FPR Mod Vs URD Fuel Pump for S/C and 2.85 pulley
Discussion in 'Performance and Tuning' started by 2wheelnut, Apr 1, 2014.
  1. Apr 4, 2014 at 8:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bring it. :cheers:
  2. Apr 4, 2014 at 11:45 AM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
  3. Apr 16, 2014 at 5:04 PM
    2wheelnut
    2wheelnut [OP] Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    So I got the AEM 320 lph E85 approved from a member here, but it comes with a pre filter, how do I go about putting in an inline? Should I even bother? The pre filter looks like it wont filter much.
  4. Apr 16, 2014 at 5:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Apr 16, 2014 at 5:17 PM
    2wheelnut
    Angelo
    Vallejo, CA
  6. Apr 16, 2014 at 5:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At Napa, it is about $6.
  7. Apr 16, 2014 at 7:06 PM
    2wheelnut
    Angelo
    Vallejo, CA
    Will I need more hoses other ancillaries etc.? Sorry for all the ??? I'm in XRU right now searching and searching.
  8. May 23, 2014 at 11:24 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Ok,
    First, my fuel pump is now changed. Logged AFR was OK (TRD SC with 2.85 pulley, TRD CAI Pro Dry, DTLT headers, TRD catback) until i've added the DT Y-pipe. Adding it had an important impact on my AFR curve. Keep in mind that the OEM FPR mod was done on my truck. With the Y pipe it became impossible to maintain an AFR between 11-11.5 over 4500 rpm.
    I have few question in mind about the FPR mod and would be curious to look at explanations from experienced guys like TOR. Please correct me if i'm wrong and excuse my English.
    Ok first, the base of the theory for doing FPR MOD is to increase fuel and avoid starving at boost. Let say stock pressure in the FI circuit to be close to 44 psi. People saying that cause there is a positive pressure in the inlet manifold (ex: 7 psi), the absolute injection pressure will be 44 psi - 7 psi = 37 psi. By doing the FPR mod you're applying the pressure from the inlet (7 psi) manifold to the diaphragm of the FPR so it will raise the pressure in the FI circuit at 44 psi + 7 psi = 51 psig so the absolute pressure of the fuel injected will be maintain to 44 psi (51-7=44). It supposed to help not starving the truck (when no fuel pump mod done).
    My problem is that more pressure in the FI circuit doesn't mean more fuel flow. It maybe produces a better vaporisation of the fuel but not more fuel flow. In fact if the FPR mod raised the pressure (restrictive circuit) in the FI circuit, fuel flow will go down so the result gonna be worst.
    I have the FPR mod and cause of the new fuel pump, i'm fine tuning my AFR curve now. When I,ll be satisfied with it, i will record a run and then undo the FPR mod and record a new run so we can compare.:confused:
  9. May 23, 2014 at 11:46 AM
    Vassily28
    Just to give you all interesting informations.
    Look at the 3 graphs extract from different logs i've done.
    We can see pretty well the impact of adding the Y-pipe and adding the fuel pump.
    :eek:
  10. May 30, 2014 at 5:52 AM
    Vassily28
  11. May 30, 2014 at 6:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The FPR mod is not to help give extra fuel when no the fuel pump is not upgraded. It is to help the injectors flow extra fuel because they will be at a higher fuel pressure than stock, when under boost.
    The fuel pump should still be upgraded BEFORE of the FPR mod. As the increased pressure on the stock pump will tax it even more. Increase pressure on a fuel pump, and it decreases output. Not wise to do on a stock fuel pump.
  12. May 30, 2014 at 11:22 AM
    Vassily28
    Ok TOR,
    Same as you but it seems to me that a lot of poster in many threads saying to do FPR mod at least if not upgrading pump.
    My FPR mod was done with the stock pump but as you can see, i'm always monitoring my AFR and the impact of changes i'm doing. :D
    It's funny to see how important is the impact of the new pump on the FI circuit and the resulting AFR.
    I lately realize when tuning the trims that most of them remain correct in mid to high TPS, RPM and in boost but have to add fuel at low TPS (16 to 24%).
    My fuel map (MAF cal.) is almost ready now so when i have time i will to the compare for FPR mod and no mod in exact same conditions.
  13. Jun 18, 2014 at 7:48 PM
    Celinap22
    Celinap22 Member
    Celina
    Spartanburg
    04 4x4 SR5
    I have a 04 manual tacoma and recently when I get gas it sputters usually when im going from 2nd to 3rd. It feels like if its not getting fuel. Could it be a fuel filter or fuel injectors? Today it turned off as I was turning and at a light.
    Like
  14. Jun 19, 2014 at 4:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could be those two things and or a vacuum leak. How many miles does your truck have?
  15. May 11, 2015 at 1:20 PM
    #35
    Vassily28
    Ok almost a year ago i've said that i will come back with data log showing the impact of the OEM FPR mod.
    I'm still working on the truck and i was removing the MAF controller, so i've removed the FPR mod and done a log session and the day after, re-install it and done an other log session. So you will find the result in the document attachement.
    I was a bit surprise after removing the MAF controller cause remember how rich was the mixture at WOT before the installation. This time it's not the case cause you'll see that the ECU is maintaining a steady AFR of 11 at WOT in 3rd gear. I'm not sure if it's the reason of it, but we had to add and soldered a little piece of electrical wire for the MAF signal and the gauge is way to large for a 5v signal (it's propably a 12 or 14 gauge). It seems to act as a resistance and offset the signal, maybe. If it's really that, but the AFR is steady as never, maybe a bit on the safe side for a forced induction but i've seen worst. I will correct that later but like said, at least i know i'm on the safe side.
    So with the stock setting the AFR is between 11.5 and move to 12 at higher rpm. With the FPR mod (with the same setup)the FPR is almost stready at 11.
