Fox Performance 2.0 Front Coilover/Rear 2.0
Discussion in 'Suspension' started by belcher, Nov 2, 2011.
  1. Nov 7, 2011 at 11:25 AM
    #81
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Hey, I was just trying to provide some facts. You said the Fox's weren't rebuildable. I was merely correcting you.
    And yes, Fox is running an Eibach spring. 600lb rate. As I mentioned a couple times earlier in the thread.
  2. Nov 7, 2011 at 11:43 AM
    #82
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Just pointing out 5100's specs and how they compare! Also, I was saying IF they were not rebuildable there wouldn't be a lot of advantage over Toytec's! Fox obviously puts out good stuff......so there's just more options then there were before! No harm no foul buddy!
    Someone needs to get these real quick and run them through their paces and report back, lol!
  3. Nov 7, 2011 at 11:44 AM
    #83
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    It is under $200 for the bilstein front 5100 and $150 for the springs. I know it does not include the top plate setup.
    So for a poor man the 5100 is still a decent setup vs the entry fox.
    If they could hit $600 or so I would be in but for the difference I am set on purchasing 5100 soon.
    If anyone is going to offroad alot they are going to go better than entry fox pieces so they are not buying in the future again. I do not see alot of daily driver guys or sometimes weekend OR people going for the $700 price tag.
  4. Nov 7, 2011 at 12:38 PM
    #84
    Nonfatwater7
    Nonfatwater7 Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    OK
    Just ordered my new suspension
    -5100's and 1/4" top plate from wheelers for $200.00 (Wheelers is awesome by the way)
    -Eibach coils for $131.00 from JDM Hub
    not too bad right?
    ...I hope not
  5. Nov 7, 2011 at 1:01 PM
    #85
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    I'm going 5160's for the rear though...But i did see that and that is a steal of a deal
  6. Nov 7, 2011 at 5:26 PM
    #86
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I'm down for these.
    Are they progressively or digressively damped?
    These plus Dakars and a 1/4" lean spacer and I'd be set for my driving.
  7. Nov 7, 2011 at 11:19 PM
    #87
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    2"
  8. Nov 8, 2011 at 6:52 AM
    #88
    GP3
    California
    4X4 TRD Off Road
    That's what I was thinking about doing.
    Others said adjust the preload.
    I'm not sure yet.
    I can tell you for sure that with these coilovers, you will lean towards the drivers side 3/4" with a full tank of gas.
  9. Nov 8, 2011 at 6:57 AM
    #89
    GP3
    California
    4X4 TRD Off Road
    I understand that, but why then does Toytec offer the 1/4" lean-spacer? Is it for their non-adjustable coilovers?
  10. Nov 8, 2011 at 7:04 AM
    #90
    GP3
    California
    4X4 TRD Off Road
    I had to draw it out, but I agree: Adjust the preload to compensate for the 3/4" lean.
  11. Nov 8, 2011 at 7:18 AM
    #91
    GP3
    California
    4X4 TRD Off Road
    What? You are telling me my tape measure is wrong?
    With these coilovers set at equal preload, the truck sits 3/4" of an inch lower on the driver side with a full tank.
    This is real life experience; not what I read on the internet.
  12. Nov 8, 2011 at 12:43 PM
    #92
    Voodoo Rufus
    Bakersfield, CA
    I suppose you guys are right. No lean spacer required.
    Brain did not engage fully.
  13. Feb 14, 2012 at 8:30 PM
    #93
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Anymore updates on these?
  14. Feb 22, 2012 at 3:09 PM
    #94
    Uncle Cliffy
    Uncle Cliffy Never tell me the odds.
    Clifford
    So. Oregon
    06 DCSB 4x4
    https://www.tacomaworld.com/threads/uncle-cliffys-build.327590/
    Bump. Anyone else pull the trigger on these? Got a good price through my work, and Bilsteins wouldn't be much cheaper. ;)
  15. Sep 23, 2012 at 9:01 PM
    #95
    JeremyGrey
    JeremyGrey Well-Known Member
    Ahwatukee, AZ
    2012 DCSB TX Pro Prerunner
    Bump, does more than just one person have these?
  16. Sep 24, 2012 at 7:44 AM
    #96
    GP3
    California
    4X4 TRD Off Road
    Sure there are. They just don't post on TW. They make these for all different applications. Jeep, Chevy, etc.
    What do you want to know about them?
  17. Sep 24, 2012 at 10:05 AM
    #97
    JeremyGrey
    Ahwatukee, AZ
    I saw you metion that the rear was a little stiff to compensate for the crap springs in the rear. Can I have whomever i buy them from revalve them? also, I wanted to lift the rear a little. Thinking either, wait for the TSB for the 2012 or do the icon progessive AAL. On the ORW website it says the fox rears are for 0-1inch of lift. The icon AAL is 1.5 inch lift. so i cant use those foxs then? I would have to just wait for the TSB? if I lift the back with either TSB or icon AAL, I would would like to raise the front more. So that would put the front at 2.5 inch + of lift right? Im guessing I need UCA then?
  18. Sep 24, 2012 at 10:18 AM
    #98
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    What about a price on these things?
  19. Sep 24, 2012 at 10:28 AM
    #99
    JeremyGrey
    Ahwatukee, AZ
    its just under 1k for all four shocks
  20. Sep 24, 2012 at 10:43 AM
    #100
    GP3
    California
    4X4 TRD Off Road
    It's a bit stiffer than stock, but it keeps the axle off the hard bumpstops better than stock. It's a compromise, but it's not drastically stiffer.
    I've been running the Icon AAL for 3,000 miles or so. No issues. I don't think it lifted the rear 1.5". At least, not on my truck. It had 35,000 miles on it when I put the AAL on, so the stock leafs were probably fatigued which is why I didn't see 1.5". Though, I didn't measure before and after.
    2.5" up front is pushing it without an aftermarket upper control arm, in my opinion. Ball-joints will be binding, and your caster will be out of spec. In fact, 2.5" up front is pushing the limits of an OE length shock.
