Fox Lift almost done, one last question!!
Discussion in 'Suspension' started by cgrove04, Aug 17, 2010.
  1. Aug 18, 2010 at 12:05 AM
    cgrove04
    cgrove04 [OP] 2010 tacoma v6 fox's
    Cory
    Richmond
    '10 trd sport v6 tacoma, fox's, ap bump, 33's
    the bottom of the sway bar link is rubbing the bottom of the coil over. It actually made a dent into the bottom of my freakin shock rubbing some metal out of it. you can pretty much see it hitting in that picture
  2. Aug 18, 2010 at 12:06 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Did you take the end links completely off when you installed the coil overs? Or just one end of the end link?
  3. Aug 18, 2010 at 12:07 AM
    cgrove04
    Cory
    Richmond
    took them completely off, right now their off too until I can figure out whats going on
  4. Aug 18, 2010 at 12:10 AM
    all.on.black
    Auburn, WA
    It looks like you have/had them on wrong. The one you have pictured should be on the other side. The nut should be on the inside and the joint towards the outside. In the picture it looks like the end link is bending towards the inside while it should be straight.
  5. Aug 18, 2010 at 12:12 AM
    cgrove04
    Cory
    Richmond
    Oh hell no way
  6. Aug 18, 2010 at 12:12 AM
    cgrove04
    Cory
    Richmond
    seriously im a reeeetard
  7. Aug 18, 2010 at 12:13 AM
    cgrove04
    Cory
    Richmond
    guess that would solve the problem ehh
  8. Aug 18, 2010 at 12:14 AM
    all.on.black
    Auburn, WA
    I haven't had the sway bar on or looked at in over 2 years so I'm just going from how they typically are designed. The joint usually points outward.
  9. Aug 18, 2010 at 12:16 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    That didn't even cross my mind. Normally you just take the whole swaybar off, do the install, then put it back on.
  10. Aug 18, 2010 at 12:16 AM
    cgrove04
    Cory
    Richmond
    I dunno I'll have to go out there and see, im trying to find pics now, anyone who has one on atm can they confirm
  11. Aug 18, 2010 at 12:18 AM
    all.on.black
    Auburn, WA
    Just look at the end links. Are they identical? If not, then they are side specific.
  12. Aug 18, 2010 at 12:21 AM
    cgrove04
    Cory
    Richmond
    they are mirror images, it looks like you could be right but for some reason I thought they went the way i put them back on oh well
  13. Aug 18, 2010 at 12:23 AM
    all.on.black
    Auburn, WA
    If you swap them then the joint will be on the outside and the nut on the inside. Which will give you 1/2" more clearance on the coil over side.
  14. Aug 18, 2010 at 12:27 AM
    cgrove04
    Cory
    Richmond
    thanks soooo much man, ya your right I just completely forgot about doing that. Well that solves my sorrows just wish I hadnt hurt the shock but oh well
  15. Aug 18, 2010 at 12:29 AM
    #35
    all.on.black
    Auburn, WA
    You're welcome. Saving one headache at a time.
