Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Aug 12, 2019 at 5:15 PM
    #1681
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    I’m a lot heavier. Bumper, skids, sliders, winch, and 33’s. 14” 600 lb coils. No complaints.
    I am riding around with a bed full of firewood in addition to all of my weight and 14” 600’s are just fine. I think 650s might be okay, but never anything more than that.
    Edit: I was skeptical at first after reading posts of people with super heavy springs. After talking with @*TRD* at @AccuTune Offroad, I went with 14” 600s. After running this setup for a year, I sent them back to Accutune and they updated the valving to fine tune the system to my needs. It only cost me shipping, which was super cheap.
    I highly recommend you buy from them. They always respond. Are always available. And they really know their stuff.
  2. Aug 12, 2019 at 5:17 PM
    #1682
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    Looking for some help. I just finished installing a set of FOX-883-02-025 combined with SPC adjustable UCA's and I'm having trouble balancing my ride height and preload. As it sits now I have 2.5" of threads showing for preload and a spring length of 10.75" at full droop. This gives me a ride height of 21.5" on the driver side and 22.25" on the passenger side. From the @AccuTune Offroad article I shouldn't be going any less than 11" on the springs and after contacting Fox they told me that max preload was 2.5". My truck has full Aluminum skids and a hidden winch mount with winch. I was hoping to be able to adjust these to achieve 23" hub to fender but now I'm wondering if I will need heavier springs to achieve the 2" lift I was looking for. Let me know what you guys think.
  3. Aug 12, 2019 at 9:32 PM
    #1683
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Yes, you’ll need the 14” 600 coils. Maaaaybe 650, but I bet you’ll be fine with the 600’s.
    go2cnavy and supralee like this.
  4. Aug 12, 2019 at 10:32 PM
    #1684
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Where you guys buy you're fox at I need the fronts with adjusters Extended travel
  5. Aug 13, 2019 at 4:49 AM
    #1685
    NukedTaco
    Wyatt
    What does a 14” 600# coil change, wouldn’t there just be less preload adjustment before the coil gets bound up. If I’m thinking about this correctly (which I might not be) there is a fixed amount of space available for a spring to go. Lets say for example 12”. If I put a 13” spring in there, the spring compresses some to fit but if I put a 14” spring in there it will have to compress more to fit. This will bring the coils closer together and if both springs are 600# springs wont they both oppose the same amount of weight causing the truck to sit at the same height but with less room between the coils on the 14” spring.
    AccuTune Offroad likes this.
  6. Aug 13, 2019 at 8:14 AM
    #1686
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    You are correct that the 14's have a taller block height than the 13's.
    However the 14's have more travel and can therefore support more weight and take more preload before reaching block height.
    Max Preload = (Spring Travel) - (Shock Travel)
    As you can see from the equation above a spring with more travel can take more preload, and more preload means it can support more weight.
  7. Aug 13, 2019 at 8:45 AM
    #1687
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
  8. Aug 13, 2019 at 9:28 AM
    #1688
    808_tacoma
    808_tacoma Well-Known Member
    Chad
    Morgan Hill, CA
    I just got my kit and having it installed on Monday. Been reading through and there's so much good stuff here!
    For the 3rd Gen owners, about how much are you seeing these needing to be adjusted to get about 2" of lift (no extra weight)? Have you all been seeing about 1" in the factory setting?
  9. Aug 13, 2019 at 10:05 AM
    #1689
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    yeah, factory setting is about 1". you'll likely need to crank these up to 20 threads showing, or possibly to the max(24 passenger, 27 driver) to see 2" on a stock third gen.
  10. Aug 13, 2019 at 10:54 AM
    #1690
    808_tacoma
    Chad
    Morgan Hill, CA
    Thanks for the heads up! I was reading that with the extended travel I get 0-3” versus 0-2”, so hopefully it’ll work out just right.
  11. Aug 13, 2019 at 11:00 AM
    #1691
    NukedTaco
    Wyatt
    @RangerComa thanks for the help. At this point I'm going to call @AccuTune Offroad and talk with them about whether a 600# or 650# spring would be better for my application.
    RangerComa likes this.
  12. Aug 13, 2019 at 11:03 AM
    #1692
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    You’re going to want to be at 2” over stock maximum. The stock third gens are an inch over stock second gens, with all other suspension components being the same. So the second gens can go up 3” and the third gens only 2”.
    The number to shoot for: on level ground, middle of hub to fender measurement of 23”. That is the max recommended lift for 2nd and 3rd gen Tacoma’s. You’ll start to run into cv axle and control arm ball joint problems if you go any higher.
    808_tacoma[QUOTED] likes this.
  13. Aug 13, 2019 at 11:04 AM
    #1693
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Good choice!
  14. Aug 13, 2019 at 12:25 PM
    #1694
    808_tacoma
    Chad
    Morgan Hill, CA
    Perfect, 2" is exactly what I was shooting for and with the "extended travel" I should be right in the sweet spot!
  15. Aug 13, 2019 at 2:37 PM
    #1695
    go2cnavy
    From what I remember from my communication with Accutune, the 14” springs require, at minimum 2” of preload (Not threads showing, but actual compressed spring length). Why does this matter? Because it will determine your minimum lifted height.
  16. Aug 18, 2019 at 10:21 AM
    #1696
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Currently running FOX 2.0 rears w/resi. Might possibly be making a purchase on some 2.5 rears either without or with DSC’s. Looking for some feedback from people who have made this same purchase.. or possibly jumped up from 2.0’s to 2.5’s. Any personal reviews?
  17. Aug 18, 2019 at 10:25 AM
    #1697
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    From what I was told, the 2.0’s are crap compared to the 2.5’s...and that’s from multiple vendors. With that said, I love my 2.5 with DSC.
    AY_ARONTRD[QUOTED] likes this.
  18. Aug 18, 2019 at 10:30 AM
    #1698
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    I’ve had my 2.0’s on 2 trucks and for about 2-3 years. Don’t really have anything to compare them to besides stock. My fronts are 2.5’s without DSC’s. But I’m considering 2.5 rear with DSC’s just to be able to make the adjustments under load etc... of course I don’t know a damn thing about adjusting them so class would be in session.
  19. Aug 19, 2019 at 1:04 AM
    #1699
    go2cnavy
    Unless you’re super heavy with armor and gear, 2.5s are overkill for the rear. 2.0s have an option for adjusters.
    https://accutuneoffroad.com/articles/size-tacoma-4runner-shocks-need/
  20. Aug 19, 2019 at 1:24 PM
    #1700
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Yes I agree there a bit overkill.. the only added weight I have is a HC rear bumper. But when I camp I have a family of 4. Truck gets some gear loaded and have it full of tools Monday-Friday. Figured I could get a better ride and I’m not the biggest fan of the resi design on the 2.0’s. I’ve had one get damaged by the top hat and not really looking to cut it for clearance for the resi line/fitting.
    bax likes this.
