FPR Mod Vs URD Fuel Pump for S/C and 2.85 pulley
Discussion in 'Performance and Tuning' started by 2wheelnut, Apr 1, 2014.
  1. Apr 1, 2014 at 9:58 PM
    2wheelnut
    2wheelnut [OP] Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Other than having the fuel filter, which I know is needed, would I be able to get away with doing the FPR mod with the S/C and TRD CAI coupled with the URD pulley for a while?
    I have the CAI on the S/C now and so far so good. I know the reflash is ok with the 2.85 pulley but most folks say to upgrade the fuel pump before, during or after the pulley swap. I didn't want to mess with the pump just yet since I read some with slow start or other issues...
    If I have to do you guys recommend the Walbro > the AEM or Deatschwerks?
  2. Apr 1, 2014 at 10:59 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Just don't overtightened the hose clamps and u should be fine.
    Not all reflashes are the same.....
    What are ur current AFR?
  3. Apr 2, 2014 at 1:57 AM
    2wheelnut
    Angelo
    Vallejo, CA
    Not sure yet as I still have to get a meter and slap it in. So is the walbro pump ok? No need to go aem etc? My friends with Lan Evos say the walbros whine like crazy.
    Not in it to WOT stop light to stop light etc. I'm planning to add serious weight to expo and armor my truck and just want my throttle response and power to still be there.
    Although this thing is fun right now!!!:D
  4. Apr 2, 2014 at 4:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The Walbro isn't that loud, since it is so far away. If you had a car, you would definitely hear it. I do in my Subi. Barely noticeable in the truck though.
    I have the Deastchworks waiting to go in. Definitely upgrade the pump. Cheap insurance for your engine.
  5. Apr 2, 2014 at 7:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just remember. Pump feeds injectors. Injectors feed the engine.
  6. Apr 2, 2014 at 5:22 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    tank feeds fuel pump......
    Gas pump feeds tank..........
    wallet gets RAPED by gas pump
  7. Apr 2, 2014 at 9:27 PM
    tank3105
    tank3105 Well-Known Member
    Houston
    13 baja T/X edition supercharged
    Supercharged.
    Been running 2.85 and cai on fpr mode with stock filter and pump for 8 months wot on aem reads 10.9. I say you don't need it. Invest in an aem wideband.
  8. Apr 3, 2014 at 4:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have a fuel pressure gauge or have a way to datalog your fuel pressure?
    I recommend getting a fuel pump. Cheap insurance. Cheaper than most wideband gauges.
  9. Apr 3, 2014 at 6:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    An enjoyed truth.
  10. Apr 3, 2014 at 2:18 PM
    2wheelnut
    Angelo
    Vallejo, CA
    Hahaha. Not too bad so far.
    Now I'm looking to get more bottom end. The truck has a noticeable hit at 3000 rpm. I believe it's from the VVTI kicking in and built up boost. I'm trying to bolster power between 1,800-3000 rpm for daily driving. The pump is cheap insurance though. But the FPR mod is free and I hoped to hold me over for a while since I just dropped a bunch of money on the S/C and now trying to get what I wanted from it.
  11. Apr 3, 2014 at 4:41 PM
    tank3105
    Houston
    Supercharged.
    Get some shorty headers.
  12. Apr 3, 2014 at 6:06 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Wideband AFR is a great idea...but there is a reason the Boosted community recommends upgrading your pump....because there have been many ,many,many engines starved to pieces, a lot of them relied on gauges, which CAN BE inaccurate at times....A Walbro 255 is $155 , plus you have the ability to change out filters in 5 minutes...no brainer for me after dropping 5 Large on Rooting this bitch......
  13. Apr 3, 2014 at 6:51 PM
    2wheelnut
    Angelo
    Vallejo, CA
    $155 is cheap insurance...
  14. Apr 3, 2014 at 7:38 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Cheap indeed.
  15. Apr 3, 2014 at 8:20 PM
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    How hard is it to drop the tank and install the URD Walbro fuel pump kit?
  16. Apr 3, 2014 at 9:42 PM
    2wheelnut
    Angelo
    Vallejo, CA
    Wondering the same, I was over at XRU and TORSPD's build thread has the tank out... Looks pretty straight forward.
  17. Apr 4, 2014 at 5:56 AM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Do a thread search....it's been discussed a few times on here....or your local performance shop can do the install in about 2 hours.....!
  18. Apr 4, 2014 at 6:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is really easy to drop the tank. Just make sure that you are close to "E". No need to fight the weight of the gas.
    Instructions are easy to follow. Tank is easy to drop. Just take your time so that you don't stress any connectors, on the top of the tank.
    My best time was 30 minutes. On an Xrunner. Which makes it a little harder.
  19. Apr 4, 2014 at 7:14 AM
    BLOODYMARY
    Keith
    Tulsa, OK
    2012 Tacoma Double
    Nice thanks!
  20. Apr 4, 2014 at 8:15 AM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    If I leave now, I can be there by noon tomorrow...and should be just about on "E" when I hit Houston...after 13 fill ups...I'll bring beer.
