Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Sep 16, 2018 at 12:03 PM
    #801
    gadogad
    gadogad Member
    White '17 Tacoma SR5 AC AT 4x4
    Fox 2.5
    Yes I am stock springs. I adjusted them today 3 clicks out from full damper on both high speed and low speed. Still rocked a little but I guess that's the trade off for having off road race shocks.
    Catfish21[QUOTED] likes this.
  2. Sep 16, 2018 at 1:15 PM
    #802
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    spring rates for these are too soft. they need to have 650 stocks and 700 as an upgrade.
  3. Sep 16, 2018 at 1:36 PM
    #803
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    They should have done this for 3rd gens instead of just taking the same 2nd gen shock and calling it good for a heavier truck. The 600s are ok for a 2nd gen, but are even borderline with no weight.
  4. Sep 16, 2018 at 3:24 PM
    #804
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    What about going king 14” 600 or 650 ?
  5. Sep 16, 2018 at 4:45 PM
    #805
    Noreast
    Noreast Well-Known Member
    Dylon
    2012 silver 4dr tacoma TRD
    Anyone know how important it is to instal a diif drop bracket or the ubolt flip kit?
  6. Sep 16, 2018 at 4:46 PM
    #806
    TRDandGlocks
    TRDandGlocks Well-Known Member
    Angel
    2021 TRD Off Road DCSB 4x4 Manual
    I have 14” 650# and they are great and mines don’t have RR just the stage 2.
  7. Sep 16, 2018 at 4:46 PM
    #807
    TRDandGlocks
    Angel
    I didn’t install either, all I installed was the space for the sway bar.
  8. Sep 16, 2018 at 5:07 PM
    #808
    The1youluv2hate
    Peps
    SAnta Paula CA
    Been thinking if it’s worth it swapping out springs before install
  9. Sep 16, 2018 at 5:29 PM
    #809
    Catfish21
    Stockton, Ca.
    its the same as Eibach 14'' coils. i got mine for 170 shipped from wheelers offroad.
  10. Sep 16, 2018 at 6:07 PM
    #810
    TRDandGlocks
    Angel
    I did mine before install, I had the shop I bought them from install 14” 650
  11. Sep 16, 2018 at 7:56 PM
    #811
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    LwvFrQYPN1YLX3ighB7sXmevv8h7rSLrRtEzEoOF_ee617de103bb99d16fa0f58c524e3d2dddd84d27.jpg
    for those wondering, the king coil is slightly wider than the fox ones. eibach/icon coils might have better fitment. i run them with zero preload
    UpieqKJ9uetNnwPn2g3EfjmuUvhvJ7DB2PLQRFoA_afb2abf949f4221ff4b0322b60994f6748c70cd7.jpg
    YChxhEAQJSKIw4DZ3-Ox9_255kT7VOBp9cvcrVpv_a828c665092a5b7b0fb55ad78dc9d80fd227d4e1.jpg
  12. Sep 16, 2018 at 10:59 PM
    #812
    The1youluv2hate
    Peps
    SAnta Paula CA
    Going to check it out, still putting my lift together , about to order tc uca and nitto 285s
  13. Sep 17, 2018 at 8:33 AM
    #813
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    Going with heavier rate springs is not the correct solution for the rocking. The rocking is a result of improper shock valving. Other related symptoms are front bounciness on the highway and bottoming out too easily on certain things.
  14. Sep 17, 2018 at 9:09 AM
    #814
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Is this a common issue ...?
    I want to go with a 2.5 with RR and DSC front and rear on my 16 TRD OR but can't afford the valving tune at this time. Should I go with king or ADS...?
    *TRD*[QUOTED] likes this.
  15. Sep 17, 2018 at 11:07 AM
    #815
    *TRD*
    Carson, Ca
    I don't know about ADS, but Fox and King both valve theirs similar to OEM.
  16. Sep 17, 2018 at 11:13 AM
    #816
    fxrman
    palm springs
    Was going Fox based on your recommendation, and in the 2.5 like stated above with the intention to have you revalve and rebuild after some use.
    Guess I'll see how it works out.
    Watched some of your videos and wish I could have you do it all right out of the box but funds won't allow it at the moment.
  17. Sep 17, 2018 at 11:25 AM
    #817
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    If you buy from @*TRD* with Accutune OffRoad then he’ll tune them as a part of your purchase.
    Biscuits, 17SandTaco and *TRD* like this.
  18. Sep 17, 2018 at 11:50 AM
    #818
    fxrman
    palm springs
    Yep I know...
    Can't afford it presently as just the tuned shocks run over 3 G's and I'm getting the shocks, rear springs, uca's, cb drop kit, bushings, swaybar relocation brackets etc.... for 3,550 out the door. Well over 5 G's from accutune and I would still have to get u-bolt flip kit and bump stops.
    MCDavis[QUOTED] likes this.
  19. Sep 17, 2018 at 12:05 PM
    #819
    *TRD*
    Carson, Ca
    Our complete Stage 4 kit with 2.5's and custom tuning is $4,460 and that includes u-bolt flip and bump stops. The front coilovers include sway bar relocation.
    Our kit uses high quality parts: Icon Delta Joint, Icon RXT Pack, Upgraded High Flow Piston in the Rear, Correct hose routing and bushings in the rear, all shocks disassembled and re-tuned.
    http://accutuneoffroad.com/product/05-tacoma-mid-travel-suspension-kit-stage-4-fox/
    We can make it less expensive with Dirt King UCA's, Fox 2.0 rear shocks, and AAL.
    Biscuits and MCDavis like this.
  20. Sep 17, 2018 at 12:13 PM
    #820
    fxrman
    palm springs
    Is that out the door...?
    If so I can save a few more weeks.
