Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Aug 21, 2019 at 11:28 AM
    #1721
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Got it. Exactly. Yours move. Mine don’t.
    I think we both came off a little too sure and matter-of-fact. The fact of the matter is our situations are not a guaranteed behavior of these shocks.
    RESET - The accurate answer is that “some” move.
  2. Aug 21, 2019 at 11:33 AM
    #1722
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Correct. I never claimed all do. I was just proclaiming that even when installed and torqued properly they can still rotate, and to always visually check your hoses before rides just in case.
    I build jet engines for a living. No stranger to reading specs and using a torque wrench lol.
    No hard feelings. Was just sharing my experience.
    go2cnavy[QUOTED] likes this.
  3. Aug 21, 2019 at 11:37 AM
    #1723
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    It's probably in here somewhere.
    I was contemplating rear 2.0s, are the lower shock mounts a lot of trouble to install?
  4. Aug 21, 2019 at 11:37 AM
    #1724
    m603holden
    Marteeen
    New England
    Nah. Just grab a buddy if you can though.
    batacoma[QUOTED] likes this.
  5. Aug 21, 2019 at 11:37 AM
    #1725
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    The Fox 2.0 valving does change by part number, and some of them are EXTREMELY aggressive.
    There is nothing preventing the 2.0's from rotating, but it also hasn't been a problem.
    Most of the damage I have seen has been cause during installation (not noticing the hose hitting the mount) or initial hose orientation (hitting the tire on articulation).
    go2cnavy likes this.
  6. Aug 21, 2019 at 11:46 AM
    #1726
    go2cnavy
    Can be if you put the top in first. I’ve found it easiest to
    - jack the rear up
    - remove rear parking brake hangers from frame and leafsprings
    - install lower mount with shock top facing away from lower mount. Don’t tighten bolt yet
    - rotate shock to vertical position while compressing it slightly
    - guide top mount in while releasing the shock
    It’s more difficult you put the top mount in first because of the mounting angle on the lower mount.
  7. Aug 21, 2019 at 11:48 AM
    #1727
    batacoma
    batacoma Truck Wars
    That sounds easy.
    How about the mount itself, I though the bushing had to be changed?
  8. Aug 21, 2019 at 12:22 PM
    #1728
    m603holden
    Marteeen
    New England
    My bad. I gave a simple answer because I thought that's what you were talking about. It does. It can be stubborn. I actually filed down the inside of it to make it thinner and it ripped pretty easy. Others have some good techniques too. I'm sure they'll chime in.
  9. Aug 21, 2019 at 12:47 PM
    #1729
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    I combined the techniques of these two videos:
    https://www.youtube.com/watch?time_continue=1&v=PYueBjLnBms @drewhaus posted this here somewhere
    https://www.youtube.com/watch?v=V6kNV7cdwtE
    Mine also came with the bigger bushing installed so to swap them out for the smaller ones that came provided, I used different sized deep sockets and a c-clamp (like @Rd62 recommended) plus some lube and it was actually surprisingly easy.
    The problem is that even the small bushing will most likely be too big for your lower shock mount, at least least it was in my case. So out came the angle grinder to carefully shave down both sides to make them fit.
  10. Aug 21, 2019 at 4:54 PM
    #1730
    go2cnavy
    Sorry. Mine came from Accutune with the correct bushings installed. I wasn’t aware that the bushings need to be swapped out.
    AccuTune Offroad likes this.
  11. Aug 21, 2019 at 9:59 PM
    #1731
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Would I be ok with 100 pound steel bumper with 2.5 600 spring rate
  12. Aug 21, 2019 at 10:01 PM
    #1732
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  13. Aug 21, 2019 at 10:15 PM
    #1733
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    Sorry if I sound dumb not sure im new to fox upgrade from stocks
  14. Aug 22, 2019 at 9:51 AM
    #1734
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    AccuTune Offroad and go2cnavy like this.
  15. Aug 30, 2019 at 2:22 AM
    #1735
    go2cnavy
    200 psi rides so much better than 175 psi. At 175 it felt like the front was just slightly under damped - primarily the rebound felt a little quick. After adding 25 psi, it seems like the suspension stays in the stroke much better, it soaks up the square edge hits like butter, and the ride is the best it’s been in three years.
    On top of the extra air, I went to a c-rated tire and ditched the e-rated rubber.
    Thanks for the advice and killer customer service @*TRD* @AccuTune Offroad
  16. Aug 30, 2019 at 5:26 AM
    #1736
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I’m going to go ahead and say that your increased ride comfort is more related to changing tire load than changing nitrogen PSI unless there’s a science behind this that I don’t understand.
    HeadStrong Off-Road likes this.
  17. Aug 30, 2019 at 5:38 AM
    #1737
    go2cnavy
    Tire change occurred a few days before PSI change. No doubt that the tire change helped - night and day difference between E and C. However, the PSI change is by far much more noticeable.
  18. Aug 30, 2019 at 11:28 AM
    #1738
    josh0724
    josh0724 Well-Known Member
    Josh
    2017 Quicksand Tacoma TRD Off Road
    Hey Fox family. I just got my Fox 2.0 kit in from @HeadStrong Off-Road and hoping to install it myself tomorrow morning. I don’t have to compress the springs prior to installing the front right? I should be able to install them right out of the box correct? This is for a 2017 Tacoma TRD Off Road.
  19. Aug 30, 2019 at 11:34 AM
    #1739
    m603holden
    Marteeen
    New England
    Make sure the allen head for the lock ring is facing out so you can get to it once on the truck.
    Daddy_Firebird likes this.
  20. Aug 30, 2019 at 12:23 PM
    #1740
    JAStaco
    JAStaco Well-Known Member
    MT
    2013 Tacoma DCLB
    Elka 2.5 RR w/ adjusters front and rear, JBA UCA's, Icon RXT, SEMA 4R pro wheels, Meso Customs interior lights, Wheeler's Superbumps front and rear
    If you have the 2.0 fronts, then yes, just bolt them up. You can't adjust ride height with them on the truck, so the lock-ring allen @m603holden mentioned is not applicable to you. FWI, they do not come adjusted to compensate for the "taco lean" and you may find they don't provide quite as much lift as stated by Fox straight out of the box. I'm sharing this so that you can make adjustments (for which you will need a spring compressor) prior to installing to avoid having to take them off/on again. Hope this helps.
    bax likes this.
