Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Mar 20, 2024 at 4:21 PM
    #3901
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Based on some tech info I have, its about 1.20" of thread showing. However, the driver and passenger side likely have different amounts of preload. I can triple check tomorrow and see if we have any in stock.
  2. Mar 20, 2024 at 5:27 PM
    #3902
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Thank you, that would be greatly appreciated :thumbsup:
  3. Mar 21, 2024 at 7:15 AM
    #3903
    AccuTune Offroad
    El Cajon, CA
    Numbers were correct, just measured both sides. Both are about 1 1/8" of threads showing with a standard 13x600 spring (Fox part number: 039-26-004-A)
    backcountryj[QUOTED] likes this.
  4. Mar 21, 2024 at 8:08 AM
    #3904
    backcountryj
    Jonathan
    GA
    Thank you!! That’s actually right about were they’re set currently with the 14x650 springs.
  5. Mar 21, 2024 at 11:51 AM
    #3905
    AccuTune Offroad
    El Cajon, CA
    14x650 springs are VERY different than a 13x600.
    How much weight do you have up front on your Truck, or plan to have?
  6. Mar 21, 2024 at 11:53 AM
    #3906
    backcountryj
    Jonathan
    GA
    Bumper/winch combo is ~150#.
    Steel engine/mid skid and steel sliders. Not sure what any of those weight.
    Everything is tuned as they would have been direct from Fox, aside from the 14x650 springs.
  7. Mar 21, 2024 at 12:03 PM
    #3907
    AccuTune Offroad
    El Cajon, CA
    Right on, may be a little on the stiff side with spring rate and valving wont be tailored to those springs. Worth trying at least
  8. Mar 21, 2024 at 12:06 PM
    #3908
    backcountryj
    Jonathan
    GA
    I have some 13x600 springs on hand as well. Suppose if I’m gonna throw them on a compressor to lower the preload I could simply swap springs over to the 600s and match Fox’s OE set preload?
    What’s your professional opinion on those two scenarios given the weights mentioned above?
  9. Mar 21, 2024 at 12:31 PM
    #3909
    AccuTune Offroad
    El Cajon, CA
    I would need to know more exact weights. If you have a spring compressor available to you, then I would run whats on there now with the 650 and see how it is. You will likely need to make some subtle changes to get ride height correct, but thats pretty normal for trucks with custom mods. I would also recommend skimming through our preload article.
  10. Mar 21, 2024 at 1:08 PM
    #3910
    backcountryj
    Jonathan
    GA
    Thanks. I’ve read through most all your articles, lol.
    If I had to through more precise weights I’d say in the neighborhood of ~350# for the skids and sliders. My rig was 5400# when I weighed it last weekend with a full tank of gas.
    Rearward weight is comprised of a fiberglass camper shell (~200-250#) and ~75# of gear and tools.
    I wouldn’t quite say I have a spring compressor readily available. A neighbor that had offered to assist if needed has access to one at his work.
  11. Mar 28, 2024 at 4:43 PM
    #3911
    overlandtaco77
    overlandtaco77 Member
    Tacoma
    Is fox worth it??
  12. Mar 28, 2024 at 4:46 PM
    #3912
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Depends on what you're looking for. You want a rebuildable, tunable shock...yes, they are worth it.
    doublethebass likes this.
  13. Mar 29, 2024 at 10:14 AM
    #3913
    AccuTune Offroad
    El Cajon, CA
    What are the spacers for?
    MGMDesertTaco and SoonToBeOn39s like this.
  14. Mar 29, 2024 at 11:39 AM
    #3914
    MGMDesertTaco
    For ruining the ride quality most likely. :rimshot:
    AccuTune Offroad likes this.
  15. Mar 29, 2024 at 12:08 PM
    #3915
    AccuTune Offroad
    El Cajon, CA
    Well I did some quick searching and found the website. Unfortunately that spacer is an upsell to provide more lift to the shocks in the kit.
    MGMDesertTaco[QUOTED] likes this.
  16. Mar 29, 2024 at 1:57 PM
    #3916
    AccuTune Offroad
    El Cajon, CA
    Yes I do, very much so. Here is a link to an article we put together that dives more into spacer lifts
  17. Apr 1, 2024 at 1:33 PM
    #3917
    Codybuck93
    Codybuck93 Member
    Sexy :cool:
  18. Apr 1, 2024 at 1:34 PM
    #3918
    Codybuck93
    Codybuck93 Member
    I have a 2021 TRD Pro with Fox shocks. Like the way they ride on and off road. Haven’t done any serious off-roading yet, but very impressed with stock Fox’s on the Pro’s.
  19. Apr 3, 2024 at 8:40 AM
    #3919
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    You should call Accutune and discuss your needs/wants. They know their stuff and can guide you with knowledge. I bought mine from them and they are great! Plus you get them tuned included in the price which is no higher than anywhere else.
  20. Apr 3, 2024 at 10:09 AM
    #3920
    AShive92
    AShive92 Well-Known Member
    Andrew
    It depends on how much it is compressed. The pro shocks are internal bypasses, so they're position sensitive meaning that there is a "ride zone" roughly in the center of travel of the shock, in which the oil can bypass the piston giving a more compliant ride, but once the shock is compressed to the point of the bypass holes, the shock effectively has more damping force as the oil can no longer bypass the piston and is forced to go through the shim stack. So if you lower ride height enough you'll be at the edge of the ride zone and getting into the bump zone which will cause it to ride much more firm. Once I get my PRO shocks apart and rebuilt I'll know exactly where the ride zone is and have actual numbers to reference for ride heights.
