Fox Shox vs Toytec Ultimate Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scaddude, Oct 25, 2011.
  1. Oct 25, 2011 at 2:00 PM
    scaddude
    scaddude [OP] Active Member
    Los Angeles, CA
    V6 4x4 6-Speed Manual TRD Off-Road
    So over the weekend I bought a set of TRD Anthracites from forum member huyissuperman (great guy, with lots of cool stuff) and he turned me on to Fox shocks.
    I was already eyeballing the Toytec Ultimate Lift kit along with the optional Leafs, but now huyissuperman is thinking about packaging his own set using Fox Shocks and All Pro leafs.
    So, my question: Which should I go with? Price isn't an issue (though seems the Toytec will cost more)
    Now I usually go off-roading only 4-5 times a year out in Mojave, with an occasional jaunt through the beaches of Baja, but my Taco is my daily driver.
    From everything I've read, the Toytec feels the most like factory, but I haven't heard any comparisons to the Fox. Thoughts?
  2. Oct 25, 2011 at 3:43 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Fox is a way bigger bang for your buck if $ isn't an issue! I like my Toytec's but am needing an extended travel coilover for wheeling. As far as street ride, Fox's valving is progressive so they should be softer at slower speeds and firm as the shocks compression speeds up. The Toytec's 5100 is digressive and will be firm at slow speeds and soft as the speeds increase. Keep them around 2.5" lift for the smoothest ride. Personally, I like the digressive valving and was going to upgrade to Icon's for that reason but have yet to ride with Fox!
    PS - For those prices you should jump on the full Fox package and def get the UCA too! That way you wont have to re-do everything later! Plus, you'll start wheeling a hell of alot more now that you will be fully capable!
  3. Oct 25, 2011 at 4:03 PM
    scaddude
    Los Angeles, CA
    Thanks Sublime! Good info. I've reposted this to the suspension thread now too.
    But I think you've got me definitely considering the switch.
  4. Oct 25, 2011 at 4:06 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    fox shocks are better than toytec in every way.
    toytecs are cheap. you might as well get 5100s with ome coils than get the toytec kit
  5. Oct 25, 2011 at 5:10 PM
    davidfj
    davidfj Active Member
    Not even close of a comparison, Fox setup is better hands down. Plus, they're being offer for cheaper!
  6. Oct 25, 2011 at 6:59 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I realize some people have had issues with toytec, but they're no as cheap as everyone says they are. If you're not looking for a full race style rebuildable shock toytec is the best you can get.....mainly because the 5100 is a digressive maintenance free shock and does very well on/offroad. Toytec has matched eibach springs and the adjustable collar and is the best you can get without going to a race shock. I stand by toytec and their products and have been very happy with them except for the type of wheeling I do would prefer an extended travel shock! Toytec out performs OME in my opinion!
  7. Oct 25, 2011 at 7:02 PM
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    huyissuperman is the "man"!
  8. Oct 25, 2011 at 7:04 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    :popcorn:Good debate going thus far
  9. Oct 25, 2011 at 8:02 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    the toytec coilover shocks are the 5100's, looooooooook close. I would still go with the fox's as you'll be getting more bang for the buck in performance. Is the fox's 2.0 or 2.5?
  10. Oct 25, 2011 at 8:41 PM
    scaddude
    Los Angeles, CA
    The Toytec Ultimate Lift Kit was the one I was looking at, which are the Bilstein 5100s.
    05sctaco, the Fox's are 2.5" lifts. I presume that's what you were asking.
  11. Oct 25, 2011 at 8:48 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    He was asking about shock diameter. Hopefully they are the 2.5s but you may want to double check!
  12. Oct 25, 2011 at 8:52 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    OME before toytec. Then Icon's and fox's.
  13. Oct 25, 2011 at 9:14 PM
    davidfj
    IMO, Icon/Fox/SAW/King are pretty much on the same playing field...Bilstein 5100 is sub-par compare to those companies, which is a no brainer to go with the Fox setup especially if its cheaper. BTW, the Fox is 2.5" diameter and lifts the truck 0-3".
  14. Oct 25, 2011 at 9:19 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I love my Icons :D
  15. Oct 25, 2011 at 9:21 PM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    And just got the rear 2.5's last month and WOW!
  16. Oct 25, 2011 at 9:52 PM
    05sctaco
    Ken
    Santa Cruz
    I got those too, almost same shock setup but no resis up front. I mounted my rear resi to the bed, easier to drill then the frame. Next setup is camburg LT
  17. Oct 26, 2011 at 8:22 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    How much better do the 2.5 rears perform compared to the 2's? They look SICK!
  18. Oct 26, 2011 at 10:59 AM
    05sctaco
    Ken
    Santa Cruz
    The icons can re rebuilt but for regular use they'll last longer than 50k. Not to mention it's cheaper to rebuild then keep buying new shocks. After a while those 5100's will need to be replaced regardless. Not to mention the 2.0, 2.5 aftermarket coilovers are 10-100x better shock then the 5100's.
  19. Oct 26, 2011 at 11:01 AM
    05sctaco
    Ken
    Santa Cruz
    Like butta, i had rear 5150's 12 travel shocks, and daaaaaam, does my rear soak everything up. It's like a skinny girl with a big-o butt.
  20. Oct 26, 2011 at 9:59 PM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    I've never got a chance to feel the 2.0s but these 2.5s ride 10000000x better then the 5100s i had on before!
