Foxwing awning/annex Group Buy - Round 4
Discussion in 'Automotive Group Buys' started by SoCalTacos, Jul 2, 2018.
  1. Jul 8, 2018 at 7:50 PM
    #41
    SoCalTacos
    SoCalTacos [OP] Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    In the op, the first picture is the square style. The other pictures are the standard triangle off the side.
  2. Jul 9, 2018 at 12:27 PM
    #42
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Ok. So can you put me down for a 2m square foxwing awning in grey. Driver side mount, as well as the annex. Thanks
    MY50cal and SoCalTacos[OP] like this.
  3. Jul 9, 2018 at 12:44 PM
    #43
    SoCalTacos
    socal
    Gotcha! Thanks!
  4. Jul 9, 2018 at 5:53 PM
    #44
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Interested!!!!
    Looking at previous GBs on which option
    I know I want drivers side. Green or sand. I have a LB Tacoma, loooing to make custom brackets, wondering if I can make the supporting legs just a little taller, I know if it’s raining this would make the water run towards the truck, but I’m taller too lol
    What’s the difference between the square option?
    I’m also looking for pictures of a 2m awning mounted over a Long bed Tacoma. I just don’t want the awning to be too close to the cab or hang way out passed the truck
    SoCalTacos[OP] likes this.
  5. Jul 9, 2018 at 10:00 PM
    #45
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    *past
    :boink:
    If you look closely at the first picture (black 3rd gen 4runner) all the pieces of the awning tarp are triangles. If you look at the last picture (red BMW X5) you see the first piece is square, followed by the remaining triangular pieces. Hope this helped.
    Edit: my bad, both photos are regular. The square one is the very first picture with the green awning. Apologies.
  6. Jul 9, 2018 at 10:12 PM
    #46
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    What size would you suggest for a long bed with a shell?
  7. Jul 9, 2018 at 10:16 PM
    #47
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Two meters is 6.5 feet. 2.5 meters is 8.2 feet. So the 2 meter fits pretty decent on the shell with no cab overlap. 2.5 meter will stick 2 feet, or approximately the rear door length over the cab. I cant speak for deployed size. OP can chime in.
  8. Jul 9, 2018 at 10:25 PM
    #48
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sounds like the 2m will be best. :thumbsup:
    arctic04trd[QUOTED] likes this.
  9. Jul 9, 2018 at 11:17 PM
    #49
    SoCalTacos
    socal
    For a 6ft bed I'd go with the 2m square.
  10. Jul 9, 2018 at 11:21 PM
    #50
    SoCalTacos
    socal
    The square is the shape of the awning off the side of the truck, then it wraps around in triangular pieces. If you have a long bed I'd go with the 2m awning. Itll be flush and not over the cab. Keep in mind, you can adjust where it mounts very easily using the rail system on the rear of the awning.
  11. Jul 10, 2018 at 9:26 AM
    #51
    vitistop
    vitistop ig: twosie_silverback
    Vit
    Los Angeles
    2017 Silver Tacoma TRD OR
    Bilstein 6112 front, Bilstein 5100 rear, Dakars
    how easy or hard is it to put up the annex?
  12. Jul 10, 2018 at 11:00 AM
    #52
    SoCalTacos
    socal
    not hard at all. It's in sections and uses velcro and zippers to attach to the awning and to the other sections. It's very lightweight and you can attach as many sections as you want. You can completely enclose the awning or have only a few walls up.
    MY50cal likes this.
  13. Jul 10, 2018 at 11:08 AM
    #53
    vitistop
    Vit
    Los Angeles
    what would it be for the 2m, square with awning option?
  14. Jul 10, 2018 at 11:20 AM
    #54
    4x4Taco09
    Dane
    Louisiana
    There are no crossbars that connect each legs together through the top of the canopy is there? Only video I can find on YouTube showed some pipe sliding into the edge of the canopy
    The legs will fit in the bag and then the bag in with the canopy too right? I know I want a square one. Just figuring out which color. I’m sure I’m going 2m as well
    I wish I could find someone to split an annex option with me. I don’t want that many walls and would probably never use all of them
    EDIT: Someone who has one of these should do a set up and tear down video ;)
    SoCalTacos[OP] and MY50cal like this.
  15. Jul 10, 2018 at 11:29 AM
    #55
    SoCalTacos
    socal
    it's $340 for the 2m square awning and $340 for the annex. You're in Los Angeles so you could will call from my location and save shipping.
  16. Jul 10, 2018 at 11:35 AM
    #56
    SoCalTacos
    socal
    There are no crossbars, tension pretty much keeps the awning tight between the poles. The annex has it's own bag to store it in as well. everything that comes with the awning itself will fit into the bag mounted on the truck for storage. I'd go with grey on a black truck, but to each his own...
    As far as the panels go, you could use as many and as little as you want. Couldn't hurt to have some "extra", in case they get damaged.
  17. Jul 10, 2018 at 11:38 AM
    #57
    SoCalTacos
    socal
    some pictures of the annex from a member. He already has a full setup and just ordered 3 more sets. He's provided some great feedback on these.
    4x4Taco09 likes this.
  18. Jul 10, 2018 at 12:05 PM
    #58
    4x4Taco09
    Dane
    Louisiana
    Thinking Tan or Green
    My boot bags are Tan and idk if I want it all green
    Looking to put it on drivers side and wrap around the back. Just trying to figure out how I can prop open the drivers side window if I put the 270awning there....
    297DCE58-D1C9-4599-ADBB-8518045FED3B.jpg 4BE0663F-0B50-4058-8A86-FAC9C3977D30.jpg 828A2757-A10D-44BA-8D40-5180549B63E6.jpg
  19. Jul 10, 2018 at 12:11 PM
    #59
    nothrill87
    nothrill87 Well-Known Member
    Richmond Hill, GA
    2016 DCSB TRD OR
    OEM door sill protectors Husky Xact fit floor liners Tailgate letters Mobtown Sliders Y-pipe reroute RCI 90% Aluminum Armor Custom modular bedrack with mounted Hilift and removeable fishing pole holder rack RokBlokz oversize mudflaps (for future lift and tire upgrade) Xpel tailgate and doorhandle cup protection film ARB rear diff breather valve relocation ARB Twin Compressor in bedbox Coming soon: ARB Safari Snorkel
    Whrn is your cut off?
  20. Jul 10, 2018 at 1:44 PM
    #60
    SoCalTacos
    socal
    are you going to mount it to your roof rack or bed rack? it shouldnt interfere with the window if its on your roof rack. If it's on your bed rack, you could mount it far enough towards the rear so it doesn't interfere with the window.
