Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. Oct 29, 2019 at 9:05 AM
    #1921
    su.b.rat
    su.b.rat broken truck
    the TRD Pro Fox 2.0 kit uses 3" ID coils with 600lb rate? is this correct? and regular non-TRD 2.0 Foxes use a 2.5" ID coil? with a 600lb rate?
    i am in conversation with Fox also trying to get a possible custom kit figured. all the details are getting on the table, but i don't have all the details yet.
  2. Oct 29, 2019 at 9:08 AM
    #1922
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    The TRD PRO uses a 2.5" shock which will use a 3" ID spring.
    The 2.0 series c/o use a 2.5" ID spring.
    su.b.rat[QUOTED] likes this.
  3. Oct 29, 2019 at 9:11 AM
    #1923
    su.b.rat
    great. do you know the spring rates on these? pretty sure the TRD Pro kits are 600lb. i'm looking at 2.5 & 3.0 kits for the truck but those don't appear to come with less than 650lb springs.
  4. Oct 29, 2019 at 9:20 AM
    #1924
    desertjunkie760
    Shane
    Check My Sig.
    On the PRO? There's been much speculation but I don't have any confirmed information.
    Spring rates from Fox, for aftermarket at least idk about their OE shocks, are 600lbs for that Tacoma.
    tacoma16 likes this.
  5. Oct 29, 2019 at 9:22 AM
    #1925
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Can confirm spring rates at 600lbs based on what down south motorsports had just mentioned to me @St.Germain
  6. Oct 29, 2019 at 10:41 AM
    #1926
    su.b.rat
    so it turns out that the TRD Pro Fox 2.0 kit are 2.5's with internal bypass according to Fox. so while i'm looking at upgrading to internal bypass 2.5's, i'm a fool because i'm already running them. o_O i didn't know these had the internal bypass. anyway, the suggestion from the Fox guy was to send them back for a rebuild, and they can custom revalve them for my needs. so it looks like the only PITA is sending them back off my DD. that's probably not as bad as a new set of $2000 shocks.
    thanks for y'alls help.
  7. Oct 29, 2019 at 11:01 AM
    #1927
    sicki
    sicki Well-Known Member
    OR..you get the new shocks, and, send your current ones off for rebuild, then when ya need to rebuild the new ones, you have a set...such and such, and so forth....
  8. Oct 29, 2019 at 11:05 AM
    #1928
    desertjunkie760
    Shane
    Check My Sig.
    I would contact the service department and confirm that information before you do anything.
  9. Oct 29, 2019 at 11:34 AM
    #1929
    su.b.rat
    of course i will. everything is in a planning phase right now with the truck. no rush on this.
  10. Oct 29, 2019 at 6:45 PM
    #1930
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Nice. I’d buy a cheap set as spares and send your Fox set to @AccuTune Offroad for a double stack re-tune.
    I throw my stock Billy’s on when I send mine in. Usually get them back in a week.
  11. Oct 29, 2019 at 7:15 PM
    #1931
    su.b.rat
    are you recommending Accu Tune to rebuild/revalve instead of Fox? if so, why?
  12. Oct 30, 2019 at 1:59 AM
    #1932
    go2cnavy
    Much more personalized service and a better valve stack with a wider range of tuning options. A relationship with one’s suspension shop is invaluable. For me truck stuff goes to Accutune and bike stuff goes to SuperPlush.
    Jpiskura and su.b.rat[QUOTED] like this.
  13. Oct 30, 2019 at 7:20 AM
    #1933
    su.b.rat
    thanks for that. I'll check into it. :thumbsup:
  14. Oct 30, 2019 at 9:19 AM
    #1934
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    @AccuTune Offroad question. If I run Fox 2.5s 600lbs springs with zero preload (slight preload on the drivers side for the taco lean) with my 4inch Maxtrac spindles will there be any additional lift? I’m trying to only retain 4inches I’d lift from the spindles.
  15. Oct 30, 2019 at 11:51 AM
    #1935
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Thats extremely specific. You're basically wanting 0" lift with the suspension, but 4" from the spindles. You will need to adjust preload to get you back down to a 4" lift... but there is no specific number for this since every vehicles weight is different. 0" preload does not equal 0" lift.
  16. Oct 30, 2019 at 6:28 PM
    #1936
    TheBlueBeast15
    Kevin
    H-Town
    Ahh I forgot to mention I have no additional weight up front as of now. I have a 2nd gen and I swapped out my stocker or shocks for some 3rd gen or shocks and it lifted me up a little under an inch. I’m not sure what the spring rate is on those tho.
  17. Nov 4, 2019 at 12:26 PM
    #1937
    Broheim
    Broheim Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    Anybody ever rebuild the 883-02-025 's?
    Pretty much the 2.5 extended ifp coilovers.
    Any part numbers for the rebuild?
    Oil, bearings, seals etc.
    Going to rebuild them with some 14" 600# on there. They've been great so far.
  18. Nov 6, 2019 at 10:08 PM
    #1938
    Taco_mex
    Taco_mex Active Member
    Alberto
    Tacoma 2018 sand
    none
    regards, I have a
    problem, I hope you can help me, have a horrible sound and I don't know where it comes from, it happens to me when I adjust the preload to more than 1.5”, I have spc uca and 14” 600lb spring
  19. Nov 7, 2019 at 7:57 AM
    #1939
    AccuTune Offroad
    El Cajon, CA
    Did you just install the suspension system, or is this noise only coming AFTER you adjusted preload?
    Have you gone through every nut and bolt to make sure it torqued properly?
    What is the measurement from lower shock eye to top hat?
  20. Nov 7, 2019 at 8:19 AM
    #1940
    Taco_mex
    Alberto
    Tacoma 2018 sand
    none
    thanks, only after I adjust preload, and yes I check torque for all nuts and bolts, the measurement are 23" with 20 threads showing
