Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Aug 31, 2018 at 11:21 AM
    #721
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Just says "Body Plating Zinc-plated and double-clear coated for long lasting finish"
    Contact Fox if you desire a chemical breakdown analysis
  2. Aug 31, 2018 at 12:54 PM
    #722
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Yep, already red that.
    I'm not sure it's too much to ask if your going to drop 3 to 5 G's on suspension if it's going to rust or corrode prematurely...
  3. Aug 31, 2018 at 1:05 PM
    #723
    dirty deeds
    Nick
    Eastern KY
    I completely agree. Which is why I suggested contacting them about what they've improved far as coatings
  4. Aug 31, 2018 at 1:15 PM
    #724
    fxrman
    palm springs
    Ya I meant that as a concern and I need to call for sure, my sarcasm is I would hope they have gotten it solved for the coin they charge..
    I'll post back after I call...
    dirty deeds[QUOTED] likes this.
  5. Aug 31, 2018 at 1:31 PM
    #725
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm not sure what the process change was but Andrew at Accutune was the one that told me about it because I asked him the exact same question about the older ones getting ruined over time.
  6. Aug 31, 2018 at 1:34 PM
    #726
    dirty deeds
    Nick
    Eastern KY
    I will say that my rear Performance 2.0 IFPs have stayed pretty much longer than the 5100s did!
    fxrman likes this.
  7. Aug 31, 2018 at 2:23 PM
    #727
    Biggums
    Biggums Well-Known Member
    Jade
    SoCal
    What brand spring are people going with on the 14" 650?
  8. Aug 31, 2018 at 3:31 PM
    #728
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    I measured pre and post install and I got 1” up front after installing straight out of the box. The truck sits pretty level now but once I lift the back it should have about an inch of rake.
    Tacomamike mike likes this.
  9. Aug 31, 2018 at 8:28 PM
    #729
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Wondering about rear suspension. Looking at the fox 2.0 rear shocks and what people are runnigneith Dakar’s? I don’t wanna lose uptravel. Most people running 9inch stroke?
  10. Aug 31, 2018 at 8:34 PM
    #730
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I’m running the 985-26-118
    They are nearly perfect with the EL095r Dakar’s I’m running. They would be perfect if they were ~1/2” longer as I have some travel left in the springs with these are fully dropped out.
    gordi[QUOTED] likes this.
  11. Sep 1, 2018 at 12:22 PM
    #731
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    King's FTW. I have Fox & regret it since the day I installed them.
    Catfish21 and Biggums like this.
  12. Sep 1, 2018 at 12:32 PM
    #732
    Biggums
    Jade
    SoCal
    Why
  13. Sep 1, 2018 at 12:33 PM
    #733
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    The answer you seek is already in this thread.
  14. Sep 1, 2018 at 12:35 PM
    #734
    Biggums
    Jade
    SoCal
    If it's been corrected, I don't see a problem.
  15. Sep 1, 2018 at 3:03 PM
    #735
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    That's not the reason.
  16. Sep 1, 2018 at 3:04 PM
    #736
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    can you measure precisely center hub to fender? id like to gain 2.75 inches of lift with the 14'' eibach 700 lb springs.. just seeing where i need to place my preload at... also can you take shots of your CV angles?
  17. Sep 1, 2018 at 6:28 PM
    #737
    Biggums
    Jade
    SoCal
    Looking to achieve 2.75" up front with this setup. I only have sliders that account for weight in the front (if any). Do you think this spring will suffice without suffering too much ride quality?
  18. Sep 1, 2018 at 6:48 PM
    #738
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'd use the 14" 650lb springs. That's what they should come with from Fox but instead they come w/the useless 13" 600lb springs.
    I don't think you can get 2.75" w/a 3rd gen w/out creating other issues. 3rd gen is 1" taller than 2nd gen from the get-go.
    shr133 and abqnurse80 like this.
  19. Sep 1, 2018 at 7:29 PM
    #739
    Catfish21
    Stockton, Ca.
    you talking about the CV angles?
  20. Sep 1, 2018 at 7:32 PM
    #740
    dirty deeds
    Nick
    Eastern KY
    I've got a 4 banger, with armor. Already plan, when time to buy comes, to get them with 650lb coils instead.
