Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Aug 15, 2018 at 1:19 PM
    #681
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    No problem, happy to answer questions.
    Go for 650 if you have bumper/winch/sliders/skids.
  2. Aug 15, 2018 at 1:24 PM
    #682
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Aluminum bumper and steel sliders ... so 650..?
  3. Aug 15, 2018 at 1:32 PM
    #683
    *TRD*
    Carson, Ca
    I'd probably leave the 13 x 600 and see if you can get enough lift out of it. If not, then a 14 x 600. Don't think you have enough weight to justify a 650 unless you're shooting for 3" of lift (which we don't usually recommend).
    CementTRDOffRoad and beers@1600 like this.
  4. Aug 15, 2018 at 1:35 PM
    #684
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I'm sure there's someone here that can help...
    What's the longevity of Fox shocks like in a location like the Appalachians? Do they corrode badly? Will they need some sort of coating like cerakote or just a yearly or more often lube applied?
  5. Aug 15, 2018 at 1:45 PM
    #685
    fxrman
    palm springs
    Ok I was just hoping to not change the spring after install.
    I'm looking for 2 1/2" after sag up front and 2" after sag rear with the RXT on the 2nd setting.using the 2.5 extended travel front and rear.
    If that's not recommended then would 2" up front and the RXT on the #1 setting netting just under 2" in the back be acceptable..?
    Want all I can get with out having too many negative effects.
  6. Aug 15, 2018 at 2:18 PM
    #686
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I’m a 2nd gen so you’ll be heavier to start, but I have 2.5” lift with the stock 600lb coils. I have a about 125lbs extra upfront between winch and US offroad half bumper. It rides great even preloaded past foxes reccomendation. So I would assume your gonna need at minimum 14” 600lbs, and maybe even 650lbs.
  7. Aug 18, 2018 at 12:35 PM
    #687
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Fox Familia,
    This question is for 2nd Gen owners with 2.5 coilovers up front.
    If this is the way that it came from Fox..........1.925" of collar = 27 threads showing = approx 3" lift.
    Would I thread them up so it only shows 1" of collar (13 threads) if I only wanted roughly 1.5" of lift ?
    Or do I have to factor in motion ratio, etc....
  8. Aug 18, 2018 at 1:30 PM
    #688
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    You have to put them on the truck and ck...
    But just turn them and show less treads to lower the truck.....
    SUMOTNK[QUOTED] likes this.
  9. Aug 21, 2018 at 1:25 PM
    #689
    maxp4354
    maxp4354 Member
    What is the general opinion of the Level 1 kit? I sold my 5100 and wanted to go with a full kit with coilovers. I am between the level 1 and the 6112/5160 setup. My truck spends 90% of the time on pavement and commuting so I don't need the most extreme setup.
    Thanks guys
  10. Aug 22, 2018 at 1:55 PM
    #690
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    I have a Fox setup on my 3rd Gen TRD Pro.
    I am adding full skids and sliders.
    Eventually I’ll be adding aftermarket front and rear bumpers. Want to run 33s.
    I’m on 265/75/16 now which is close to 32.
    When I add all this weight, what Fox setup do you guys suggest swapping to? I’m assuming #700 coils and 2.5. But not sure if I’ll need to be adjustable or if 33s will work without chop. Really wish I could just swap coils on my existing setup and adjust for height, but doesn’t seem to be possible.
    Note*
    I have a bedrack and RTT but don’t keep mounted unless I’m camping.
  11. Aug 22, 2018 at 3:28 PM
    #691
    bowhunterRN
    bowhunterRN Well-Known Member
    Eric
    Greenville, NC
    14 MGM TRD sport DCLB 4x4
    Where is everyone buying their fox kits from? Does every vendor charge extra for the heavier/longer springs? I’m looking to buy a full kit.
    Kpatt9 and *TRD* like this.
  12. Aug 22, 2018 at 3:49 PM
    #692
    TRDandGlocks
    TRDandGlocks Well-Known Member
    Angel
    2021 TRD Off Road DCSB 4x4 Manual
    Just installed my fronts, 2.5’s with 14” 650# from @HeadStrong Off-Road. Got 2.5” on the drivers side and 3” on passengers side as it came from them. I’m going to lower the passenger side to 2.5” to make them even. Now just have to do the rear.
    Catfish21, bunz559 and Sub_Par like this.
  13. Aug 22, 2018 at 5:08 PM
    #693
    bowhunterRN
    Eric
    Greenville, NC
    Cool. Did they charge you extra for those springs?
  14. Aug 22, 2018 at 5:28 PM
    #694
    TRDandGlocks
    Angel
    They did charge me extra but it wasn’t bad. Accutune has also very good pricing with switching out springs, I just wanted the whole kit.
  15. Aug 22, 2018 at 6:11 PM
    #695
    bowhunterRN
    Eric
    Greenville, NC
    If I’m understanding it correctly, Fox doesn’t offer 14” 650lb springs as an option, so you have to buy an aftermarket spring to install. Is that right?
  16. Aug 22, 2018 at 6:38 PM
    #696
    TRDandGlocks
    Angel
    Yes that’s right, the spring is made by Eibach if I’m not mistaken, just gets reassembled.
  17. Aug 23, 2018 at 8:00 AM
    #697
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Yes, that's correct. I bought mine from Accutune with a 14" 650lb spring. My truck's current weight is a wee bit light for those springs so I have almost no pre-load with a 2.5" lift. I only have sliders for extra weight. However, I know I'll be adding skids in the future so I bumped up the rate just a touch. I would advise against 700lb coils unless you really run a TON of weight. Bumpers, sliders, skids, winch, bed rack, camper shell, etc...
    *TRD* likes this.
  18. Aug 23, 2018 at 8:00 AM
    #698
    CameHonor
    CameHonor Member
    Southern California
    2018 Toyota Tacoma TRD Sport
    TRD Skid Plate / Tweeter & Speakers Upgrade / Tinted Windows / Custom Front License Plate Holder / Flowmaster Exhuast / Etune Knobs Upgrade / TRD Pro Grille / OEM Bed Lighting /
    Has anyone just bolted the OEM 2.5" Fox's that dont require any UCAs and had any problems with alignment? I'm planning on going .5" or 1" above stock height. Which is techinally a 1.5" to 2" lift (stock 18' Tacos have 1" of lift if I'm correct?). Says front OEMs can go up to 2" and rear is 1.5" without UCAs or Leafs.
    I really just want a smoother ride on bumpy open dirt roads and potholes/dips at medium speeds. Also, I'd prefer not to change out my UCAs or leaf springs as I enjoy the stock height (wouldn't mind an extra inch) of the 18' Taco. I do not do any rock climbing or muddin'.
    If the future I may be pulling around 4000 lbs at most.
  19. Aug 23, 2018 at 9:59 AM
    #699
    Yotaholic
    Yotaholic Well-Known Member
    Oahu, HI
    2017 DCSB Sport 4x4 MT
    I’m pretty sure the pro has the same UCA’s as other trims so I don’t see an issue. I’ve seen guys run close to full 3” lift with stock UCA. I’d say go ahead and do the install with stock UCA and see how the alignment goes. If you need UCA’s, SPC Light Racing is a repuatble brand and not too expensive either.
    CameHonor[QUOTED] likes this.
  20. Aug 23, 2018 at 7:50 PM
    #700
    gadogad
    gadogad Member
    White '17 Tacoma SR5 AC AT 4x4
    Fox 2.5
    I don't have OEM 2.5 but I do have standard length 2.5 installed with stock UCA. No issues with alignment.
