t have an issue swapping coils, I believe coils are not specific to a vehicle. You just have to choose the correct length and spring rate for the weight of your vehicle. I’m running 14” 600 springs on my truck.
