Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Apr 19, 2022 at 5:36 AM
    #3381
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I think that your best bet will be to call Accutune directly this morning. We carry Fox stuff here at Hotshot, but I know that they carry stuff at a much more granular level than the majority of us. Your next place that I would call up might be Downsouth Motorsports.
  2. Apr 19, 2022 at 6:13 PM
    #3382
    Crazyframerdude
    Crazyframerdude Well-Known Member
    Josh
    Blodgett, Oregon
    2021 Cement 4x4 Tacoma Trd off-road
    Fox 3” lift with icon uca and RXT rear leafs, 285/70/17 nitto trail grappler mt
    Thanks, tried both of those and no luck, guess I’m waiting 12-24 weeks to put my stupid truck back together.
  3. Apr 19, 2022 at 6:21 PM
    #3383
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    TacoEspecial likes this.
  4. Apr 20, 2022 at 6:24 AM
    #3384
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    what is wrong with your resi? ID scored?
    Kartek "should" have parts in stock.
    If you have the tools and knowhow you can replace just the can to save some money if your DSC is still in good shape.
    https://www.kartek.com/parts/fox-sh...e-only-clip-one-side-threaded-other-side.html
    edit: Do you need just the DSC, no resi can? I have some of those in stock.
  5. Apr 20, 2022 at 6:53 AM
    #3385
    Crazyframerdude
    Josh
    Blodgett, Oregon
    Yah the dsc got smashed by a log I got crossed up on, definitely interested in trying to piece one together
  6. Apr 20, 2022 at 7:52 AM
    #3386
    wi_taco
    Adam
    SE Wisconsin
  7. Apr 21, 2022 at 6:13 AM
    #3387
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Hurry up before I get too many miles on my setup :)
  8. Apr 21, 2022 at 6:19 AM
    #3388
    aturk
    Tony
    Charlotte, NC
    For anyone with a light truck, 2.5 DSC's, and 600lb front springs, need some advice.
    I have both low speed and high speed backed out (full counter clockwise). Low speed feels perfect (can probably go a couple clicks in), high speed can still be a little harsh. (800 miles on setup, still need to do final ride height adjustments). Rear end is perfect, fully backed out both low and high speed..
  9. Apr 21, 2022 at 7:17 AM
    #3389
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    Are your shocks tuned or off the shelf?
  10. Apr 21, 2022 at 7:22 AM
    #3390
    aturk
    Tony
    Charlotte, NC
    They are tuned. Truck definitely rides better than it did before, I just feel like there's some further optimization that can happen as there's a big difference between low speed bumps and high speed bumps. I might just need to lower the truck a half inch or so. Or could be that the low speed is set a little too soft causing the high speed to feel stiffer than it really is.
    Buttskevin21 likes this.
  11. Apr 21, 2022 at 7:23 AM
    #3391
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    What tires and PSI are you running?
  12. Apr 21, 2022 at 7:26 AM
    #3392
    aturk
    Tony
    Charlotte, NC
    265-70-17 SL tires with 32psi.
    Going 285/75/17 whenever my wheels show up, but they will be LT/Cload tires. So whatever I gain in ride quality from increased sidewall might be offset by extra ply's.
    Coming from Eibach coilovers with 14" 600lb springs.
  13. Apr 21, 2022 at 7:33 AM
    #3393
    TVH475
    Montrose CO
    I'm running your same set up & have been pretty happy with it, tire pressure is a great point, in the winter I'm mostly hwy driving I run 32, in the summer I do alot high speed dirt and lower pressure to 15-18
  14. Apr 21, 2022 at 7:39 AM
    #3394
    aturk
    Tony
    Charlotte, NC
    Yup mostly seeing just where people are running their adjusters so I can play around and see. Definitely happy with it, but if I could get 10% better or so it would be perfect. I will lower it a little bit in the next week or two to see how that changes things.
    TVH475[QUOTED] likes this.
  15. Apr 21, 2022 at 7:41 AM
    #3395
    Saskabush
    Adam
    2013 TRD Sport
    Doesn't seem like anything out of the ordinary... I've got 265/75/16 10ply KO2s running about 30PSI with my 620lb eibachs and find the ride nice. That's with 5100s too, which in theory should be stiffer than yours dialed down.
    I assume you've tried turning up the high speed compression to see if that makes a difference? I'm still waiting on my adjustable fronts from Elka but on the rear I notice that the ride can sometimes be improved by increasing the high speed compression a bit.
  16. Apr 21, 2022 at 7:46 AM
    #3396
    memario1214
    Colton
    Missoula, MT
    The rears are pretty much the only thing that we have to dial in on if someone is running with a stock bumper up front. The fronts usually have everything backed off for comfort, but the rears need some tuning to avoid that excessive chatter as you described.
    Saskabush[QUOTED] likes this.
  17. Apr 21, 2022 at 7:48 AM
    #3397
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Does high speed feel harsh on road, or offroad/aired down? It's kinda give and take. Softer high speed on road, would be too soft with tires aired down/bigger hits offroad which would put you into the bumpstop. Firm high speed on road with tires aired up, is usually pretty good offroad once aired down.
  18. Apr 21, 2022 at 7:54 AM
    #3398
    aturk
    Tony
    Charlotte, NC
    Truck has only been on-road for now. I will take it down some fast gravel roads today before it gets washed. Truck lives 99% of it's life on-road. And by no means is the high speed harsh, it just feels quite a bit different than the low speed. Which is why I'm thinking to tighten up the low speed a little bit so there's not such a huge gap.
    I have all Fox suspension on my mountain bike, it took me a long to get a tune between the front and rear that worked for almost everything perfectly. Guessing I'm just too anal and the truck will be the same way.
    I will say the rear feels absolutely mint. This is with the rear Tundra shocks, Icon RXT's at Option 1, and Archive hangers with the cross brace.
    Buttskevin21[QUOTED] likes this.
  19. Apr 21, 2022 at 10:04 AM
    #3399
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    I had the same issue running the exact same front setup. Low speed was great, high speed a bit jarring. I had the stock Fox coilovers with no tune. Switched to Kings from Accutune and solved the harsh high speed feeling. Also, added a steel skid plate which actually made a huge difference, the weight between the coilovers helps the truck stays planted over bumps.
    AccuTune Offroad likes this.
  20. Apr 22, 2022 at 5:14 PM
    #3400
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    Purchased a longer 5/16 punch from ebay. I highly recommend getting one it made adjusting the coilovers on the truck easy peasy didn't even have to take the tire off. As you can see the harbor freight one is much shorter.
    And as you can see here. The longer punch sticks out enough to adjust without the tire getting in the way. The truck was of course lifted up so coilovers weren't bearing any weight.
