Foxwing 270 Awning
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Vyprdad, Jan 25, 2020.
  1. Jan 25, 2020 at 6:37 AM
    Vyprdad
    Vyprdad [OP] Well-Known Member
    David
    2019 Tacoma TRD Off Road
    I bought a new 2019 No Boundaries 10.5 RV and this was factory installed. I am going to be getting a more conventional RV type straight pull out awning as it would be better for my needs. I have only been camping one time in the RV since I bought it and it was only used once and it was on a dry day. No rain. I bought the newer upgraded cover for it that is black and much more heavy duty and allows you to store the poles inside the awning bag. It is basically brand new. This is the right side mount top. So if you are going to be using it on a Overland truck it will mount on the passenger side and swing open towards the rear. The awning is 100” long so it will cover a nice big area!! I am located in Northern Natomas area of Sacramento. First 500.00 gets it. It is very nice. Comes with the mounting brackets, poles and spikes / tie down ropes. I am posting a reference pic to so you can see what it would look like opened.
  2. Jan 25, 2020 at 6:47 AM
    NewbieTaco
    NewbieTaco Well-Known Member
    NE Ohio/ Montana
    2013 DCSB 4x4 SPORT MGM, 2017 DCSB 4x4 OR MGM
    So are you able to change the mount on this to mount on the drivers side?
  3. Jan 25, 2020 at 6:49 AM
    Vyprdad
    David
    I think it has more to do with the way the bars open up more than the mounts. I looked at it and I think it could be flipped and moved to a left side. But just unsure. You could mount it on the left side it would just open towards the front of the vehicle. I had a guy tell me it could be taken apart and everything done in the order of a left side assembly.
  4. Jan 25, 2020 at 8:21 AM
    NewbieTaco
    NE Ohio/ Montana
    thanks GLWS,
  5. Jan 25, 2020 at 9:15 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Me and the lady are looking into getting a trailer. Why did you pick the nobody 10.5? We were looking at the teardrop style trailers, but this one looks pretty nice.
    We just need to go to an rv dealer and start looking at these in person. Thanks!!
  6. Jan 25, 2020 at 11:11 AM
    Vyprdad
    David
    I got the 10.5 2019 version. The 2020 is the same height now as the 10.6. I wanted the shorter one to fit in the garage. I have modified it quite a bit. So much the manufactures contacted me asking what I did and how did I do that and if they can use my ideas.
  7. Jan 25, 2020 at 12:39 PM
    slowlane
    AZ
    16 double cab MGM
    Haha awesome!! Got pics?
  8. Jan 25, 2020 at 1:46 PM
    Vyprdad
    David
    I will post some when I get home. I installed a tv in the rear. Ambient lighting with switches. Moved the kitchen around and a custom prop rod. Bolt on table to the fender well for a counter etc....
  9. Jan 25, 2020 at 8:21 PM
    Vyprdad
    David
    Here is a lot of pics I did for modding it. Turned the kitchen and added a bbq counter top etc
  10. Jan 25, 2020 at 8:23 PM
    Vyprdad
    David
    Also installed a tv. On a swing out stand and entertainment sound bar. The rear outside back wall I have a projector had tv for so we can watch movies and everyone sit outside as well
